查看: 1511|回复: 0
[讨论结束] 宏出现了问题有高手可以帮忙看一下ㄇ
发表于 2008-12-14 11:53:35 | 显示全部楼层 |阅读模式 来自: 中国台湾
本帖最后由 astrokylin 于 2010-7-16 22:42 编辑 0 z/ a3 j/ ~$ i3 r6 j9 e# C2 M
! V* D/ e+ n3 @9 q/ W) R- t* m宏出现了问题有高手可以帮忙看一下ㄇ
. ~/ v) H: f. m  k; ~2 ?! {1 q宏执行出现了第十二行发生错误1 X* _  e) v. g# `. S7 Z
+ X  r0 V  {( T" W* m0 ~NX 4.0.4.20 J& Q4 k7 G, r
Macro File: E:\do\2d_e.macro
) g/ O) @2 m0 [" K& K2 T  QMacro Version 7.505 _  K9 X- q+ @6 d3 {
Macro List Language and Codeset: trad_chinese 7
3 h; G! q5 ^7 `. E7 PCreated by ici on Thu Jul 29 08:50:41 2004+ z4 |. H% L3 M# _4 j
Part Name Display Style: $FILENAME, J3 n4 F+ E/ v! G" D" n
Selection Parameters 1 2 0.270669 1. s/ ?  x9 _- g
Display Parameters 1.000000 12.032480 5.733268 -1.000000 -0.476483 1.000000 0.476483* u0 h5 `% M: h! \9 ~5 }
  m0 j8 m: C$ A# A0 r1 [- IRESET: |  b2 f4 K! C/ J
MENU, 0, UG_APP_DRAFTING UG_GATEWAY_MAIN_MENUBAR ! * L. }/ i" q; V: g5 _
ASK_ITEM  0 (1 WIDE 0) = "*"  ! Filter1 A& [2 M0 c$ [2 G) p& W2 i5 p
ASK_ITEM  1 (1 SELB 0) = "SHT1"  ! Drawing Sheet Name. C, G' B9 g8 ?' h8 r
ASK_ITEM  1 (1 SELB 0) = -1  ! Drawing Sheet Name
: R& g9 y1 |# q1 b7 N6 E( R: ZASK_ITEM  4 (1 OPTM 0) = 0  ! A - 8.5 x 11
# r- H, y* O* b" J+ h1 zASK_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 297% M  D: S) K1 B( W
ASK_ITEM  6 (1 REAL 0) = 210.0000000000000000  ! Height) O# ^& D  A# ]1 [- r# x# R
ASK_ITEM  7 (1 REAL 0) = 297.0000000000000000  ! Length
1 I. ]* m0 r$ R, Z% g) v. j9 i8 E1 j  kASK_ITEM 10 (1 REAL 0) = 1.0000000000000000  !
1 P1 H7 J* r4 {( PASK_ITEM 12 (1 REAL 0) = 1.0000000000000000  !  3 Z' c+ C# U* M6 N6 y1 y6 a
ASK_ITEM 14 (1 RADI 0) = 1  ! Millimeters
$ t+ c: j9 D. r. t* ^: v: N2 aDIALOG_BEGIN "New Drawing Sheet" 0
' H% x4 P& J( U* V8 N1 A7 O BEG_ITEM  0 (1 WIDE 0) = "*"  ! Filter
* W' u' U7 c) e1 ? BEG_ITEM  1 (1 SELB 0) = 0  ! Selection Box (Items selected)2 G# ?3 Z. b) h0 a" t9 E) T4 e( E) o
      SELECTION = "SHT1"& s/ g. o- k' t1 f' c" v8 ~, i
BEG_ITEM  4 (1 OPTM 0) = 0  ! A - 8.5 x 11" s! F1 i0 d1 s
BEG_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 2971 C5 |$ [- k6 t% [1 p) n
BEG_ITEM  6 (1 REAL 0) = 210.0000000000000000  ! Height3 W2 v- d% q5 r% ?: P3 E* W
BEG_ITEM  7 (1 REAL 0) = 297.0000000000000000  ! Length2 i0 `3 i2 R4 M6 M( B/ W/ ~( f4 }
BEG_ITEM 10 (1 REAL 0) = 1.0000000000000000  !  1 l" S" ]7 U. C& k
BEG_ITEM 12 (1 REAL 0) = 1.0000000000000000  !
+ j( d# ?, Z8 a  t BEG_ITEM 14 (1 RADI 0) = 1  ! Millimeters
, o& U- u- n) _6 H( z* Y4 r BEG_ITEM 15 (1 RADI 0) = 0  ! 3rd Angle Projection) f/ K/ ?1 a' S5 c2 H
WINDOW RESIZE 1.000000 11.478839 7.886319 -1.000000 -0.687031 1.000000 0.687031
$ t/ `' d( k2 t% s; o EVENT ACTIVATE -10 0, 5, 0, 0! A4 - 210 x 297) T9 }' c: o3 b" w# T
ASK_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 297% W+ e& t* @2 Z0 }/ W/ g+ D
ASK_ITEM 15 (1 RADI 0) = 0  ! 3rd Angle Projection+ M& S! E  D2 U( [  p; W% y% y  ~: b
7 s- r6 ~3 g, ~; b# L2 _ ASK_ITEM  1 (1 SELB 0) = "SHT1"  ! Drawing Sheet Name( w7 _& U: I9 h/ Y
ASK_ITEM  1 (1 SELB 0) = -1  ! Drawing Sheet Name0 z: S& W  N" p$ r
ASK_ITEM 10 (1 REAL 0) = 1.0000000000000000  !  % Z, N' g: _5 w  o; k& G* ?' I
ASK_ITEM 12 (1 REAL 0) = 1.0000000000000000  !  : L1 ]2 V$ W/ T4 A& U
ASK_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 2972 E0 a. W! m" S
OK -10 0 ! OK Callback; I% ]# B( q+ ]8 S8 j1 k  P
$ ?2 C' G6 Y7 C! h3 P, d' q9 `. H ASK_ITEM  1 (1 SELB 0) = "SHT1"  ! Drawing Sheet Name
! ~( q  }; {' e8 _  X4 q. q ASK_ITEM  1 (1 SELB 0) = -1  ! Drawing Sheet Name
: ~" O( P/ S8 R4 _9 L0 ^& Z  r ASK_ITEM  4 (1 OPTM 0) = 0  ! A - 8.5 x 11
) @4 b% d! \3 w! Z ASK_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 2974 \& C- f; }4 B- ^9 _  X
ASK_ITEM  6 (1 REAL 0) = 210.0000000000000000  ! Height+ d5 @" R" b8 V! A. H7 I& ]2 @
ASK_ITEM  7 (1 REAL 0) = 297.0000000000000000  ! Length1 W! \3 J) X! N( G
. ]9 [% y. Y/ @+ } ASK_ITEM 12 (1 REAL 0) = 1.0000000000000000  !  3 I( h1 k0 v& F5 _/ @' `
: V. \- Z% P5 _7 G, A8 u ASK_ITEM 15 (1 RADI 0) = 0  ! 3rd Angle Projection
) }: S+ Y7 ]$ A  W( Z0 a4 b0 @2 O ASK_ITEM  0 (1 WIDE 0) = "*"  ! Filter
) m! r6 d' H: i: ?; W+ @# p ASK_ITEM  1 (1 SELB 0) = "SHT1"  ! Drawing Sheet Name! n7 i4 p/ @* H; D$ r! Y2 l" c
  S; j! W  h) ]4 a* O6 \ ASK_ITEM  4 (1 OPTM 0) = 0  ! A - 8.5 x 11
! A% \8 {2 P  ?/ g  n3 { ASK_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 297
' H3 {: @* b0 V3 N2 G ASK_ITEM  6 (1 REAL 0) = 210.0000000000000000  ! Height
! h8 t# }9 x" F  ` ASK_ITEM  7 (1 REAL 0) = 297.0000000000000000  ! Length6 F- g, C* |& a# l0 x8 b
4 s; l- o( v) n. M7 M! G0 C ASK_ITEM 12 (1 REAL 0) = 1.0000000000000000  !
6 Q1 V$ ]0 h2 }8 Q* `/ |1 I ASK_ITEM 14 (1 RADI 0) = 1  ! Millimeters
. q( ]) I* r; ~/ N6 i+ C6 @ END_ITEM  0 (1 WIDE 0) = "*"  ! Filter* Q) U* R" ?9 F2 f
END_ITEM  1 (1 SELB 0) = 0  ! Selection Box (Items selected)
% k3 f- E% R+ |) b      SELECTION = "SHT2"
/ m" _6 E1 B" k END_ITEM  4 (1 OPTM 0) = 0  ! A - 8.5 x 11
# Y9 x: R2 M* z1 W END_ITEM  5 (1 OPTM 0) = 0  ! A4 - 210 x 297! k9 ~8 g- q, d# `9 W% a0 [
END_ITEM  6 (1 REAL 0) = 210.0000000000000000  ! Height
# b4 R+ }$ O& T1 u' b, K END_ITEM  7 (1 REAL 0) = 297.0000000000000000  ! Length- ^5 S/ n" J0 M/ X; Q9 y$ g
END_ITEM 10 (1 REAL 0) = 1.0000000000000000  !  " k4 Y& ^1 x- n
END_ITEM 12 (1 REAL 0) = 1.0000000000000000  !  * s! S7 R' y9 D: _
END_ITEM 14 (1 RADI 0) = 1  ! Millimeters
2 M) X! u) ?0 I- e! G8 C END_ITEM 15 (1 RADI 0) = 0  ! 3rd Angle Projection
' G5 R& Z* p% t$ Z+ d* j5 D  XDIALOG_END -2, 0 ! New Drawing Sheet: OK
+ ~: e% V3 k# R( [" y* f6 ~FOCUS CHANGE IN 12 \; I  \/ O9 h/ S1 V4 C
MENU, 0, UG_PREFERENCES_VISUALIZATION UG_GATEWAY_MAIN_MENUBAR ! 6 k- x+ `+ o& R7 F
DIALOG_BEGIN "Visualization Preferences" 5005
- Q) w5 Q& ]* d) R PROP_PAGE 59 ! Color Settings
& {2 m3 z9 b+ { BEG_ITEM  3 (1 MULT 5005) = 0  ! List (Items selected)! Q( m7 R' j, M
BEG_ITEM  4 (1 BOOL 5005) = 0  ! Update this setting to all selected views
" M! m4 N! `8 u8 q+ ] BEG_ITEM  5 (1 OPTM 5005) = 0  ! Wireframe3 a+ X5 n, |# h6 _) @
BEG_ITEM  6 (1 BOOL 5005) = 0  ! Update this setting to all selected views, i# d1 p$ l+ U% a& q
BEG_ITEM  7 (1 OPTM 5005) = 0  ! Visible; A' m2 p1 C( X% e8 B) |! _
BEG_ITEM  9 (1 BOOL 5005) = 0  ! Update this setting to all selected views
7 H) o1 Q1 A" l4 d9 D. Q, Q- x BEG_ITEM 10 (1 BOOL 5005) = 0  ! Silhouettes5 V. ~3 J& O6 P" ]# W8 f
BEG_ITEM 12 (1 BOOL 5005) = 0  ! Update this setting to all selected views* N) o2 b/ Q- ^! x- Z9 }* z
BEG_ITEM 13 (1 BOOL 5005) = 0  ! Smooth Edges5 A4 d+ l: _4 _$ y: u5 i
BEG_ITEM 15 (1 CTOL 5005) = 1  !  7 a; Q3 E# q7 P6 H' t: T; [
BEG_ITEM 16 (1 BOOL 5005) = 0  ! Original8 z8 G  L  C4 k, R, e2 d2 I
BEG_ITEM 17 (1 OPTM 5005) = 0  ! Original
$ _% w1 J$ E3 l6 K BEG_ITEM 18 (1 OPTM 5005) = 0  ! Original/ J' W% G! v' r! k8 H$ P
BEG_ITEM 20 (1 BOOL 5005) = 0  ! Update this setting to all selected views# `% P0 X3 l4 \6 J: y" @
BEG_ITEM 21 (1 BOOL 5005) = 0  ! Two-Sided Light
7 S) n: ]3 p+ n5 [" C BEG_ITEM 22 (1 BOOL 5005) = 0  ! Update this setting to all selected views' [; Z. v2 n1 H  |6 w0 a
BEG_ITEM 24 (1 SCAL 5005) = 0.0000000000000000  !
8 ^0 r# ^6 V- j1 V1 @8 h- N, ~ BEG_ITEM 28 (1 BOOL 5005) = 0  ! Update Hidden Edges
' |% j* a2 Y, _; w8 q! h# S: f BEG_ITEM 31 (1 BOOL 5005) = 1  ! Translucency' P- W  S* A7 W; X7 ?
BEG_ITEM 32 (1 BOOL 5005) = 0  ! Line Antialiasing0 l$ ~* Y9 S  b  X" e
BEG_ITEM 33 (1 BOOL 5005) = 0  ! Full Scene Antialiasing# C& h3 [9 c: U4 A5 U
BEG_ITEM 39 (1 OPTM 5005) = 0  ! Coarse; t$ M7 Q8 T6 k, {
BEG_ITEM 40 (1 OPTM 5005) = 0  ! Visible Objects, Q* @; I0 ?% {
BEG_ITEM 43 (1 OPTM 5005) = 0  ! Coarse  S5 N( ]$ f! k: h# _" F
BEG_ITEM 44 (1 OPTM 5005) = 0  ! Visible Objects
7 G- f1 q2 d! o7 o0 _- g# d4 ~" q BEG_ITEM 47 (1 CTOL 5005) = 1  !
; N# s9 V7 M, Y0 X/ {! i$ @, U BEG_ITEM 49 (1 OPTM 5005) = 0  ! Off9 T% P* W: h0 N% H4 F2 N4 O$ t- A1 y: o
BEG_ITEM 51 (1 CTOL 5005) = 1  !  * @6 }2 R8 S: F% ?1 l
BEG_ITEM 52 (1 OPTM 5005) = 0  ! Invisible
  o- F2 l$ F" f6 ]; c) j BEG_ITEM 56 (1 BOOL 5005) = 0  ! Show Facet Edges) h1 q2 C1 P, j& M$ _& d
BEG_ITEM 57 (1 BOOL 5005) = 0  ! Edge Emphasis* c" r1 p% j- ?) z9 R6 C
BEG_ITEM 62 (1 CTOL 5005) = 5  !
. v- |; x9 ^) g) d4 | BEG_ITEM 64 (1 CTOL 5005) = 4  !  7 t& i% K$ v! R; p' O& {! y9 ]
BEG_ITEM 66 (1 CTOL 5005) = 15  !  ' q7 V- F# G0 D
BEG_ITEM 69 (1 BOOL 5005) = 0  ! Random Color Display+ K! M( ~& U3 U7 Z
BEG_ITEM 70 (0 RADI 5005) = 0  ! Faces
' I' a' ^! A1 z) y; g BEG_ITEM 74 (1 CTOL 5005) = 15  !
( J) {% X+ Z! S9 i( u  ^9 g BEG_ITEM 76 (1 CTOL 5005) = 130  !  $ e1 S( ^% M  b4 w
BEG_ITEM 78 (1 CTOL 5005) = 42  !
4 B+ F; R6 \6 i7 r9 h/ B& d7 G BEG_ITEM 82 (1 BOOL 5005) = 1  ! Monochrome Display8 z1 w2 A& l( m: t0 H, P/ `
BEG_ITEM 83 (1 CTOL 5005) = 145  !  2 \  a* k5 l8 }9 M: u+ p: @4 c0 w
BEG_ITEM 85 (1 CTOL 5005) = 186  !  ! I: k3 M( d: y3 `/ V  o
BEG_ITEM 87 (1 CTOL 5005) = 216  !
7 K& [2 h" h# c BEG_ITEM 89 (1 CTOL 5005) = 7  !
& w! C5 u$ \9 W5 o BEG_ITEM 91 (1 BOOL 5005) = 1  ! Show Widths
* h- O$ W6 d( K1 z1 v; o BEG_ITEM 95 (1 TOOL 5005) = -1  !  8 T: f  a* c9 d2 p1 ~
BEG_ITEM 96 (1 BOOL 5005) = 0  ! Add to Quick Palette# q9 _7 m; P: S) b1 T
BEG_ITEM 98 (0 BOOL 5005) = 0  ! Override
' R+ u' q9 O! |" ?) A7 f BEG_ITEM 105 (1 INTE 5005) = -1  ! Color ID
! c5 P. h# I" t/ \0 i! J BEG_ITEM 106 (1 STRN 5005) = " "  ! Label
* J- x( I% n" R) H6 S BEG_ITEM 108 (1 BLO  5005) = -1  !    N4 i  m3 C2 x9 l$ w1 U7 e- Y
BEG_ITEM 113 (1 BOOL 5005) = 0  ! Front Clipping
; V: N& W1 {( C0 t( h2 D( Z  a0 { BEG_ITEM 114 (1 REAL 5005) = 0.0000000000000000  ! Distance7 Z3 t  J+ U9 m% Z7 x9 U1 s
BEG_ITEM 115 (1 BOOL 5005) = 0  ! Back Clipping: [  O* j2 g0 _' l) d$ p  j1 B
BEG_ITEM 116 (1 REAL 5005) = 0.0000000000000000  ! Distance1 _  m/ f; B# g. p  q( o
BEG_ITEM 119 (1 BOOL 5005) = 0  ! Perspective. s1 M3 W' c. ]& ^2 i; R
BEG_ITEM 120 (1 REAL 5005) = 0.0000000000000000  ! Distance
& D& r$ A4 U7 s/ ]: f% s BEG_ITEM 128 (1 RADI 5005) = 0  ! Off3 Q7 L3 a( n( T
BEG_ITEM 129 (1 REAL 5005) = 3.1750000000000000  ! Character Size3 n7 R! _3 p% e) @9 X
BEG_ITEM 131 (1 BOOL 5005) = 1  ! Show Model View Names1 _# F* X5 l* }) b8 O$ [/ q, Q: \
BEG_ITEM 132 (1 BOOL 5005) = 1  ! Show Model View Borders( y1 b- h7 V6 f# {) O0 j7 U
BEG_ITEM 137 (1 RADI 5005) = 0  ! Hardware" x' v6 c* `0 h  \4 A0 A. O7 `" t
BEG_ITEM 138 (0 REAL 5005) = 1.0000000000000000  ! Dash Size
: y4 O+ r! c" m! } BEG_ITEM 139 (0 REAL 5005) = 1.0000000000000000  ! Space Size' O" M) V3 \; j$ I7 W+ |( a! y; A
BEG_ITEM 140 (0 REAL 5005) = 1.0000000000000000  ! Symbol Size
' {# E6 m: K4 r, W3 l! Z5 o6 D BEG_ITEM 141 (1 REAL 5005) = 0.0050000000000000  ! Curve Tolerance
9 z* R+ d3 r. \& R9 Y  { BEG_ITEM 142 (1 BOOL 5005) = 0  ! Show Widths! J  N7 j9 U$ Q& X% `* q
BEG_ITEM 145 (1 BOOL 5005) = 0  ! Depth Sorted Wireframe
) u. E9 E8 W& _ BEG_ITEM 152 (1 BOOL 5005) = 0  ! Fog
# \  O$ ~4 v% t! |- M) {: p, m BEG_ITEM 159 (1 SCAL 5005) = 100  !  * O) T& K  B, V. g
EVENT VALUE_CHANGED -50 5005, 82, 0, 0! Monochrome Display
1 p( |7 h# s' ~! g ASK_ITEM 82 (1 BOOL 5005) = 0  ! Monochrome Display  _" Q! V7 v3 L' ?
OK -50 5005 ! OK Callback
, b+ |9 B6 J1 A6 H
3 ]. t- S$ ~$ r4 L- p) ^( R[ 本帖最后由 konkon742 于 2008-12-14 11:54 编辑 ]
e_draf.rar
6.67 KB, 下载次数: 2
