查看: 2283|回复: 2
[求助] 如何用VBA标注一个三维长方体尺寸?
发表于 2009-3-11 16:04:54 | 显示全部楼层 |阅读模式 来自: 中国福建福州
请版主举一个例子。。。给我参考下。。
. j5 y, P$ }; a, p, o- s& k
" {6 X( N8 e8 A8 m非常感谢!
 楼主| 发表于 2009-4-13 11:32:54 | 显示全部楼层 来自: 中国福建福州
继续求助。。。请版主就下面的代码。。帮我标注下这个长方体# t9 o4 j* v% Q% t. c7 V! `
# |  o3 f1 Z$ R! d
center1(0) = 1: center1(1) = 1: center1(2) = 1
; H. w- y& y. K8 y length = 2: width = 2: height = 44 G% l: H% N* c/ M% z
Set boxobj1 = ThisDrawing.ModelSpace.AddBox(center1, length, width, height)
. _5 P! R1 n8 A& P) ?+ P: f1 ?6 [2 }- t) i' H4 n! ^1 i; `
麻烦帮帮忙~~谢谢!
发表于 2009-4-15 19:13:08 | 显示全部楼层 来自: 中国
  1. : P2 Y) F( e' u; U  U( K( t
  2. Dim Center1(2) As Double, Length As Double, Width As Double, Height As Double, Boxobj1 As Acad3DSolid, L7 j- V1 ]; E3 ]8 N9 D
  3. Dim P1(2) As Double, P2(2) As Double, P3(2) As Double, Ucs As AcadUCS" N- I  X: J4 d7 b
  4. With ThisDrawing
    . K9 i# i7 z* l# c2 ~
  5.     Center1(0) = 1: Center1(1) = 1: Center1(2) = 1
    - V/ _( `* c. U( j4 y2 X
  6.     Length = 2: Width = 2: Height = 43 r% {- k6 u- m) ~/ \" [
  7.     Set Boxobj1 = .ModelSpace.AddBox(Center1, Length, Width, Height)
    + Q5 {1 f+ w5 t/ z
  8.     ; V; m1 M3 K+ D8 ?6 H( Y5 X
  9.     P1(0) = Center1(0): P1(1) = Center1(1): P1(2) = Center1(2) + Height / 2 '新UCS原点) S  u$ ~& y* ~
  10.     P2(0) = P1(0) + 1: P2(1) = P1(1): P2(2) = P1(2) '新UCS的X方向,与WCS的X方向相同
    0 `: C+ r% i% k  Z  I
  11.     P3(0) = P1(0): P3(1) = P1(1) + 1: P3(2) = P1(2) '新UCS的Y方向,与WCS的Y方向相同
    : Z6 M2 P& f5 a4 v
  12.     Set Ucs = .UserCoordinateSystems.Add(P1, P2, P3, "U") '新建UCS( H$ e. \2 B+ C+ w$ N8 l( t- f% ]
  13.     .ActiveUCS = Ucs  '新UCS置为当前
    2 W( y5 C- h4 Y$ f; p
  14.     5 D) _( A4 B: b" P  f  B+ O
  15.     SendCommand "dimlinear  0," & -Width / 2 & " 0," & -Width / 2 - 1 & " ") I* p2 W- C7 w7 G, C7 r
  16.     SendCommand "dimlinear  " & -Length / 2 & ",0 " & -Length / 2 - 1 & ",0 "
    ! z, _2 f7 F* a9 x! ?2 }" p
  17. ; j5 x- K& |- M. Q1 V/ q# J
  18.     P1(0) = Center1(0): P1(1) = Center1(1) - Width / 2: P1(2) = Center1(2) '新UCS原点
    4 L' w/ D& h5 L8 s0 w! k
  19.     P2(0) = P1(0) + 1: P2(1) = P1(1): P2(2) = P1(2) '新UCS的X方向,与WCS的X方向相同7 M. d8 w' G0 `6 |7 `9 F
  20.     P3(0) = P1(0): P3(1) = P1(1): P3(2) = P1(2) + 1 '新UCS的Y方向,与WCS的Z方向相同
    3 k0 R& R% a$ U% S
  21.     Set Ucs = .UserCoordinateSystems.Add(P1, P2, P3, "U") '新建UCS
    5 ?1 M8 ^3 S" V0 O' R
  22.     .ActiveUCS = Ucs  '新UCS置为当前
    6 _5 b7 `! l  _+ x$ R. Q) e, @, _
  23.     3 B: `0 ]. M, u; W, A2 t- O% g
  24.     SendCommand "dimlinear  " & -Length / 2 & ",0 " & -Length / 2 - 1 & ",0 "# B4 a! G  P$ E  V* z* w6 H
  25.       y8 N" w( Q& T0 `; u) k4 ]/ e
  26.     SendCommand "ucs w " '恢复WCS: Z( u7 {% F( I& O" b% X; ]2 r+ \# p( b
  27. End With5 C- M- d* @! M0 W& x: s
复制代码
