发表于 2008-12-25 13:06:42
来自: 中国辽宁大连
我现在也碰到楼主的问题,不知如何解决,请高手帮帮忙,谢谢' W1 h3 a& W& o: B2 e- _. F
7 {8 w M6 S; ~- g; F, H“C\DOCUME~1\admini~1\locals~1\temp\autocad 2006setup.log以获取详细信息。 % k; g9 q3 u4 {1 E9 A' f9 Z) b Q
”, l) o' i% s' r9 v$ `, X; A1 E
是:
4 A' z) B% U/ T( q
" o# _) b% r- a% V* x2008/12/25:12:32:20 a LIANGXIA-81E2B1 === Installation started on LIANGXIA-81E2B1 by a ===" n% x6 E: h4 @
2008/12/25:12:32:22 a LIANGXIA-81E2B1 Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4001.5512
& C# P7 E6 L u2008/12/25:12:32:22 a LIANGXIA-81E2B1 Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
5 K, w' V/ S, N+ s$ R+ A2008/12/25:12:34:03 a LIANGXIA-81E2B1 Install .NET Framework Runtime 2.0 Language Pack Succeeded Command = "D:\AutoCAD 2007 CHS 简体中文版\acadFeui\support\dotnetfx\chs\langpack.exe" /q:a /c:"install.exe /qb"; `3 a G% c! c4 T. B
2008/12/25:12:34:03 a LIANGXIA-81E2B1 Install DirectX 9.0 Runtime Failed Failure is ignored, Result=3
7 I- T( T! X' X% k- `' V) n2008/12/25:12:34:05 a LIANGXIA-81E2B1 Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1132.01 q3 V g' ~7 [" p
2008/12/25:12:34:05 a LIANGXIA-81E2B1 Install Autodesk DWF Viewer Failed Failure is ignored, Result=3
4 _) d5 W/ E' s( y* F w2008/12/25:12:34:05 a LIANGXIA-81E2B1 Install Flash Failed Failure is ignored, Result=3; s" M- L) e) M. k( T
2008/12/25:12:44:38 a LIANGXIA-81E2B1 Install AutoCAD 2007 Failed Installation aborted, Result=16035 z8 I, E( v6 T y6 e
2008/12/25:12:44:38 a LIANGXIA-81E2B1 === Installation ended === |
