The steam turbine driver shall be rated for continuous operation at 105% of the compressor design speed and also for 110% of the compressor highest required shaft power. The turbine shall be of condensing type. Turbine shall be furnished in accordance with API Standard 612. 5 @* N8 N0 t+ b; _3 F* j* M
The compressor and turbine driver must be operational across the range of cases provided without recirculation via the minimum flow bypass. Vendor shall advise the minimum flow point for each case.
