查看: 1109|回复: 0
[风能] Clean Oil, Bright Ideas
发表于 2008-11-5 09:27:35 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
The Importance Of Oil Cleanliness9 ?1 J; U2 e7 U, f. t/ A/ |
Oil cleanliness has a huge impact on the lifetime of the bearings and gearboxes in wind turbines.
4 L2 X+ C& ]% v& z( s+ `Oil contamination can be reduced considerably by the use of fine filtration, doubling the lifetime of bearings and gearboxes (source: Life Extension Factor, Noria Corporation). 1
Laura C Ancho-English.pdf
943.81 KB, 下载次数: 4
