发表于 2010-1-26 16:28:58
来自: 中国江苏无锡
不同标准的规定是不同的,你想用什么标准来测,就看看相应的标准啦,这些标准有:1 x* T2 p9 j0 P% D2 u1 }
1、ISO 16276-1:2007 Corrosion protection of steel structures by protective paint systems —Assessment of, and acceptance criteria for, the adhesion/cohesion (fracture strength) of a coating —Part 1: Pull-off testing
. ?+ M5 D; O; P* ^/ k( X3 k1 w3 W2、ISO 16276-2:2007 Corrosion protection of steel structures by protective paint systems —Assessment of, and acceptance criteria for, the adhesion/cohesion (fracture strength) of a coating —Part 2: Cross-cut testing and X-cut testing- @; I1 _5 [. P- j Q
3、ISO 2409:2007 Paints and varnishes —Cross-cut test2 E7 ^9 ~* |2 V# Q$ k0 e; K4 K' w
4、ISO 4624:2002 Paints and varnishes —Pull-off test for adhesion( U- s$ G6 g0 `! {2 M' N$ P
5、ASTM D 3359-02 Standard Test Methods for Measuring Adhesion by Tape Test. C7 P0 e, @8 P. W$ H
6、ASTM B 905-00 Standard Test Methods for Assessing the Adhesion of Metallic and Inorganic Coatings by the Mechanized Tape Test
2 y3 c; S3 N0 P$ C9 V. Q7 M* |7、ASTM D 2197-04 Standard Test Methods for Adhesion of organic coatings by scrape adhesion3 c/ U7 o+ @- _; {+ [
8、GB/T 9286-1998 色漆和清漆—漆膜的划格试验(eqv ISO 2409:1992)' D3 C* r, O0 D: w" R5 _; p
9、GB/T 5210-2006 色漆和清漆—拉开法附着力试验(eqv ISO 4624:2002) |
