查看: 1147|回复: 1
[风能] Improving Blade Fatigue Tests Using A Crank-Rod Mechanism
发表于 2008-11-5 09:37:24 | 显示全部楼层 |阅读模式 来自: 中国湖南湘潭
Abstract:
2 u. k! B+ q: x) b) D. bDevelopment of blade test loads is indicated and it is shown why multi-axial tests have a higher potential of facilitating reliable blade testing. A cost-effective crank-rod multi-axial testing method is developed and implemented.
J.J. Heijdra.pdf
145.22 KB, 下载次数: 11
发表于 2008-11-9 15:35:16 | 显示全部楼层 来自: 中国辽宁沈阳
不错的资料,感谢楼猪!
