查看: 2962|回复: 0
[公告] Drafting Introduce
发表于 2009-1-31 14:18:24 | 显示全部楼层 |阅读模式 来自: 中国上海
Easy To Use   b/ ]- Q6 G7 F0 ]: K# g8 K
“A user has to be productive in a couple of hours”, this is what our users want. We did it, thanks to a software fully Windows compliant to improve productivity and performances. Drafting drives the user to his target, thanks to compact menus, intuitive icons, smart contextual menus and adaptive selection lists. Features like Drag&Drop can be extensively used to create or modify geometry, virtually eliminating user explicit interaction with menus, widely increasing productivity. Drafting can be customized at various levels of deepness. The user can configure contextual menus and keyword shortcuts, for instance, to adapt Drafting behavior to his own preferences, thus speeding personal productivity and reaching faster the wanted results.
2 ]- ?) Z% G( a7 u7 A
5 B3 @7 N# b, n' t
5 H: a) h* d2 T2 h) V
Full 2D Function, T' t$ h, w+ P7 \, t, |
Drafting is built on thirty years of think3’s experience helping European mechanical companies to reach their market faster and with the right products. More than 25,000 users already rely on think3 technologies and Drafting has been built around their requirements to provide one of the faster, more complete and more reliable 2D CAD system available on the market. Using Drafting you will be able to draw any type of 2D entities, organize those using groups or layers, organize product structure and create detailed drawing or large layout as well. Drafting offers a suite of dedicated features to help engineers creating or modifying large drawings representing very complex products.
* r8 \. R( r3 q6 g5 b. o6 ?7 F
Value to your history  b( }4 A7 ^2 A# C
We know that legacy data represents an inestimable value for any manufacturing company. Drafting is fully compatible with the most used 2D formats, like DWG/DXF, IGES, e2, draftmaker, and can save DXF/DWG without any limitation up to AutoCAD format.DXF/DWG is easily loaded because Drafting shares with AutoCAD many concepts and processes like layers, text format, x-hatch, dimension style and text style. Moreover, AutoCAD blocks are displayed in Draftingas groups, letting the user to benefit from Drafting’s optimized group management. 2 J" T" F" }) g) a$ H2 ]
( F/ f1 T; F& A
6 ?8 \- ^; ]2 e, J5 V1 \
3 N' o+ A( i* H# Y* [# a) Y4 ~
Smart Objects and Adaptive Measures 9 V( N( h1 r& a" h
Unique to Drafting, Smart Objects allow users to capture, reuse and share all of (or part of) a design. The benefits are greater consistency with company standards, less errors, and faster design cycles. Adaptive Measures introduce a breakthrough, intuitive approach to designing parts within the context of the assembly. When inserting or editing features, users can input values directly from the surrounding geometry with a simple mouse click. Adaptive Measures will adapt to model changes driving the features that incorporate them and preserving the design intent. This makes top-down part and assembly design faster and less error-prone than today's raditional, manual methods. With Adaptive Measures users can quickly create reventive drawing cleanup is virtually eliminated.
