10天前
查看: 1925|回复: 2
[已解决] 版主请进。。如何转变坐标?使两个两个图处在同一面上?
发表于 2009-2-10 14:19:41 | 显示全部楼层 |阅读模式 来自: 中国福建福州
弯曲的那个是椅子的靠背。。。直的是椅子腿* p% T" p' u1 r
9 h( e! r! C" c" L7 M, e
如何转变让椅子腿接在靠背上。。- i) f: [& o# {  E% p1 K7 B
5 r2 t9 j  R, {. ]& q. ~说下如何转变坐标系就行。。不用认真接。。谢谢& D* G! q3 K6 q
# r7 A. u, P) l; r* r, J1 M
( {. H6 _9 W6 A  I9 ?, H2 V6 `下面是代码。。+ q9 n% j. B) w8 \  M" i. t+ J/ H$ \( g
8 w+ R. u! A& G3 p. X: x2 t
Sub A()
6 B. u: R# f9 ?    Dim PL(0) As AcadLWPolyline, Ps(11) As Double
' y2 \/ }8 s; u9 S    . p+ U0 A7 h* O$ t5 w9 v. N
    Dim R1 As Variant
. x* L, R1 J5 P6 v) N
) `, n2 A3 T: n& z1 }+ A$ I
+ j% Z5 f1 i- h    Dim S1 As Acad3DSolid
, ~9 P0 \' d- Z- ~* L( n- W
' t7 ]2 N) J4 O* {* m ) O$ _' t! F2 `( k" j9 c
     With ThisDrawing
7 n1 }0 C4 b5 V1 g    + b2 {( v1 `# E. I% X! V
/ x! P- b8 g' X         '定义优化多段线的顶点坐标% o+ u! K. Y3 `* @4 |# }4 T  s
        Ps(0) = 0: Ps(1) = 01 Z8 ?! d2 F9 j8 Q
        Ps(2) = 2: Ps(3) = 0
! m1 b9 ]5 H; d1 B7 \( ]        $ T3 s6 I" y5 w7 Q/ I
        Ps(4) = -3: Ps(5) = 169 Q' p: Z: h8 ^: T. V  L6 I) [8 ?- ~
3 w% o5 s  ~: Q        Ps(6) = -15: Ps(7) = 40/ J4 g& i/ F7 b$ K! [* \
        Ps(8) = -17: Ps(9) = 40* w% B. g2 L2 m, f( g- l2 v
* }: W; i" b5 m5 H6 h( i+ Q        Ps(10) = -5: Ps(11) = 16
! `) c2 v2 c6 y4 a0 H
6 R) S6 U6 z1 q. n      5 I: J! ]( o, Z1 Z3 A
5 D6 P! L+ a4 j+ r) P        '创建优化多段线& }/ Q5 D, i5 ]7 a  O$ g, f& v# z
        Set PL(0) = .ModelSpace.AddLightWeightPolyline(Ps)
) m0 \5 ?9 }! w, d, X
0 x: F2 d( q( S6 n3 r3 k) L1 M4 R" I        '多段线闭合0 ^  x9 d8 w5 v  L6 V# ?
        PL(0).Closed = True0 M- Y- I& S9 Y, A2 M: a
0 s( R9 v5 Q& z- C5 n# B$ q; Y; |6 {        R1 = .ModelSpace.AddRegion(PL)
, W7 i7 p7 B4 k( i" g        + Q  V8 ]  ]6 _0 Z/ S
        & J" V" n( n) Y  M
        '靠背- ~6 t# \+ N$ @8 g
        ( |: a0 C  u7 B. m8 ?
        Set S1 = .ModelSpace.AddExtrudedSolid(R1(0), 2, 0)
5 V# u0 r; o8 E& v- e
: M# L7 b2 J1 ]. U3 h      ( f8 `. s$ k. @" {% `+ H( @
      '椅子腿
; U- ?- d9 B( h$ {' ^$ J
/ I" a" [3 ?! I4 T, u8 d        Dim boxobj1 As Acad3DSolid
3 A, t& Z2 N* l% z5 h) G% L       9 @$ d" q  D* u: b
        Dim length As Double, width As Double, height As Double. b2 s! S& C( l; \2 d  n7 {0 s; s: A  q
       Dim center1(2) As Double
. _; l: z( b' x8 j" r- |. Y$ f      . b# w! I6 H9 H2 s4 \
/ M% E/ X8 d/ |! H( _8 F
+ G+ [0 `/ t9 i/ Y8 j7 N' ~$ n
      center1(0) = Sqr(2): center1(1) = 10: center1(2) = Sqr(2)
5 q; \# o$ A$ z( R+ l  G. x      length = 2: width = 2: height = 20
; G: X2 s* ]% W  r, C      Set boxobj1 = ThisDrawing.ModelSpace.AddBox(center1, length, width, height)8 V$ N+ R  h3 ^6 M$ ]' H9 A# G$ Q
) ?8 L9 E) v- T% v. MEnd With
; J. ~: A# c4 I2 k/ g( \8 ?) G' d- e% T/ a! v& G
End Sub
 楼主| 发表于 2009-2-10 14:44:38 | 显示全部楼层 来自: 中国福建福州
如何让靠背按照原先的坐标轴画
) {7 `* b$ a6 {+ n- h2 T2 @
8 {# S$ E" [3 ]7 }" D+ z; G然后椅子腿按照另外一个坐标轴画呢?
 楼主| 发表于 2009-2-10 16:01:35 | 显示全部楼层 来自: 中国福建福州
好像解决了~~
