3天前
查看: 1236|回复: 3
[求助] 请问这是一种什么类型的调压器?
发表于 2009-2-1 09:56:27 | 显示全部楼层 |阅读模式 来自: 中国香港
在UL 144中写到activated by the regulator linkage mechanism请问这是一种什么类型的调压器?
: L( [" H& d2 S6 U7 r/ L! |, x( ^
1 U; a- @! Q' N$ B27.2 One sample is to be subjected to 100,000 cycles of complete opening and closing of the valve.' U  B) l$ h; Q' M9 u: ^: ~7 @
When the construction incorporates an overpressure shutoff device that is in accordance with 14.1(b) and
& j1 B, s/ w+ I; E! L# |that is activated by the regulator linkage mechanism, the sample is to be subjected to the number of
5 i, H+ O8 [* a2 m. L. \9 ucycles and test conditions covered in 27.6. When the construction utilizes nonmetallic materials in the2 v7 z0 @/ o7 {6 l; Y$ Z$ W/ s
linkage assembly a second sample is to be subjected to the test conditions specified in 27.5.
发表于 2009-2-1 12:35:07 | 显示全部楼层 来自: 中国河南南阳
请把你的图传上来,这样写言之无物。
发表于 2009-2-1 15:34:26 | 显示全部楼层 来自: 中国河南新乡
不太明白,推测是不是一种手动设置压力的溢流阀
 楼主| 发表于 2009-2-1 22:13:58 | 显示全部楼层 来自: 中国浙江嘉兴
没有图片。。。这是卖到北美的调压器必须遵守的标准,这是该标准对循环耐久实验的描述,规定了一种特殊类型的调压器需进行高低温实验
- U- ~( n% C; @/ I7 W  q从字面上看应该是一种金属连接的二级调压器。。。但是如果这样不是又与一体式二级调压器冲突?
