楼主 |
发表于 2008-12-16 09:13:02
来自: 中国广东阳江
GibbsCAM 2009 v9.x - Lz0
2 }2 n6 [+ g5 z0 K3 T3 h) Q------------------ u9 o/ C5 p. f' S
1. Install Gibbs 2009 with 'No Hardware Key' option, S; a w! W; x2 P7 [/ f# H6 q8 y
2. After installation, open the install folder one level up (e.g. C:\Program Files\Gibbs), and make a folder RLMServer.3 \0 h2 Y( h0 A0 W7 ?/ v
3. Now go into install folder (e.g. C:\Program Files\Gibbs\GibbsCAM\9.0.1(w)) and run RegistrationTool.exe
8 e: ~& ]9 }; T5 [4. select Network License Server, make sure the install path is correct
' l) F9 i: e( M$ V$ N- p8 W5. Click in the install path editbox and press Enter
5 N. k- n* E! l% Q p6. After installing the RLM Server, coppy gibbsnet.exe and gibbsnet.lic to the RLMServer folder, overwriting gibbsnet.exe
2 ^) m1 U$ z6 A# a" @7. (Optional) Open the gibbsnet.lic and change the port 2765 to something else.& M; z9 l: H7 C
8. Create an environment variable GIBBSNET_LICENSE and set its value to 2765@localhost (NB: if you changed the port earlier, change it here a well).: a# H+ w1 M: b& A( q" q
9. Run rlm.exe (NOTE: You must have rlm running before running the app always!)3 ~) z9 @' n6 ]! g/ X1 o
10. Start GibbsCAM3 B5 }( H) S3 A& U) L6 ]
11. It will say you don't have a license. Drag 0b.lic onto the reg tool, it will be happy
0 H: }9 n7 O$ g" l' H9 R# c12. Enjoy!7 B% C! r' [3 ~' l$ m( g
7 V- D; p- j. y9 }( r$ A6 Q/ G% y( ~
NOTE: As stated in step 9, rlm must be running for the app to run.
9 ?: a+ d- w/ N' ^8 A
4 f9 `" l; K5 F; `这个是GibbsCAM.2009.v9.0.5安装方法,望可以帮我译成中文,谢谢! |
