查看: 1647|回复: 1
[求助] 紧急求助 涂层
发表于 2009-1-13 11:50:57 | 显示全部楼层 |阅读模式 来自: 美国
找一种涂层。
6 Y7 ]; _% X$ S) x我主要的目的是:
& e- p* D/ }, w8 r% w大摩擦力; (想在汽车挡风玻璃旁边放手机的胶垫一样的作用)
  K/ i4 D7 H- i( p: W- p& c( \缓冲带弹性;(硬的东西比如矿泉水瓶盖从10MM高度掉在表面上不要弹其过高)
, B, b/ a1 l: l+ K' U2 I* W无毒;(最好是食品级的) . o0 s$ k5 \4 v: d! ?& W% }
# q- m" m5 o8 W9 g
附上说明书(是国外的,我翻译的不是十分正确)
4 J0 @/ Y* j% }) s3 {' ?# L' C3 X" u6 u7 C: e  s9 b" K
5 e. @0 g: o! l: S  p, z/ F  \
TECHNICAL DATASHEET1 |% F/ f) C( A9 ~) v# }
技术说明书
  i5 }) B* G9 n, n9 S
/ _( e5 f( v9 d6 S  z
PRODUCT:* a: f# }$ M* A* a4 N
. ], n7 p. v- X, k8 |4 c" @产品名称:
" E+ R1 N7 M4 r1 O$ B, h4 y7 F2 B) l- |, Q% d
ACCOSIL P292
# o  \( I5 c3 G6 ~3 N& a0 w
3 C7 g4 ?& N! _. a, Z1 {1 LACCOSIL P2924 b: T# M3 D8 t; s- {
$ ~& g7 B0 P* w6 [/ k
4 z4 N8 w2 ]0 Z4 G- k. r3 l' C- t
) U: o% O! R3 [
DESCRIPTION:" H8 {2 j: N  z8 n4 K; K% Y0 M& n
4 @9 I6 e7 X! \* `5 N& `描述:
4 J1 d# S7 c6 ]2 y( j- o. `# r0 q1 o; g& S- U& y
ACCOSIL P292 is a soft, rubbery silicone coating. 2 F9 D4 v; M. `4 Z7 L
( q! h2 c2 I# Y" d
ACCOSIL P292 是一种柔软的有弹性的硅胶涂层。
) w7 A; L' v2 K) e5 K& p" H
3 H& O$ E+ `# g! ?" i# C' t. b$ v) u! b- M8 I$ s) w4 n8 R6 X
) C% y6 O$ s9 n4 U9 j+ O5 K
APPLICATION:! k2 R( i0 _$ r' |4 O! ?8 U
$ r' M, Y9 ~3 C: d3 _* p
1 `, Y7 q6 [; u& ~8 q- `; C
/ o9 {3 h' v. [0 m
( @3 i2 g/ D# W8 ?; \" x( E- g) [3 F! s0 \" a2 ], \
  I3 L: }7 K6 P$ y4 F! j
3 y  _: f5 a7 u, r: E6 {5 ~# X5 h* }* a1 h2 I, {% q3 s) g1 g' Y
3 _% v/ b  ~! r9 e9 C: y+ J
3 z/ E: n7 _% C8 @" {3 C
: ?* T, @( |3 }5 t+ C0 u. m
. k5 E8 z4 V+ [  `7 N8 e1 F& p1 ?5 c
$ U7 F* N+ M; T! O. e  N1 s. e6 [. B0 [5 ~* s! s$ C
) ^5 [2 ]0 t2 p, n  p, v6 g6 l% `0 F3 U8 Y6 X0 @& f: M
+ h2 b$ F0 o% o7 X% [
应用:9 }% U6 R0 E3 B# u; c! C% T6 A
! b6 f0 J* r' e8 c! w) N
ACCOSIL P292 is applied on items to obtain the highest possible non-stick-effect especially in connection with very adhesive substances such as tape, dough etc. The very high friction is also very applicable to drawing rollers, for example. Is also applied for baking trays or other equipment being in contact with foodstuffs.
/ _' T* _% h, G3 c9 {: k: ~- R  {+ E
/ g& ^9 b. M: k" FCombined with Accowear the coating will emerge with a surface more rugged, very wear-resisting and scratch-proof. 9 q4 a$ H% U/ Z; @  Y1 J2 Y2 @
! U8 C5 F: v( F- \
0 V6 S$ A6 h  D$ z. d1 r$ r
  U# N1 ?, X( E9 C# h) jACCOSILP292 是一种非常优良的“不沾”材料,更可以应用在有粘合力的表面。优良的性能也非常适合用于胶辊。也可以用于烧烤盘等接触食物的表面。
# C6 g- A+ i% M0 {) ?, b7 A* J( N/ L. u6 a
结合ACCOWEAR 工艺,涂层将呈现更加粗糙、耐磨、耐刮。
; t' o! P9 A) t1 E2 X+ ^0 z( z5 {5 G" f0 i+ ~- J
) U0 v& q! r/ z3 n  q9 ?$ m9 x% u; y1 y
COLOUR:$ i2 o* _3 V' R4 C
& u, W- y/ X# c6 U2 V颜色:
  Z1 E0 H5 _+ L* O" U5 r+ L- D- k. l( D$ ^
& b3 [$ @/ @) a8 j
! N7 e2 L3 S+ J3 N# v: h
Reddish brown, shining- N& M) P! C! t6 O( u+ Q
2 h2 {. D6 \$ f4 y
棕红色,亮光, s2 n2 B: Q2 u8 [
: M" X8 o$ ~3 x7 F3 L4 f2 i
$ c- }6 i+ U  |; W  S5 b5 @4 c
7 B. s9 o% o& ^0 v1 I* s% p2 p
LAYER THICKNESS:) U# r$ m  C+ G' G
. z, Y6 i3 t) l涂层厚度:
# d' S9 |7 v/ D* b
8 E. j8 E  l- A- a( w
Ca. 50-100µm
/ n( |: I' S7 G" u6 Y# n
8 x+ i( x/ [; \1 Y! u# |Ca.50-100 µm$ g; m" b! C7 L% S9 s
5 X! z+ e( {2 L" ]
0 I; S! |/ Q4 J4 {$ d) B; v! {( p% s6 s8 ]6 @* P9 ~+ n
TEMPERATURE RANGE:
# Y3 f% g' ?1 C% v
5 e6 A8 O4 g+ b: B耐温:# [7 P! m4 @; w, E
5 x3 X, p- n3 R7 a+ O8 \! ~
& \' B5 `- N" U1 v- i  N$ p- N. _1 v2 `: B% A2 B3 o4 q# |9 {! N
50°C - 250°C continuous3 T5 Y" H9 ]" c7 y+ {/ [0 ~, ?
, f" z/ i* B# y
50-250
# K! p* T, m9 G& a1 c. l
! ^$ a  c+ b* i3 Q8 ^5 {
! Q. v4 s. g; x' F
2 H+ z2 k; x0 v, h# e9 M; VNON-STICK EFFECT:
) O1 f( G8 t. E  v, }! M$ g) f1 E4 t$ j
不沾性
7 @' n6 A* C: B- S! `; g' i( E
; V: h0 v" o6 z; }
2 I" ?3 N2 ~6 S1 p) W
% B% ?7 t9 U. N( z3 W) KExtremely good, ]9 [3 {$ @$ C+ b' u
# e0 N( M8 G5 y  d( O: ~及其优良9 ]8 B) Y- M6 u* c  O6 y+ l6 S6 K4 J
- ~) o; T6 G' L) i5 O  H3 p: O) R, v7 g7 E, e2 f& ]: ]
6 s/ `( F+ c5 B9 q; E+ K
& x, S3 e$ d. d2 U, ^2 P. o8 F9 f: S9 N/ r& o. @4 @
COEFFICIENT OF FRICTION:
) S, [- D& ~& `% I; z8 S  l. {2 N  z: W$ H3 n, p, Y1 T
摩擦系数( l' ?" T9 _, `7 _* d4 L
( E6 Z. t3 M( c) d* u9 y0 }) f- x
9 E( C1 I$ s5 ?" D* M; I8 Z
: n0 n1 c' z9 MHigh friction
% t( _1 Y3 s$ ?% o# R
3 r6 _" G  z/ j. u% y3 E/ u, h* c& o% M' _: t+ y8 w7 ?
+ [9 P3 X. G/ Z* C
非常高
3 ^  o! h3 d; J: A" p% x5 ]3 u5 [0 U* N" }
* d. B9 a: T4 _/ L4 e% C5 p& r! G+ N9 l0 t5 f, q+ k+ N$ I; A
WEAR RESISTANCE:, I( b  v9 Y  b( j5 a
) r7 F# E4 O5 a' ^# n
3 m8 o# e& F) |
7 r6 ^. p) g' r0 j  z
& _/ j* f  B6 e' M3 R# c0 G; F0 a3 q
% H  ^$ d1 A! q9 f2 E! @, d& R( A1 w
9 m1 k2 i5 o/ S+ D+ N
! E9 e% I3 `# W3 l+ q( O3 @0 i- P涂层强度:
( G: L7 t- w/ i1 T  g, U
- m. j1 d' [7 R" U5 a
: \! F/ z; l- ]
3 C' T4 n+ T# {4 d: z' a& \
) F' S; i2 Z3 l) A& M" `+ t; s# z) n$ ~; E: K! s
4 m& V  e2 N/ ~2 D4 P3 m( a
- k# p8 X3 I3 [, A
# W/ q+ P3 J+ O- }/ b* B
- }. g* h4 T, x. |Reasonable (dependent on type of wear). Can be reinforced  with Accowear to make the coating more scratch-proof and  wear resistant. 2 {* B6 z/ R- V! Y
3 W& X4 J8 O& H1 r; y
8 p! O! d- e% U4 f9 y' j
3 u) C% i) H. _  z1 ?9 \  y% g7 \
可调(按照型号)。可以用Accowear 加固,达到抗磨耐刮效果。9 t' s" r% ?, V8 W* g" a
& A  s' O5 K0 j% E$ x% X$ \
CORROSION PROPERTIES:
% S0 D4 {: u6 Q/ y6 h7 i
6 U! ]7 v* }; m, v腐蚀性:% `& R: R, G* E% h2 X
  O7 ?4 y6 E) k( e
. h7 T( c* I: Y1 X" f2 o
0 |# g5 L( c+ ZA non corrosive coating
1 X3 C5 ^, \) F" ]  l
3 T- p0 {0 S" y7 o# r无腐蚀性' J3 `2 V( N' T% m. v, D' O
" y2 f) E* N6 W( D* U; E) k: [5 S
) _- x# E* B( I" ?7 \4 t1 v" Y% e/ |; w
CONTACT WITH FOODSTUFFS:3 b; S* m$ ~0 v' ?& T: W+ y2 g  f
# P7 G6 a6 u5 p; Q1 y' M
食品接触安全级别:# c  v; p$ u0 Q
5 A; `* f5 Q0 S5 u
4 `$ O( `" _) @) q8 I( Q$ l$ k( m4 Z( v1 H: {
BGA approved XV: Silicone
4 Y5 B! [2 M2 h% @8 _* Y! V
& {# m  W. f/ K- [7 P) D  D
8 d5 n: @7 Y/ h5 V2 R" f! n, [
- k4 a6 n0 S" U8 ~. wBAG认证,硅胶
! O# O! X7 p2 L
9 J( p! D' L# S9 b
9 I2 d7 B8 w: q; c; g% B* S2 ]3 r1 I" y9 S) U; \2 W( V: h
SUBSTRATES:9 Z+ ]) m, O# V2 p5 M1 f) j
# Q! \6 E/ `) H- f适用基体
, y; r; F* E) Y7 q
2 T8 }) z$ p& V/ I
7 j# I" q4 c3 g4 w: t5 S
( x+ K7 H% P. x6 KSteel, stainless steel, aluminium, plastic etc.
( U, E; k" E( X/ K( u
: g8 q' Y2 z9 u7 O钢材,不锈钢,铝合金,塑料等。
0 w. D. |# P9 a  w
9 o2 T; ?. c/ P
2 M% m( D% L* U
9 z" u" D% o  M$ n7 N& HLIMITATIONS:
* D5 f+ L* A2 t9 L+ h; m' S; ^, O1 r7 ?2 ^
缺陷:! e5 J' }6 i( w% X, F
& \; D4 b  z+ y( Y
) ^. n# k3 x0 v" W0 G/ E
4 F* F1 A# m9 x( ~3 x$ c2 {; T2 uSharp tools and mechanical wear to be avoided.
: h  t3 n' m2 A5 ?0 `. l/ u" o4 J8 p; I% `# N
避免尖锐物品刮割。  r8 |8 {- l7 K
8 ^  f6 v6 C9 h/ ?- z  @' M  W) v$ h. x' a4 n0 |
% W. X7 ?; R+ C; ^( n
/ o" a3 A# d7 `" l. R3 VPACKAGING:4 B) K8 r2 O4 j. Y' x
/ u$ Y4 f3 H7 t  N- k4 E包装要求:( a$ o% ]) F% u' x4 e0 H7 ~
2 y$ T& l  l  ]  `# O+ v* C
3 d& [% E$ x: S
! m( {1 o2 E5 j" S6 q  X
To be packed carefully avoid destruction of the coating
* \1 ^0 j4 z2 ]3 K+ c, i
" @* ~$ T0 N2 H$ H; D小心包装,以免磕碰。
  j4 o: f) d4 X# M# I5 h
9 D# n3 y% Z8 v* t8 |, R- M
发表于 2009-1-20 08:19:37 | 显示全部楼层 来自: 中国福建泉州
使用硅胶涂层就可以了,你可以找一下类似手机的那种硅胶套的材质!表面磨擦力很大,又很有弹性!
