Abstract:
; R9 O1 \- \+ B; l7 s( c/ TThis paper describes reasonable design of the HVDC-VSC model for large grid-connection wind farm, and presents the short-term stability (three phase short circuit fault) simulation results.! e% E5 q% q3 p
In this paper, it presents an aggregated, single-machine model of the wind farm has been added at the wind farm-side of the HVDC-VSC transmission system, and also a reduced pitch control model of the wind turbine blade pitch system has been implemented. Therefore, the HVDC-VSC model has been designed, when the gird is subject to faults, the dynamic control for the grid-side and wind farm-side converter is applied to control the HVDC-VSC transmission system and allow the ride-through operation. A simplified model of the grid equivalent delivered by Energinet.dk has been presented for the simulation.' Y1 E9 d! Y5 p$ D
The comparison of the grid-connection wind farm behaviours in the power system with and without HVDC-VSC in operation has been carried out in the paper. |
