楼主 |
发表于 2009-6-5 18:29:18
来自: 中国广东江门
先建立一坐标系,再运行以下宏即可自动分中。(参考别人的)- m2 q1 h9 H* S6 V8 G1 V
//DEACTIVATE WORKPLANE 取消激活座标
. w B/ X- r7 Q
* l0 H1 m: g b# A1 A6 p) R+ f* I' x$ g d- Z( r( k5 j
FORM BLOCK& t) s! f% k [, V0 D, q, g
UNDRAW BLOCK
$ p+ C0 D9 F5 jEDIT BLOCK ALL UNLOCK
! {$ B9 |% s% J" ~! f2 f4 vEDIT BLOCKTYPE BOX
, i& c' O* u; J: X$ ^( h& mEDIT BLOCK TOLERANCE 0.01
% ~0 ]' X- |+ q' r- d: Z3 |EDIT BLOCK LIMITTYPE MODEL
" z) b i2 a" a3 _4 g/ YEDIT BLOCK RESETLIMIT 0
$ j& c- F4 z" o& REDIT BLOCK RESET# X5 W0 [1 Y4 @1 Y) ]
EDIT BLOCK XMIN LOCK
( F: b9 _, ]: g$ p. _5 BEDIT BLOCK XMAX LOCK
, s6 q A1 r4 P8 _* F8 c7 XEDIT BLOCK YMIN LOCK
- g, U. G$ R2 X% y e& I- NEDIT BLOCK YMAX LOCK
A8 p7 f, c% w! X4 d+ a1 \EDIT BLOCK ZMIN LOCK
! e0 m' B8 |7 FEDIT BLOCK ZMAX LOCK8 M% B; e; f# a- M* R* j
BLOCK ACCEPT
9 |* x/ \* {" Z, _" p
; H' c) {, Y9 ]! m. N; \//DELETE WORKPLANE "ucs1"1 [' M" k/ ?6 H
//CREATE WORKPLANE "ucs1" YES FORM WPEDIT; X: t( a5 f% t4 m/ m/ n
EDIT WORKPLANE ;\n X "(Block.Limits.XMax-Block.Limits.XMin)/2+Block.Limits.XMin"
8 Q. o3 ], n" o+ uEDIT WORKPLANE ;\n Y "(Block.Limits.YMax-Block.Limits.YMin)/2+Block.Limits.YMin"
& J3 C& q+ D5 N+ E3 k6 B- e1 ?5 n. yEDIT WORKPLANE ;\n Z "Block.Limits.ZMax-0"' @$ `1 n. ^& w# K) g j8 I! u
TRANSFORM MOVE "0"
( f+ l3 t( t0 ~' d4 qTRANSFORM ANGLE "0"
) M5 b' G* M0 w6 }# NWPEDIT ACCEPT8 I, v/ v; Q- L& o
ACTIVATE WORKPLANE ;\n : }. J0 X; _$ v# i5 B
4 O5 p6 R7 M; F. c" ^6 [FORM BLOCK" V: i& c1 q+ o0 X9 G
! r6 L8 c, d. |# N" i% K0 tEDIT BLOCK RESET: G* c1 x# [! H
BLOCK ACCEPT
; D' |7 R& Z+ x# B+ p) x! v! V' `5 P" ]( ~( d
ROTATE TRANSFORM TOP VIEWMILL RESIZEVIEW |
