查看: 1102|回复: 0
[风能] A Modelling Experiment on the Tornado-type
发表于 2008-11-5 09:33:12 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
Abstract:) {% p4 O4 p8 U& `
Tornado-type wind-powered water-pumping system consists of Tornado-type tower and water-elevating tube. The flow entering the tower forms a strong vortex which creates a low pressure region at the bottom of tower, and this low pressure makes it possible for the pressure difference water-elevating device to lift water. In this paper, the model test of the wind-powered water-pumping system was conducted and the results of the tests prove that the principle of the system is correct.: v3 @( V( h: H% x1 W4 S9 ^
Key words: wind energy, tornado—type tower, water-elevating tube
Wei Ning.pdf
102.92 KB, 下载次数: 5
