查看: 1263|回复: 1
[分享] 焊接专业焊接英汉词典
发表于 2009-2-17 13:54:33 | 显示全部楼层 |阅读模式 来自: 日本
actual weld-throat thick-ness焊缝厚度# ~$ S9 r5 g" C
all-around weld整周焊缝 all-around weld (整周焊缝)环焊缝
) F/ W& A! O/ `( Kangle butt weld斜对接焊( ^' Z* n# k% {
angle weld角焊
- j* }% B$ m* u4 J+ l5 m1 Lappearance of weld焊缝成形
. _2 f( E$ t3 q& ~; c/ \) y' Farc-seam weld电弧缝焊+ `; J; }( [( ~+ X/ d+ Q
arc-spot weld电弧点焊
  S. K) A4 i2 P/ [" Z: J+ T! x* Rarc-weld电弧焊0 h' p9 q8 [3 J# V, \$ X# r
aspect ratio of weld焊缝成形系数1 V# t1 I: q2 k$ _. H2 k
at weld edge在焊缝边上& e3 g1 l/ Y' {; ?3 y3 d
attachment weld连接焊缝6 z* l1 C) x2 Y% ~7 `" S
automatic spot weld自动点焊法
- Q2 {$ T+ T+ q1 v+ V' T0 V( Aautomatic weld自动焊接
  _* u% }9 A0 d$ H* u5 ^3 ^# eaxis of a weld焊缝中心线; 焊接轴线
' A, o7 S9 a5 x! }* Yaxis of weld焊缝轴线; 焊接轴线5 ~; n6 B7 Q7 a3 ^) q3 C4 N
back of weld焊缝背面) t& W! t  ^4 G. h% v3 @
backing groove of weld焊缝反面坡口
% s% _* e4 _% J" y0 v- }backing weld底焊; 底焊焊缝
& M- ^% O+ ]* E* C  f1 _bare metal arc weld裸焊条电弧焊! V5 l/ ]' H2 ?4 p# J, P; q
bead weld珠焊; 堆焊
- H6 z: }6 a4 N6 W5 E3 Sbead-on-plate weld堆焊焊缝
+ P+ W5 h: _3 t8 c- mbeading weld凸焊
1 V2 U% a' i! E. m' ?) gbeam-to-beam weld梁间焊接; 梁式引线焊接+ Q. r* ]9 |8 b* ^( e' |3 V, t
block sequence weld分段多层焊4 T5 P9 _6 C9 r, _# z- k' j1 V: e9 E
bond weld钢轨接头焊接* @$ x+ j3 b2 B/ v( A8 M- a
bridge seam weld桥缝焊接; 桥线焊
& P' C& e4 G) e3 K- }0 @! _1 x% ?brize weld硬焊
/ m' A, Y0 E+ ]& `; e) Sbutt weld对接焊缝
7 H" F( h, \$ M7 R2 v& vbutt weld ends对头焊接端$ g& _; C* P! I3 t- p; b
butt-weld碰焊; 平式焊接; 对头焊接
' {( H5 B/ J7 S) p" q. Hbutt-weld in the downhand position对接平焊+ J$ }$ w$ m* E- |" Z5 }, H
butt-weld joint对头焊接
4 ^$ t: Y; `" {( M6 L+ rbutt-weld pipe mill对焊管轧机  q; {- u1 A  C
button spot weld按电钮点焊
7 h. M- a& p' jcap weld最后焊层; 盖面焊缝
! l$ ]6 b. f9 N) n0 w1 t( O/ T, p* Hcarbon content of weld materials焊接材料的碳含量1 S9 |, K( U. R2 N
cast-weld construction铸焊结构6 i, v! r  X* _9 o, B
caulk weld填缝焊3 ~. \8 Y5 Z5 |1 g
caulking weld密实焊缝: @. S: u, h6 K$ e7 S6 X. a3 k3 O
chain intermittent fillet weld链式分段角焊; 并列间断角焊缝
. \; m+ W$ E, Jchain intermittent weld并列焊接
2 s; v" X+ W, F9 G5 c9 n) Ocircular weld环形焊缝
% j) ~$ {2 M$ K% Z+ l( acircumferential weld环缝; 环焊缝$ O0 l$ q; }( p" I5 o5 F
cleft weld裂口焊
( ?2 H1 A3 [0 ]+ k2 A4 n8 bclosed weld底边无缝焊; 无间隙焊缝# i8 |# K0 R' W. q' R7 U
closed-chamber fusion weld闭室熔焊0 S, \. Q+ `4 f1 L
cluster weld丛聚焊缝6 }" u* V1 f& E. P* U  J/ }& l3 B
coil weld卷板对接焊; 卷板对接焊; 板卷焊: S6 I5 a! Q6 ]7 U+ b8 H; f" I+ s
cold weld冷压接
/ M& y6 T! s) r- V* lcommutator-controlled weld换向控制焊接" u& q6 L+ E6 x& g$ U4 @  {! f3 V# O
complete penetration butt weld贯穿对焊% x# g  O9 @: o
composite weld紧密焊缝; 强度密封焊缝: W, w  t  g, D
concave filled weld凹形角焊缝5 E* c1 C( Z& q3 H9 O* a
concave filler weld凹角焊' c+ }1 c- A- e, @3 p
concave fillet weld凹面填角焊
0 V" b7 X$ W8 ?# oconcave weld凹焊缝; 凹面焊; 凹形焊缝; 轻型焊0 ^/ U+ `( B4 `; B
connective weld联系焊缝
4 |' y+ B; t# Vcontinuous butt-weld mill连续式炉焊管机组
* ]9 @0 g* l* o3 `, Z/ c$ mcontinuous fillet weld连续(填)角焊缝; 连续角焊缝; 连续贴角焊
( A' Q: G; [7 |: @' |& b5 lcontinuous weld连续焊缝
" E0 B) r% J, ~3 ycontinuous weld process连续式炉焊管法% F1 i6 I$ F% H* ?
contour weld特形焊接6 a; T$ {, m- J& u4 }: N* B
convex fillet weld凸角焊缝; 凸形角焊缝
8 e( L7 l8 l! n& ^( o# Gconvex weld凸焊缝; 凸形焊缝4 e- A  ~( b# N6 x% m% W
copper weld wire包铜钢丝
$ K3 x' W& t; N: {/ A/ Acorner flange weld单卷边角焊缝: X# B  X4 s- T5 j- L: N
corner weld角焊9 t0 i1 d3 E$ h! U$ {- e1 o' z
corner-flange weld卷边角焊缝; 卷边角焊缝. \; \4 B% @7 v* G
crack of weld焊部裂纹
8 `$ s. T, G! }; Y! wcross weld十字交叉焊缝; 横向焊缝) b5 y. L( _9 J1 y
cross-wire weld十字焊
# w0 v, z) b& N0 @5 [crotch weld楔接锻接; 楔接焊接
. H6 v. g; s$ c3 F3 Acup weld带盖板焊缝. `% A, t. a  K$ }# m4 t- k5 o3 R
depth of weld焊接深度
: |+ f; X0 V5 z+ Ndissimilar weld metal不同的焊接金属; 不同金属的焊接9 O7 f2 t7 K3 A
distance between the toes of a weld焊缝宽度
- @, |# p- Q& ~4 g% r/ Edouble groove weld双面坡口焊缝/ i9 l! v0 S6 c
double-bevel groove weld双斜边坡口焊缝; 双斜坡口焊( j& K2 k  k/ ?4 t
double-flanged butt weld双弯边对接焊缝7 V4 Z( \- k# \) _+ e, n1 t! x) S
double-V groove weld双斜边坡口焊缝; 双斜坡口焊
8 U) b# I5 r/ |- S( A3 C" A; Udownhand weld平焊缝$ k. d; d. u0 Q
duplex spot weld双点点焊接头
! L& [) Q8 h, P4 j! _! Cedge joint weld边缘焊
4 p7 U# q% M- a& E/ l2 a) z3 J  dedge weld端接焊; 端接焊缝; 端面焊缝; 对边焊
* z! n  \0 Z6 ?% m8 y: J$ {electric resistance weld mill电阻焊管机* {$ N, f5 O6 y' j- t
electric weld-pipe mill电焊管机
5 M  H, l- y% d; P( }electric-weld pipe mill电焊管机
1 I) e( m- u, I; ~# _emporary weld临时点定焊缝
* L; J, f$ r. W3 a5 e- o0 X% Dexcess weld metal焊缝补强金属; 补强; 补强焊料; 补强金属* }/ W! T5 w/ O
excess weld metal(焊缝的)余高
( r1 ^) F) d4 H& A. jexplosive weld爆炸焊接8 H+ P! S' h! h( l8 ~6 W
face of weld焊缝表面; 焊接面
+ n: W! r+ Q+ y6 _fibrous weld纤维状焊缝
4 _# k4 L5 V& zfield weld现场焊接0 ^% N, _( h/ }) {' B8 t
filler weld填角焊缝
( M0 z9 N0 w5 x% yfillet weld角焊缝; 填角焊; 贴角焊
# F7 e3 l$ j6 Y0 ufillet weld in normal shear (搭接接头的)正面角焊缝
! Y& ]$ d* @& |5 ]# Ifillet weld in parallel shear侧面角焊缝; 侧面填角焊0 S0 |3 ^+ d% m; q6 v2 m0 g/ T/ y* b
fillet weld in the flat position角接平焊; 水平角焊缝
发表于 2009-2-18 19:51:46 | 显示全部楼层 来自: 中国上海
楼主辛苦了,能很方便的查询。谢谢了!
