发表于 2008-11-9 19:39:23
来自: 中国江苏无锡
不好意思,由于不会发附件,只能粘贴这了
液压专业常用英语词汇2 i, Z2 D' k" e. k. F3 y
一、阀类( ~2 D( ~1 l8 f& }
Solenoid valve 电磁阀
w$ a' ^. u- B FCheck valve 单向阀
, B: u3 u0 P3 d3 oCartridge valve 插装阀8 J$ f5 \* _+ d% s7 x
Sandwich plate valve 叠加阀* n! |; L2 H& |3 _2 r+ R j
Pilot valve 先导阀
% ^8 W) |9 a* F5 ~. S! k" v& M! `5 IPilot operated check valve 液控单向阀4 V& }* f5 {1 `9 n6 J, F
Sub-plate mount 板式安装* C p! j6 ~1 S+ M: k1 Y$ T# X
Manifold block 集成块0 H2 i2 f0 s% o! |
Pressure relief valve 压力溢流阀
4 Q8 H, [4 c' H6 Y( P2 sFlow valve 流量阀
t0 r* x/ O$ @ F& W7 I0 H, RThrottle valve 节流阀0 d2 r; p* T& q* P w0 ]
Double throttle check valve 双单向节流阀0 Q6 c' }1 F. n R
Rotary knob 旋钮
# C% W/ y3 M, P- ARectifier plate 节流板7 s; T3 k; X) v& k( @ n
Servo valve 伺服阀
1 E1 a( ^& ]# Y) D6 U" l/ yProportional valve 比例阀/ U3 \" O/ l z
Position feedback 位置反馈
& M% g# T9 ` o$ m# yProgressive flow 渐增流量( e% d* t( ^. g# }
De-energizing of solenoid 电磁铁释放 j3 W. N5 i9 L
2 ]3 p, j, Q/ f: I
二、介质类4 k( r! Q: r) W# c8 R6 x0 P, b
Phosphate ester (HFD-R) 磷酸甘油酯
! J0 C8 d, s' {' [Water-glycol (HFC) 水-乙二醇) V; Z% F7 v0 T; O9 w, q6 L
Emulsion 乳化液
2 O* h* R3 q+ p. P; gInhibitor缓蚀剂
( x) `( A. p5 [( ISynthetic lubricating oil 合成油
+ X$ z7 Y* p7 U/ x2 ~7 L4 ^
6 n! H: T9 ~0 F! I三、液压安装工程
: Y; K+ j+ Q" M/ E* U* }Contamination 污染, @# M, m1 J( Q, `
Grout 灌浆) n! l, U n6 d T
Failure 失效- c7 j ?, O- \- g$ e( x( }1 v F
Jog 点动
, R' Y. _& {, G8 k' }8 j8 M8 @, `Creep爬行
* l5 f8 o1 i3 o" ZAbrasion 摩擦0 J- Z. s; [( g# o/ c! R0 O" a$ P
Retract(活塞杆)伸出
0 c# S+ ]5 b& ?Extension (活塞杆)缩回
! |; [2 h. P8 k: j. P/ rMalfunction 误动作- s; E7 o: [0 `& y+ K
Pickling 酸洗
, F( Z/ Y h: P/ Z" S0 {! {4 HFlushing 冲洗
& l: W: v7 O4 M1 ?7 ]4 oDipping process 槽式酸洗
4 y, R. A: Q3 eRe-circulation 循环# y8 t2 \5 s$ f; t/ q( N* b
Passivity 钝化/ Z: T5 d4 s b4 | D+ F
Nitric acid 柠檬酸* n% {8 j& x" v G' I7 i
Argon 氩气
) b8 g! Y J3 f& x3 R3 ]$ rButt welding 对接焊
+ {( o4 V/ D8 E5 }0 W! nSocket welding 套管焊
8 Y5 T( h) M( W hInert gas welding 惰性气体焊
9 b) Z- ]; t% p8 e; |+ V6 ^/ _' T# O) s; s3 M! Y1 \
四、管接头
2 L2 p- L8 |: _" LBite type fittings 卡套式管接头
# T4 ~6 V; @- f- B' bTube to tube fittings 接管接头
1 E/ }) v3 J6 w7 B7 h! x/ f union 直通接管接头- R2 D3 q: A/ N, x, U* |$ X0 z
union elbow 直角管接头) h* [- I+ H+ R4 O, [$ e
union tee 三通管接头, q9 Y8 f& a6 v3 a" `9 q# h) H& e
union cross 四通管接头! j! k. ^) i! A0 t) v5 L
Mal stud fittings 端直通管接头4 f' ~7 [( Q# O$ d. W x' Z
Bulkhead fittings 长直通管接头
/ p/ @. ~$ O! Z2 e* l$ SWeld fittings 焊接式管接头
2 y! e: M" N, k3 i' w, gFemale connector fittings 接头螺母8 ?! C! K& Y7 O& {) L
Reducers extenders 变径管接头! m; @5 X; z, P' h
Banjo fittings 铰接式管接头
! V6 Z0 C8 u; I% _' ^Adjustable fittings/swivel nut 旋转接头
/ I6 s9 N0 C/ R' ~( G; \* z# s. V1 ]- B8 p! c# n8 z7 b Z/ I$ l; }" Z
五、伺服阀及伺服系统性能参数
3 G+ O+ [9 X5 C4 w* G$ t$ W& KDynamic response 动态频响
( L1 d8 \! F$ M8 hDDV-direct drive valve 直动式伺服阀
5 E# J! [# `1 D2 L) ^, VNFPA-National Fluid Power Association 美国流体控制学会3 p9 f, r5 s* J1 G( e8 I" [' z% y
Phase lag 相位滞后& k+ `6 b$ }7 S( ~8 [
Nozzle flapper valve 喷嘴挡板阀 p" w9 r# Q1 i) I- n+ @
Servo-jet pilot valve 射流管阀- u5 B5 k" U f/ j
Dither 颤振电流
5 \1 u- r- G" [* E, q1 Z0 Z" K. HCoil impedance 线圈阻抗& Q$ R' a- ^- E& g; H( }
Flow saturation 流量饱和
P! H5 |* c( R1 V- y( HLinearity 线形度 C1 L# ^& }$ C, Y: o
Symmetry 对称性7 E9 L9 u0 b- C& `' [) P# I' j
Hysterics 滞环4 z S. }) k) X
Threshold 灵敏度6 c0 d" F' E# Z8 g
Lap 滞后- z( _4 B9 |% m; d
Pressure gain 压力增益
3 k8 L3 W8 A/ n) S& h/ @+ V3 eNull 零位+ o$ @) d6 R& V% W
Null bias 零偏2 j+ s- B6 K$ X/ x, b
Null shift 零飘3 H, a8 _1 q. L6 _/ T
Frequency response 频率响应3 B# M) _ Y" j% W7 O; t
Slope 曲线斜坡
4 |8 O2 L- S) g5 T
# W' {! `# \: v+ G( U/ m六、密封材质代号
3 j }; R! K9 i& SNR 天然橡胶4 o% S2 `' v) ]" ]& U
NBR 丙烯晴-丁二醛-橡胶
7 r, l) o8 W& wCR 氯丁二烯-橡胶 |
