fillet weld in the horizontal position横向角焊缝
! H* d5 F* e4 }fillet weld size焊角尺寸; 填角焊缝尺寸* [, u4 e' k; H% ^& f8 s b$ h
flame weld火焰焊接
* D4 b, B0 L$ l: v3 E3 Gflange weld卷边焊缝; 卷边焊缝/ L3 @# R9 K9 C% g+ T
flange-to-web weld卷边焊缝; 卷边焊缝) n. z( p$ l1 E& W4 K
flanged butt weld弯边对接焊
" a2 e: o# P" F" W! uflanged edge weld卷边焊; 卷边焊+ `3 N8 s" r) s4 l, q* n5 Q
flash butt weld闪光焊
& g1 w9 G4 c+ W2 `flash weld闪速对焊! D6 y! `+ \- T
flat faced fillet weld平顶角焊缝焊接
& r2 [4 V5 K! ?! D7 u4 \flat fillet weld平角焊" r/ y. n$ ~( f: {1 i
ing of fillet weld角焊缝平焊; 船形角焊4 D- B9 g' \; V% E! Q
flush fillet weld平角焊
6 x1 ]! J+ M+ O3 K9 f8 X7 Bflush weld削平补强的焊缝; 平焊接; 无加强高的焊缝
8 r) m; ? g) K* Q! b# B8 Aforge weld锻焊焊缝
+ A1 l( z+ C3 ?- U# m; wforged weld (焊后锻压的)锻压焊缝: e2 `8 M9 B7 v; K8 `( S: s: @
form factor of the weld焊缝成形系数
9 T9 B9 b- ?: o% `9 Xformation of weld焊缝成形
1 E* \* f4 Q4 l( ufront fillet weld正侧面填角焊缝; 正面填角焊
+ e. [& z0 F# a9 yfront(al) fillet weld正面角焊缝! Z! B$ A, F) N8 F
full fillet weld满角焊缝; 全角焊
+ X/ n; R7 B; hfull penetration butt weld满对接焊
+ P7 R6 k8 }. B8 r5 q( e( W- E( Pfull weld满焊( M3 t$ a/ d4 P% d2 ]
full-fillet weld满角焊+ W+ Y' U7 P1 H/ N' {7 u7 F
full-sized weld全尺寸焊缝
2 N) R# a" ?! xfull-strength weld (与母材等强)等强焊缝5 N+ U% V3 g, T# l+ m' S7 @
gap weld特殊点焊; 双极单点焊
3 C1 i# G4 A5 u8 i; c1 agas-pressure weld气压焊# N* _$ c9 ?. f Q
girth weld环形焊缝
8 m; b N' S" rgravity weld倚焊( p( N& r! G7 C5 \
groove weld坡口焊; 坡口焊缝; 有坡口焊缝; 凹槽焊
" d' w2 T2 x; c9 jgroove-weld joint有坡口焊接接头
9 b! L& d/ K) P2 p0 z3 Ihammer weld锻焊+ Y P3 c; o; @& M! Z% b
hand weld手焊焊缝) y$ I) H, b, H2 K8 s6 i* N; ?$ S
height of reinforcement of weld加强焊缝高度
( W4 b. }( p! n4 ?6 dhelical-weld pipe螺旋焊管4 X' d8 O+ a$ I5 E+ V+ m9 D
high performance weld flux高性能焊剂( H: t0 {, Y0 |: @0 X G3 Z
horizontal fillet weld横向角缝焊接" J/ ?& \! G2 D. y' F) q
horizontal weld横向焊缝
5 Q; A/ F% ^) dhorizontal-vertical fillet weld横向垂直角焊缝1 K7 h c1 z) j) {3 B* s; \
hot weld encapsulation热焊封袋
" l6 p& T4 ~' @* v: s+ y- Qhydraulic automatic weld液压自动焊接
. V s1 Y) w9 Xhydraulic weld process液压焊接法8 g% k0 S2 {9 o" H& @+ `
inclined weld斜焊
0 Z0 x$ |, ?$ v/ Y% o7 qinconel weld单面焊缝
' }4 g" {5 N1 _& V$ i( t2 e" Qincorrect weld profile焊缝形状不对8 O% b$ } C2 X' K2 s* \
incorrect weld size焊缝尺寸不对# }. J W5 \! M1 W: R$ W
induction weld mill感应焊管机
6 r* k$ w& w& ?3 Vinside corner weld内角焊接8 [. }7 O2 Y& U$ R
inside fillet weld内角焊接, R1 e+ c6 q& G/ b
inside weld内焊缝
0 ^) v9 }' U3 ~( [insufficient or excess reinforcement of weld加强焊缝不足或过量
' C* b* ~; e8 M pintermittent fillet weld间断角缝焊接; 断续角焊缝6 w' C! W) c" I1 L
intermittent weld断续焊; 断续焊缝$ O, u3 f, `' g/ `
jam weld对接焊; 对头焊接
# M% ]5 C% ?" Llap fillet weld搭接角焊缝
6 p# Z& w% y M" `laser (beam) weld (ing)激光焊
* E- j: Y3 A5 d. t" x1 r7 jlateral weld侧焊; 侧面焊缝* @; y1 `9 f7 t7 D* ^! f+ i7 S3 O
leg of a fillet weld角焊缝; 角焊缝焊脚9 N4 R ] I6 O% M+ a
leg of fillet weld圆角焊肉厚) o* e. S! q+ Z& F+ j" q' @2 L5 ~
length of weld焊缝长度
4 q4 J/ Z, Q- P. N o6 ^7 M3 flight closing weld轻连续焊接1 I; P- V3 c5 W8 p# d
light fillet weld轻型填角焊; 小填角焊
4 e# M4 f& ^/ b' xlight weld轻焊缝
& L- }5 S. ^; T# pLincoln weld埋弧自动焊 Q/ q6 k# [/ b/ \0 ~- E- j5 m. r
longitudinal fillet weld纵向角焊
; q0 T, G0 O) ]5 B( \- W1 r$ blongitudinal weld纵向焊缝
) [+ [9 ]) P8 r9 d! [longitudinal weld (焊接用语)纵缝0 W+ |; N1 i5 Q0 ^& ]. T
loose weld脱焊
* H& f+ _/ b! V/ ^8 ^/ Q1 m0 K4 emain weld主焊缝
; S1 ?/ a0 U5 `1 B2 q( u3 tmash seam weld压薄缝焊; 滚压焊3 i) V e0 \# w6 D8 q( A( Y w
mash weld点焊; 点压焊
& U& D3 x/ Z( L5 Y3 K; E$ nmelt thru weld熔透焊缝: u8 E8 {/ ]3 y
melt-through weld透溶焊
2 ~5 G& p2 O% _$ ^6 Y" Dmelten weld pool焊接熔池
: Q3 q! h1 b. dmelting through weld熔透焊缝: M. a( M* P/ g/ e) j
miter weld平顶角焊缝; 斜接角焊缝
% _4 b7 [3 p5 \molten weld metal熔融焊接金属8 }$ A( H7 I |$ c' ?( K
mulitple impulse weld多脉冲焊缝% e4 M/ j) z h3 V
multilayer weld多层焊缝- z8 z/ ^: B4 A; g3 I& S6 p" r
multipass weld多道焊缝& a9 T( e' X+ D; K( p0 n
multiple arc weld多弧焊缝0 N, j- _: S3 ~4 r( W
multiple-electrode submerged arc weld多电极埋弧焊
0 d( A3 s. v3 p4 o, X! umultiple-pass weld多道焊缝; 多路焊接2 |& J& n/ }* m8 }
multirun weld多道焊缝
4 `/ f4 c! ?; O9 Rnonpressure thermit weld不加压热剂焊缝. U* H( T6 y2 c$ G
normal weld正常焊接
8 f# r: Z a& X! ~ Moblique fillet weld斜交角焊缝; 斜角焊接
5 a n* ?' a9 `* wone-pass weld单层焊缝7 M: ?9 M/ N- G9 ?9 `7 c
open butt weld开口对接焊
. d! V4 f4 C2 E4 a& Kopen weld留间隙焊缝; 空隙焊4 T& K/ N. N9 d! B0 b. ~& \; u% d: `' P
outside weld外焊缝
3 u1 r! \- R& u1 n( _over weld过焊1 X9 i8 S; s3 Q3 n
overhead fillet weld仰焊角焊缝
( }" _$ q6 D7 v t- V+ Doverhead weld仰焊2 A1 M4 ]; g6 ~! u' Y+ T5 H
oversize weld超尺寸焊缝
; u- `) D8 ]0 {$ q- V1 ?% @6 hoxygen weld氧气焊接, d, q% Z; c+ \# |$ N
parallel-arc weld并列弧焊
$ B7 r/ |6 P3 N# g% v# qpatch weld补焊; 补孔焊缝
- `) N2 F4 o2 O) ] g# n% Q9 dPeltier's cross weld珀耳帖交叉焊接6 ?4 [) r l( ~) I% S
penetration weld熔透焊缝: j, D- V8 f, z) ^6 z* A
percussion weld冲击焊缝; 冲击焊接
% V1 q/ k( |2 w9 k w+ G) l9 xperiphera weld环形焊缝
5 Z8 i# q# ^4 {pitch of weld焊缝接距; 焊线距7 u8 a3 j3 l2 c- ]/ n4 U! @4 ]% W7 o: t, [
plain butt weld无坡口对接焊; 平头对接焊缝2 n* a9 x) ~8 q; J! i: k
plasma-arc weld等离子弧焊接
8 K- {" l: y; t( x& |, \' z ?plug weld塞焊焊缝
4 B. X" Z4 e& E8 B- Y9 x/ T3 y3 ipoint of weld焊接点+ w7 s# }* _ n/ n: N+ ^
point weld点焊
) b8 a5 |$ \+ r" k2 a/ Z5 hpoor weld劣质焊缝; 有缺陷的焊缝
7 F0 Z5 q- N1 i+ v( K+ S8 kporous weld多孔焊缝; 疏松焊缝# T& g. q7 m+ b# u- U
positioned weld平位焊缝; 暂焊3 b: M7 w# O- U& N, a1 O1 {
post weld annealed (PWA)焊后退火! I | ^9 m; E$ o5 n
poured weld铸焊焊缝7 k+ i' D/ w$ r1 t4 l+ Q
powder weld process粉末焊接法* t' I0 ?9 h: e% G3 s
practice weld试验焊缝
" L2 N5 e; a: L/ P5 Apressure weld压焊6 x' F/ P& V% A
pressure-controlled weld压力控制焊接8 U+ j+ L( r( f/ f, y
pressure-tight weld气密焊; 密封焊道) Z; F' ~8 e* U9 Z( I6 l: x
principal weld主要焊缝
+ y7 P/ Z( f9 E! m" `! wprofile of fillet weld填角焊缝轮廓/ o- c c% j" c9 Y& G
progress of weld焊向' H; L0 n e% G% {; ~5 f* I- t
projection weld凸焊; 凸焊焊缝
) j- r" n, A6 n: }( A! v. _' Lprojection weld machine凸点电阻焊机/ n% [" I2 {+ E
pulsating weld脉冲接触焊8 z7 C; h/ E$ L
push weld挤焊( R9 q* Q* m' T q E
quilting weld钉焊
7 ^7 c$ x L2 Greinforced butt weld补强的对接焊缝; 补强式对接焊缝
9 J8 N; }2 G. ~8 M) preinforced weld加强焊接% J* m0 l+ V6 m! ?! }# M: \
reinforcement of weld焊缝加厚; 补强金属; 加强焊缝- P* a2 T( e- T& B$ R4 J
resistance weld mill电阻焊管机
0 e- [4 n6 w! d0 }resistance weld pipe电阻焊管
) B% I; z8 J& tresonance butt weld谐振式对接焊# s4 u' t1 M: o- j1 v% z
restarting a weld再引弧4 c* l# R6 I/ [2 z. s
ripple weld鳞状焊缝- ~% Z- i8 {( j
rivet weld电铆; 电铆焊缝2 z4 B; c9 I* n. O; ~# O
root face of weld焊缝根部钝边1 }9 V% A. `& M+ a2 i' o ^
root gap of weld焊缝根部间隙
4 N' g7 ~* P) \4 Kroot of weld焊缝根部; 焊根$ K+ s$ z# }0 r: v: V. ?" v% t# d
root opening of weld焊缝根部间隙
$ L6 r: h( \, y Y* Eroot radius of weld焊缝坡口根部半径
' [+ A- N8 s* P/ F+ ~sagged weld下垂焊缝6 h% Z7 b6 `1 `( ^ c. S. H
scarf weld楔口焊接
1 @3 C o. q% B! ~0 Fseal weld填焊; 致密焊缝; 密封焊; 密封焊道; 密封焊缝
/ U3 V* a3 W9 b( [$ }sealing weld封焊( J( B" {/ q( R: M7 J
seam weld滚焊; b3 Q. ~: m6 r. i2 `6 x
semi-automatic arc weld半自动电弧焊
' i+ T# t4 ?. Q' E# ]- q6 isequence weld timer序列焊接时间调节器1 X9 O! r" J8 q7 I& m
shallow weld浅焊
$ b1 Q1 x0 ^4 n" _: C# S2 Oshop weld工厂焊接" P; S, H+ h: O0 w6 C
shot weld点焊
$ C. c( A( ?- p' ?' E9 pshoulder of weld焊缝根部钝边3 `# ]2 T! L3 B
side fillet weld侧面角焊缝; 侧面填角焊缝; 侧面贴角焊
" b% E" z, y: Q8 B) ]3 C: ]side lap weld侧边搭接焊; 弯边搭焊缝
: o1 u/ [: y; k( S! Y! jside weld侧焊缝; 边焊
5 k, B1 H) l8 ?+ `: a3 |single lap weld单搭接焊
7 E) N+ r7 Y" S4 x+ `" Rsingle strap butt weld单面盖板对接焊
; j: O2 j8 e, J: P6 z" G: k0 Zsingle-bevel groove weld单斜角槽焊
6 P" p% t) S: x4 V# }: K. l# b J! bsingle-fillet weld单边角接焊缝
* T+ \2 G, H8 k/ asingle-pass weld单道焊 j. {: V; D0 e% a" Y# c; r+ H' U
site weld现场焊接; 安装焊; 安装焊接: \) K7 R: G |3 u
size of a fillet weld焊角尺寸
0 j8 z1 D8 [4 @5 f/ \4 Vsize of weld焊件的大小; 焊区尺寸
/ P8 h3 ?; {. m- u7 d' Wskew weld斜焊3 Y8 n: p- h9 D$ i U! N8 K) M
skin weld表面焊接
+ G% _; I" U4 G# u! j" E; D; |sleeve weld套筒焊接
# N5 a; M) V# j' e2 E8 T2 Hslip-weld hanger卡瓦焊接套管挂
+ d5 J& u% F+ z/ Mslot weld槽塞焊; 长孔焊; 开槽搭焊缝; 切口焊缝
* G: F- f* I! t! K# e0 I4 K6 xing slotted weld槽焊+ L( b' R2 N0 H7 I" f
slotted lap weld切口搭接焊
* }: T# x" ]) j0 f5 h4 {& x0 P2 i$ Dsmooth fillet weld平填角焊缝 q$ g3 W( Y; r+ k& A) N3 d4 W
socket weld ends承插焊接端7 R- v" o( d$ L* G' _
soft-weld铜镍焊条合金1 Z9 q( X, z2 t+ R' v
solvent weld溶剂焊接* X8 R* x- J" U, O0 U3 i
space of intermittent weld断续焊缝间距; 断续焊间距
' `% E9 U0 m/ x. ~spiral weld螺旋形焊缝
@* {" {- {; ]7 c4 i6 P$ F3 hspiral weld-pipe mill螺旋焊管机
* Y! S* g& r# m) {9 h) }2 Xspot weld焊点- X* M, W( x/ d+ b- @
spot weld bonding胶结点焊' P6 l# O# ^% \) B/ @! r
spot weld nugget点焊熔核" N7 _0 y& s5 L: @
spreading weld宽缝焊接; 加宽的焊缝, F! X6 n# K; @6 q6 X$ p
square butt weld平头对接焊缝
% {6 S$ P% D+ f+ Z& y) U Rsquare groove weld无坡口槽焊
% b/ U1 n# Z. ^$ z& `/ A) m/ tstaggered intermittent fillet weld (ing)交错断续角焊- O/ j0 K9 x1 h1 L s& ]0 ~6 G8 [
staggered intermittent weld交错断续焊缝; 交错间断焊
2 U. J: _# d# k8 ] ^5 C+ d9 }! cstaggered plug weld交错塞焊
, U0 C; S3 ]( Astandard reinforced fillet weld标准加强角焊缝
* m# q {# _7 ^# G! r$ Sstick-out weld未熔合点焊接头2 L, ^# {; j7 i/ T
stitch-and-seam weld点线焊8 G+ }. O9 }3 h
straight butt weld无坡口对接接头! U3 {% [$ j4 D$ Q/ M
strapped weld搭板对接焊缝
: o. O" H# r5 i" \6 qstrength weld受载焊缝; 强固焊接; 承载焊缝; 高强度焊接
6 V, H2 @3 N4 h! m: zstructural weld强固焊缝
% t# C% x8 J, m2 E1 b1 P' L) {surface of weld焊缝表面- L1 V- s2 S" N8 \* Z0 j
surface weld表面焊缝) H/ s7 C/ p* E- E% ?* G& r T
surface weld metal buildup表面焊缝金属的形成6 ]8 O0 c6 {3 D
synthetic apparatus for weld thermal cycle焊接热循环模拟装置6 ~1 h5 L8 D* e2 C4 q
T weld丁字接头焊缝; q& k& ~" K" u) c5 J# g
T-filled weld丁字形角焊
P; D3 [6 y O( A7 eT-fillet weld丁字接头角焊缝. h- r) m/ f: c& |
tack weld定位焊点; 定位焊缝; 临时点焊; 预焊; 平头焊接
; s c) x% p1 J% ?+ ~8 \, g0 q* Y! y; S(welding)定位焊
7 d7 ]( x8 q0 Z& Z2 otandem arc weld前后弧焊) J1 y7 b% C, f+ e1 w5 s. ~
temporary weld临时点固焊缝+ m6 C) I7 e1 I( Y: n% }
tension weld受拉焊缝! G9 K. ]; i! I. u
test weld试焊4 W+ X& c- r0 H3 k/ {0 Q
throat depth (thickness) of fillet weld角焊缝厚度5 X: J8 H O- i8 M+ x0 ^- a
throat of fillet weld凹角焊喉; 填角焊缝喉长- p1 z+ p1 N8 r1 l5 m2 B
throat of weld凹角焊喉! Q4 U8 s2 `+ a9 s. U6 n
tight weld密封焊接; 致密焊缝4 U2 ^7 K* o4 W) r
tight-strong weld密实强固焊缝, ?. n+ ]/ e9 r9 J( J, B" l2 e+ }
toe of the weld焊缝边界
4 M9 }2 ^; T/ D' Ftoe of weld焊趾
! S; u! h7 G4 ?- n# Z- t$ p4 qtoe weld趾部焊缝
3 h, u2 r- v6 U- G; t/ c" Ntorch weld气焊焊缝# x! @% C9 [6 {* t
total amount of weld fumes焊接发尘量5 s! N. F. \% E" ^: I4 d4 [! w4 [4 l
transverse fillet weld横向角焊缝; 正面角焊* h* S) |" S4 }4 d8 d) J
transverse weld横向焊缝" u. J3 i1 a K% |. L1 ^
trial weld试验焊接
' N* H, p0 s$ y+ b/ k! Tundercut weld底切焊接( O( V) Z/ J) _. g7 i
undressed weld (增加焊缝)未加工焊缝3 d. i% M4 f8 L1 d8 g! H0 a
unequal fillet weld焊脚不等的角焊缝1 p2 ~# y# z: @; _0 J% f
unfitness of butt weld焊缝对口错边量' h3 z% f8 P' p; A
union-melt weld埋弧焊# z% }% T7 ?& z6 u1 m
unload weld非承载焊缝
5 q8 V/ N8 o: s0 _4 N w# Punspaced butted weld无间隙对接焊缝
# ~9 ?7 `3 v" s/ J/ I" {/ ?upgrading of boiler weld锅炉焊缝加强2 P9 ?. ] z A8 C6 C
vertical fillet weld立焊角焊缝+ D9 I' o: b1 { g6 l5 a7 K
vertical weld立焊
1 M3 U& N0 y" jweak weld不强固焊缝9 ?- }. `* x1 s9 }2 l4 u4 v8 ^
weaving weld横向摆动焊缝
) i9 V% O! ~& D7 Oweld焊; 焊接的; 补焊3 F' E; v5 X* }& w3 J
weld all around围焊
; x) Z- D+ D/ N$ ]# xweld appearance焊缝外观6 y; ^+ y) H5 V. f: q% c) i
weld assembly焊接组件
- _' b1 B' p) Vweld back-up焊缝背垫5 d8 Q0 {, K$ p" S9 q" {0 C. J
weld backing焊缝衬垫
0 m& r, ]) V! f+ W1 g2 w, Sweld bead焊缝; 熔敷焊道( b3 N! O/ _% C
weld bead height焊缝高度! @, B3 V+ {2 R6 O
weld beading焊瘤
9 h$ e& n) ]) ?! Y3 {" e) K/ `weld bond熔合线: q p4 A* S( @2 a
weld bridge seam搭桥焊缝; 桥接焊缝
. Q1 e- j1 J3 fweld cap焊帽
% b2 t- B( S* Z Nweld center line焊缝中心线
9 U, v! T, l6 Gweld collar加强焊缝焊瘤
. e9 U. M. Z& {weld crack焊接裂纹- L; c: z8 R7 R; w
weld crater熔池3 ^8 |3 ^" A% a2 l8 A
weld crosswise交叉焊接
5 b _" H( ^2 l C i( D* gweld decay焊缝腐蚀; 焊接接头晶间腐蚀; 焊接侵蚀; 焊接区晶间腐蚀
/ R7 R/ M6 S+ j; L! D& dweld decay (焊接后)敏化区腐蚀
3 q# B( I5 E( y' Zweld defect焊接缺陷
: L) p Y% N0 S) [weld delay time焊接延迟时间0 l k) c6 b/ x6 P: C( \
weld deposit堆焊
; p, _+ p0 o7 [+ R& a+ Dweld deposits cleaning焊接熔敷金属清理
2 L' J1 R* t& k: N I2 ]1 b! Tweld edge焊缝边缘; 焊缝表面边缘
& u* Q* o: H5 n* ^, Lweld edgewise沿边焊接
0 H6 Q2 ~( _+ n$ \! \1 Tweld flange connection焊接法兰连接
9 Q$ `7 ^% Q$ t5 Gweld flash焊瘤7 ]& t6 K- a% s# f' k) ~2 Z1 l$ S
weld flaw焊接缺陷
& [9 E+ L O/ o- P; H u/ ^weld flush焊缝隆起6 k+ J5 `+ I# [
weld fumes焊接烟尘
+ d- S# `9 u0 q# ? h1 |weld gage焊缝检查规; 焊缝卡规' J) k4 p+ D1 q) }0 X# v4 e
weld gauge焊缝量规0 e" M* o- i+ [, g2 I) A2 X
weld heat input焊接热输入; 焊接线能量& {! b, b1 C$ a p
weld holder焊接夹持架; 焊接架- k9 i) u- U3 u" J: k2 ]# D5 u4 m
weld inspection焊缝质量检验; 焊接检查; C" K7 J4 a, P/ b, }; L" P
weld interface焊缝界面; 焊接界面
+ v9 Z! g4 [6 z- U. @weld interval焊接时间1 z% }: o1 \0 {# Y7 a0 x. `
weld is accepted焊缝合格
3 ^- C ~$ B3 ?/ i6 w7 o2 [# }6 Wweld jig焊接夹具
3 W0 \% W ]3 V, ]7 O0 z# t: Kweld joint焊缝
* P6 ]2 y3 g: D2 s. O4 b0 Iweld junction熔焊线; 熔合线1 i ?! s) S) C- N
weld layer焊接层
5 y9 s7 q% k, ^' ]( {# m7 Jweld length焊缝长度. F5 {, o" \; F q4 M9 t
weld line焊缝线; 焊缝轴线; 焊接线; 焊线0 W! s; X9 s4 y4 G( _5 [+ c* \. o. @
weld machined flush削平补强的焊缝9 _( G9 S( k. {- n& V+ ^/ ~
weld mark焊缝符号; 焊缝记号; 焊接痕; 熔缝
, H5 n; T e7 |7 Lweld mesh crate焊接网格
/ ^! }$ `, W0 d: C; ^! \weld metal焊缝金属; 焊接金属% `! ?3 m" F" R' ~; X: o I8 \
weld metal buildup surface金属堆焊表面
$ m! E; R7 T: W" N# Jweld metal composition焊接金属组成3 ^" K1 j7 W j3 I' c( d; G5 B
weld metal cracking焊缝裂纹
: R6 y6 E3 y* I; a9 Eweld metal zone焊缝金属区; 焊接金属熔化区$ |5 v* u2 p4 o: s: I
weld nugget焊点熔核
- O9 H% i6 o. q# V" pweld on bottom底焊
' b& O4 H/ G! n5 f: rweld overlap重叠区* B# s, c# d. [. q% [
weld pass焊接通道. R M+ `" _! S$ G4 E) U) J
weld penetration焊缝熔深; 焊透深度
4 h! n3 T v: ~# ~9 Aweld period焊接时间5 P: N5 E. T1 c+ e. z+ h
weld pitch焊缝距$ S0 ?* E$ a9 l; X2 \) r
weld porosity焊缝气孔
$ e+ I `) v. s5 sweld preheating焊前预热: ?. {3 K3 ]" D _7 Y5 a' b( O
weld preparation焊缝坡口加工, R, X9 G4 M4 `
weld puddle熔池
) q. Y9 W" o' C- a- @. i" Gweld reinforcement焊缝补强; 焊缝加强; 焊接补强6 G |" K2 ?, ?/ J M# r
weld repairs焊接修补4 W1 S6 ^- m e
weld ripple焊缝波纹$ i$ P, |) M* |
weld root焊件剖口; 焊接根
* B5 h5 a5 @# d* g0 w+ {weld root opening gap焊缝根部间隙
7 C* c5 e/ C9 Q6 \4 W& yweld root reinforcement焊缝反面加强
* K( [' W6 H( m- |; x* `weld rotation焊缝转角4 s" w/ ]5 b. ^* ^$ H
weld seam pipe焊缝管, ]: F" D- _: v- D
weld shape焊缝形状
' K0 H8 l9 O$ ^& [- jweld shielding焊接区保护; 焊接熔池保护2 D% W( n1 j6 h: F; [
weld slope焊缝倾角
7 B( d1 B: }" `! s7 l- d* W; Jweld spacing焊点距; 焊缝间距1 s5 y/ e1 h4 w3 Y
weld strain焊接应变
# B# j: A2 a6 m* r) Oweld strength焊接强度
: [+ H+ a# p; W+ r& q( iweld surface焊缝表面) R I& W8 U- @
weld swell焊缝隆起
5 N, ^; N& A. v) Kweld thermal cycle焊接热循环
( }" h+ C9 i4 _weld thickness焊缝厚度0 r9 s. V3 L( j
weld time焊接时间; 焊接通电时间; 接触焊通电时间9 C( E, t5 u" W* p' x% u. R
weld toxic gases焊接有害气体, [$ {( g0 n- `1 Y3 O9 j
weld trimmer焊缝清理机: N9 d2 N* o8 z$ n) V3 A' ?* g6 C
weld up焊补
7 D5 i+ r& ?4 s, h$ _2 K; Eweld wheel conditioner焊轮调节器+ a$ k2 D: i; P/ O: G
weld width焊缝宽度
6 M$ a9 m( q* H* y% bweld wire包铜钢丝2 O* H- O" c6 \# i3 Q& z) W4 F! O' U
weld zone焊缝区; 焊接区" P L5 g& S" }% h' ^
weld-form factor焊缝形状系数
7 X, H2 R N: W) E" Aweld-fusion line焊缝熔合线
: S2 W1 d8 [& b/ zweld-in nozzle焊入式喷嘴 N; @4 V* q& |; Y1 \% E9 @2 a3 u9 x
weld-interval timer焊接间隔记时器
3 l$ p6 w9 h2 [weld-shrunk cylinder包扎式圆筒0 N3 `; z6 v3 w' K
weld-shrunk multilayered cylinder包扎式多层圆筒; 多层包扎式圆筒
" `; |! S+ I$ f8 [: l7 mweld-throat thickness depth焊缝厚度
) d, m9 H+ ^- W5 wwindow type restraint weld cracking test窗口拘束焊缝抗裂试验; 窗形拘束抗裂试验
. S% k, u V) \! K" o: j; Yzigzag intermittent fillet weld锯齿形断续角焊缝; 锯齿形断续角焊缝
) ]* j. v" q$ y7 ^zone of weld焊缝表面 |
