6 |) F4 w: C+ ^4 O( ?. D
5 l% W. A' F# l2 q _, O8 o" `
$ W* @- {% i P. A1 e‘--------------------------------------------------------------------源代码& R# I+ n" P: P5 e8 F' H$ b
Private Sub Command1_Click()
4 s9 a; N5 k: X! o% e3 V, `Dim A As Long7 n! M' C! C9 l
ps.StoreData "SELECTION.NUMBER"
9 c# E( A8 q: N! X+ i& GIf ps.StoredData = 0 Then. s: L( `5 w0 A- a: p$ Y& n
MsgBox "未选取投影所需物件,请再次选取!", vbCritical, "错误"! }! N, t- p7 X9 c" M' J9 m
Exit Sub
7 t+ S* p, c @: pEnd If. G4 P0 z: O8 X/ b' j
If Combo1.Text = "NO" Then
6 s; ~! r5 h) Tps.Execute "PRINCIPALPLANE XY"+ W O5 ?; k7 h3 z+ k ]6 W
ps.Execute "create curve PROJECT"
$ [7 }6 H0 T% M% O% y4 i/ G! Xps.Execute "THRU"
# @! H& Q1 g) \8 k" T: ?/ rps.Execute "ACCEPT"
W4 s7 c( [8 i7 Qps.Execute "select clearlist"# U4 E) u) }2 @5 `: }
ps.Execute "add Workplane 'XSH'" y% A6 K+ i7 f5 a( c
ps.Execute "Delete"
" M+ b1 M% Z5 V6 i7 E! F2 X! DEnd
, S/ x5 P4 O, t$ C& U$ Y! v8 bElseIf Combo1.Text = "YES" Then
$ T8 ^& S9 ?" i Q* |. _ps.Execute "PRINCIPALPLANE XY": H! \4 \8 a1 q" t, T; k8 E
ps.Execute "create curve PROJECT"3 F" ?5 R9 q7 T* i
ps.Execute "THRU"
* r* d$ O3 L. [ xps.Execute "ACCEPT"$ j% f% G, {' ?- j
End
, Z5 [- w0 j: a8 O8 ?3 f$ [End If
/ o0 @& E$ G7 |8 G0 a4 oEnd Sub1 ^$ V* ~& K( x6 Z0 `+ Z! n, T
Private Sub Command2_Click()8 G8 h/ K1 c0 T- e; V/ X# p
2 Y+ A0 t) x9 h* T6 I. p ps.Execute "MODIFY"/ J8 g, L | y5 z
ps.Execute "VIEWALIGN"
. d4 y& D( k0 U: ^3 v ps.Execute "ACCEPT"5 G" S* I, }: T O: {+ f1 y" u
ps.Execute "SELECT CLEARLIST"
8 n: D$ ^* F J# h$ Q) R' G# VEnd Sub( i! K& B B4 j! D" j" q: W
Private Sub Command3_Click()
5 |- Q2 ^% r& Z" yps.Execute "add Workplane 'XSH'"" V' S+ J. W: d" k3 X9 p
ps.Execute "Delete"# g) U" X. F% F% k7 g! w
End
% q2 F+ q, I/ L; X* u j! ~& xEnd Sub
" {: ?+ K" \- ^2 KPrivate Sub Form_Load() 'This EVENT PROCEDURE occurs when the form is first loaded.* I% h' L( T' J! i( y x4 l
Dim ActiveIndex As Long
8 M5 ?! W3 v/ [ d7 H8 b: E) TDim NoOfWorkplanes As Integer2 e* k3 ]& l6 d' g/ O- E
ps.Connect
6 y! L) G( _3 W' s# sIf ps.Connected = False Then
) q1 t0 B6 `" s: U; g* t MsgBox "请打开PowerSHAPE!", vbCritical, "连接错误!"+ N4 d. y$ y9 i8 {1 g9 o
Else& D& ~/ \. S: h0 b6 P+ H6 P
ps.Execute "create workplane"8 f6 _; p- ^% h t/ L' ]$ H
ps.Execute "SINGLE"
; a# m. M- X# T7 a1 @! u ps.Execute "0 0 0"
% F3 D# f7 H+ @5 ~! f; J( D ps.Execute "ACTIVATE_WORKPLANE XSH", u$ G( P' E; {7 p- M( R
ps.Execute "MODIFY"1 P' A0 A# e' ~3 P3 Q
ps.Execute "VIEWALIGN". u8 t8 h% K0 v) W
ps.Execute "ACCEPT"
" s( ~ k* I7 q. t& |4 ` ps.Execute "SELECT CLEARLIST"! z7 ^7 D; k3 [! u, h v
End If* W# Z8 o! N4 a9 e
Combo1.AddItem "NO"8 ^4 Q: j) ~* F+ M% X8 u
Combo1.AddItem "YES"" u1 b+ v9 V" |' @- i3 p
End sub- d0 A& m7 s# E3 T: }) {6 |8 {
# T. a; f. N( N. ~& w; L1 Z+ y2 {
[ 本帖最后由 xsh2003 于 2009-2-8 18:51 编辑 ] |
