发表于 2009-2-6 11:14:08
来自: 中国天津
􀂉 COSMOSFloWorks Standard. COSMOSFloWorks Standard offers fundamental fluid
: P$ z5 k, y ~4 eflow analysis capabilities such as internal and external steady state flow,+ g$ A5 I! h+ T
incompressible liquid and compressible gas flow, mixing of multiple fluids, heat
& _/ a$ s1 ~! e9 ttransfer in solids, porous media, time-dependent analyses, gravitational effects, fans,+ g. N# d. e, }3 n. ?
volume sources, wall roughness, and advanced capabilities such as particle tracking,
0 l. ?9 l- C l" i, B* ?and animation. Full user control over the mesh and solver controls are also available.
$ s; t$ a' w2 b0 Y# g4 D􀂉 COSMOSFloWorks PE. COSMOSFloWorks PE offers the same ease of use as
2 N! A4 C5 s1 Z$ }, @8 l$ o+ o# ECOSMOSFloWorks Standard but with additional physics such as non-Newtonian and1 b* y9 z) x. `& q
compressible liquids, surface-to-surface and solar radiation, as well as advanced
! l' E% z2 w4 B) ~- Emodeling capabilities such as rotating reference frames, heat transfer in solids only,
6 q% g, [5 B9 mand the transferring of results from one calculation to be used as the boundary1 C6 j, b f* F: ~* v, f
conditions for another calculation. Features related to COSMOSFloWorks PE are
7 |% t" `& z: ^) F i5 `highlighted with (PE ONLY) marker. Topics fully related to COSMOSFloWorks PE
8 f: p' }) {9 B, G4 jare highlighted with marker.
& i1 Q; `/ O: ]$ ], A- \􀂉 Compatibility. The COSMOSFloWorks projects saved with the different versions are( C2 v* W# P7 ]) D. z+ y
compatible to each other version, backward and forward. For backward compatibility
. Y. n7 ~" m+ A% u(e.g. opening an existing COSMOSFloWorks project created with PE version within
1 K' G! [3 n* N% L5 n8 Ythe Standard version) a conversion dialog appears asking confirmation to convert to
}+ a$ U- Y' O( Z( U# V* Pthe "lower" version and to remove possible existing input data for functionality which
( k# y6 m( P6 `+ }is not available in this "lower" version. All modifications made during the conversion. L/ B- t; P1 b% x
process are saved as a conversion protocol file in the working directory. The results6 Z% E* D: L: c! H( t% {
remain completely compatible among the versions, so the existing result files created: |! a/ ~0 F! l2 {2 W- r: L
with PE version can be loaded with Standard version.0 }0 B I% ]& ]2 Z$ x
5 ?- R+ ]! N# F- m! T# g看看吧~~ 感觉用PE就是了 |
