楼主 |
发表于 2009-3-24 12:59:01
来自: 中国广东深圳
(if (null int_list) (setq ok_p01 xpot) (setq ok_p01 nil)), {; \8 C# B" G
)! r' b- v5 R+ I) R; U/ }
(progn (setq ok_p01 xpot))
, ^) g8 n' M9 d4 _" T1 r1 s )* |7 ^ v6 z s( d6 Z9 S0 C6 v/ X
8 f" A/ X/ A$ p (progn
3 t. ?5 A9 ^- Y( B (setq ok_p01 nil): b( ]2 E8 \/ V2 |) F% [
)+ o. x7 X5 k, j; |: ]+ w2 ]. Q! v
+ A2 }8 I" a9 q! H; u" m! T3 {+ ])9 |( f& _6 G) K& g6 u
;;;;******PxNIL, Q5 K) f! ?' {3 Q$ x/ E9 M
;;;;******PxNIL7 u6 v& }% T/ b! ]3 w( ], X
(DEFUN PxNIL (/ list_up1 list_down1 p01_up p01_down p01_down1 p01_up1 p01_up2 p01_down2
8 A( _ N" M/ q0 h! ~ list_up list_down list_up2 list_down2 pot_angl list_all angl13_14 ssget_13X
/ ] o4 H) x/ o/ D2 T' e' [3 ^ ssget_14X ssget_13 noadd noadd_dist list_qty addangl list_no ok_p01 noadd_repeat)" h! }, Z; D6 |* y
(SETVAR "OSMODE" 0)) Y# i8 R- I) o
(if (= 1 yes_ok)" h1 F1 H& X. X
(setq ssget_px1 nil)! b2 v- s5 H6 q6 J
(setq ssget_px1 (member p01x base_13y13x))3 C# d( F/ x8 T) y: N
4 t2 ]& V* X- F* D v- F9 N
): @ p: m4 j& B* H0 {) x4 n2 [
(if (or (> p01x po_right)(< p01x po_left))7 b! k: M, `5 X/ z1 [
* i; m0 j3 Z3 W/ ~9 Y )8 w$ r' P4 C6 Q& M
(IF (null ssget_px1)
3 c* h4 G: {$ X/ h0 x/ f6 U (PROGN
( m7 B% A( [) _4 V4 _: N (SETQ len_P01x (strlen (RTOS P01x 2 2))
6 w" B) J5 P b1 D+ I7 {, f- T texthigh (getvar "dimtxt"). j4 ~8 k. e. w& S7 r( D
texthigh_half (/ texthigh 2)6 `9 R% v' O6 T, \1 R
textwid (* (* len_P01x texthigh) 0.6)0 s6 y. M; Q& N, g
aszwid (getvar "dimasz")2 ~/ D4 C3 w/ {, |( w1 J' Y
noadd 07 W7 _ l$ {( j1 U
list_all (list)
" N* {) O7 k) f( x$ A list_qty (list), k' N) @- r$ x
1 p; I' ]7 q, {) b2 _0 m (while (< noadd edit_y); t$ W' h8 ~0 ]: ^ f; v
(setq noadd (+ 2 noadd)
" F; g. E7 G0 J4 I7 `8 j6 \3 M noadd_dist (+ noadd (* 2 aszwid))
( W `1 |* V9 o( a: v/ [" T8 `, r list_qty (cons noadd_dist list_qty)' Z/ U8 ^) c5 ], a7 B
. q B9 t8 F# R9 X+ Y4 r, g: e# N )% w g. h$ r- I, O: N
(setq qty_max (nth 0 list_qty))
( z3 o }/ j: ?8 k (setq list_qty (reverse list_qty))8 T$ [& X% D0 I3 ~, c/ _
(setq pot_up (polar p01 2 (+ qty_max textwid)))
8 s- r9 J8 o% c$ o$ B1 Z (setq pot_down (polar p01 5.2 (+ qty_max textwid)))$ t: q0 w5 v: G/ ^8 l5 k8 c
(setq ch_ss (ssget "C" pot_up pot_down (list (cons 0 "DIMENSION")))) V) m5 G7 x' a
(setq ch_no -1
1 {3 h; |6 p3 y$ M; [+ y8 |0 r ch_ok nil
7 L+ g9 j) G3 W )- M) D# W" ]: d- d
(if (not (null ch_ss))3 W& J5 g8 U( v2 y1 p3 z3 f
(repeat (sslength ch_ss)3 z& J' y3 k8 G$ E4 u
(setq ch_no (1+ ch_no)
7 E! a- s! \4 q7 d' m ch_name (ssname ch_ss ch_no)0 A% n; g, h7 m6 H7 l, K1 D
)* e! v# b- ?" D% W" N; b1 O$ t' r
(SETQ ch_13 (TRANS (CDR (ASSOC 13 (entget ch_name))) 0 1))) E' A# h: }) B% |0 n4 C: g' T
(SETQ ch_14 (TRANS (CDR (ASSOC 14 (entget ch_name))) 0 1))
: v5 a; x, z% D, m( ` (setq ch_x (atof (rtos (cadr (assoc 13 (entget ch_name))) 2 3)))$ G: h3 D- @+ K9 \& P4 A
(setq ch_angl (angle ch_13 ch_14))' `( ~3 ?& R: e- g3 G" z& Z
(if (and (or (<= 0.79 ch_angl 2.3) (<= 3.95 ch_angl 5.46))
& \1 T: x3 s" T* I) ^# } (= ch_x (atof (rtos (car (trans p01 1 0)) 2 3))))# H; s; ~+ t9 C7 j- c
(setq ch_ok (cons "ng" ch_ok))
6 t$ Q: h6 v; x1 m% m2 s2 y )6 A* B! h: D# N. W# f: `- V! o" `
% A7 N# J: n+ z) L$ G5 N )
, I( \7 ~! T$ p;;;;;% F3 v2 {; q, A
(if (null ch_ok)$ u* J8 B( e1 X1 h! n
(progn
5 k" @8 ?. v: a% X5 o) V; U (setq list_no -1)
, Z$ q) O, N6 M+ H (repeat (length list_qty)- F2 A. a) ~0 q; l
(setq list_no (1+ list_no)+ x8 b. O9 R, c" `! K( q0 i
p01_up (list (polar p01 (/ pi 2) (nth list_no list_qty)))
$ P& ?+ X( w# N z3 T- b0 e( p list_up (append list_up p01_up)* b) r7 ?* R8 K% \, m" o
)7 S/ y! ^8 z$ b; A" m
5 L, l7 T# m8 J5 L* }1 Q* P0 K8 W (setq list_no -1)
# G/ b/ R) N! \: W (repeat (length list_qty)
; Y$ C- u6 D' T9 ^ (setq list_no (1+ list_no)
0 V" y3 G% e, |" F) I p01_down (list (polar p01 (/ (* 3 pi) 2) (nth list_no list_qty)))
, \( j& n: n7 Q- n1 r2 W. i s0 ~ list_down (append list_down p01_down)
- _5 N5 y8 K% Y3 ] )
4 o3 y6 R) {) _" S O- w ); \+ l: ?2 y* w
;;;;2 `& `* N" e) }) g1 y% K5 Q2 p
(setq list_no -1)' g4 Q( F. y7 H1 h4 j* X+ O* g
6 Z7 [& j- x% c4 C# N. M (setq list_no (1+ list_no)
) F/ R* l# C7 N# R- p- c addangl (/ pi 2)0 u. q- \ N2 Y& v
0 p+ K, K) }0 J- e5 ^ (repeat 2- i5 C3 u" Y: S8 i7 Q) A+ |& y
(setq addangl (+ addangl (/ (* pi 10) 180))3 B5 h% ]5 }, X1 h' a' {9 s
p01_up1 (list (polar p01 addangl (nth list_no list_qty)))% ]+ i9 D# |6 k- _
list_up1 (append list_up1 p01_up1): C' g8 J% D/ X
# A9 {4 V, u( x4 D4 r6 E" ? )9 H+ [4 A' s9 E9 v5 i
/ L/ k! W2 {$ d, Y7 [( c% f;;;;;
: F, V' [) Q" h5 m0 G# y. T- X;;;;;
* V1 d# g8 Z( S/ d (setq list_no -1), e& v; _7 @+ l, T
(repeat (length list_qty)* K" f! U x' m' Q' ^5 ]# K2 u, X8 V
(setq list_no (1+ list_no)# X8 |# m% Y2 h \' z( ?% k
addangl (/ (* pi 3) 2)
& g d8 b6 {8 L$ b5 { )
" g( R+ T l) g% v (repeat 2
4 y; F7 R! b; d. _' X$ Q, }% N (setq addangl (+ addangl (/ (* pi 10) 180))% Y) Q$ f9 k; b
p01_down1 (list (polar p01 addangl (nth list_no list_qty)))
4 ]# I# x4 P* f k5 n$ D# r list_down1 (append list_down1 p01_down1)
, l9 O) Y; A- Z# j- T# L& q )
( w$ q) l* k! R4 |5 K ), N* u# {6 l) _% S1 b% C
- D \' u) B* H5 d$ ]4 l;;;;;# K4 @. y7 v0 W! @
(setq list_no -1)
a$ q, m/ A. X7 h% y (repeat (length list_qty), p: t1 ]8 [& {* @
(setq list_no (1+ list_no)! ~/ a6 z# e- _9 Q
addangl (/ (* pi 60) 180)
2 N4 \) C+ o) z* s5 g ) I1 M5 x: G$ F5 G
(repeat 2
; v, t& u% z. X (setq addangl (+ addangl (/ (* pi 10) 180))4 Y" Q) A( g' |) L4 {; v- \7 R
p01_up2 (list (polar p01 addangl (nth list_no list_qty)))
& D2 M* w" W) F% L j list_up2 (append list_up2 p01_up2)/ Z/ [+ x" V! C6 v' B9 c# W
)" s6 o' M1 T$ ?$ n, n& {: O V
4 f9 Q/ B. ?4 {" h. V% d; ] )
. v6 |6 |1 c5 U# T;;;;;
# b7 ?# d$ b8 P2 e# L (setq list_no -1)
! }6 b% h. P5 m( J+ p l* `$ @- y. \ (repeat (length list_qty)
7 q: {; {3 T8 B5 ~ (setq list_no (1+ list_no)5 f4 n, Z0 _ G# `
addangl (/ (* pi 240) 180)2 g! ]# u% O) k. b$ }3 c
: Y7 e/ n7 z1 J+ d (repeat 2
5 e5 L4 o) p# { (setq addangl (+ addangl (/ (* pi 10) 180))
8 }% K. M- K& l7 [) A p01_down2 (list (polar p01 addangl (nth list_no list_qty)))
8 E" ?& a" y) r( q list_down2 (append list_down2 p01_down2)
( C& j% R" R6 A" x9 @* s4 q7 E )
+ |( g _* p7 J1 {1 @* r" { )* J, t/ I' W( R6 t! n: X
3 u- s( F9 Q& L8 j! m9 Y, g;;;;;;
( m ]: K6 k3 X3 ] (setq noadd -1)
% m8 |2 A8 O" u% n# _ (repeat (length list_up)5 C# j; D8 h0 q9 L7 Y
(setq noadd (1+ noadd)
2 u5 A2 Y; O# ^% B5 q list_all (append list_all (list (nth noadd list_up)))
& f+ F) _1 F0 a1 A list_all (append list_all (list (nth noadd list_down)))/ X* x9 F, g9 A( o: E2 [
" Z8 B6 F/ F0 |, C) X- e ), q" g# a4 e$ b1 v
;;;;;: w5 Z# |/ v/ M5 G& {2 A$ D+ V1 B
(setq noadd -1)
6 V( _+ s& V% t$ G/ Y$ `2 d) w3 M; _ (repeat (length list_up1)$ z$ C, q" ~# z! B" W z% E: t
(setq noadd (1+ noadd))9 P( r0 E, z/ Y6 S3 |# ]" X
(setq list_all (append list_all (list (nth noadd list_up1))): q) O0 {- _* e" ~2 _. Z
list_all (append list_all (list (nth noadd list_down1))); v" }8 f! B) ]6 z) n
list_all (append list_all (list (nth noadd list_up2)))
' W2 x& }) E! V1 D, t1 }- u1 T$ v list_all (append list_all (list (nth noadd list_down2)))7 c- l: k& B& m' m! x1 i; | y
): y, T! b2 s0 p+ @
)5 H: q+ z7 c' S9 z3 B6 |
(setq list_all (append list_all (list (polar p01 (/ pi 2) 4) (polar p01 (/ (* 3 pi) 2) 4))))
% r: ?. q0 p: C9 ~# C+ f& p;;;;;
2 b, e1 Z j! \% K* A J
; E8 m2 H; z" }$ W* f( y;;;;;! t i: [* r( |) d- E% @. a v/ k
(setq noadd_repeat -1
$ \( \# q" U! K: p1 K9 b ok_p01 NIL
* c! O9 C8 }+ B4 @( R1 h )0 Z. M- B& }/ E$ U
(while (and (null ok_p01) (> (- (length list_all) noadd_repeat) 1))
3 y1 L# t( W3 k) [4 S( M (setq noadd_repeat (1+ noadd_repeat)/ T1 Z: K" h2 V. C( r2 z
xpott (nth noadd_repeat list_all)
1 q) V1 |! [* b )
8 ]8 ^. j) n2 A0 f. y (selectx xpott)6 }+ P2 n. b# h* L/ s$ ~
j6 K8 S" e) |5 v! f, a% N% G1 g (if ok_p017 n3 M h. G5 j. b3 K1 O* b2 f- R! [
(COMMAND "_DIMORDINATE" P01 ok_p01) D, O) u$ h! k _2 n" ~
(progn8 t7 {' b+ ^" ~& m
(setq ok_p01 (polar p01 (/ pi 2) 3))5 q2 P f' f2 U U" X( H2 l# h9 V
(setq dim_color (getvar "dimclrt"))+ a" t" w+ [+ Q9 G# p" @: F2 @2 r
(setvar "dimclrt" 2)+ f4 h, @( |. q, N% R
(COMMAND "_DIMORDINATE" P01 ok_p01)' ^9 l9 Q2 @* A6 m' Q) e
(setvar "dimclrt" dim_color)+ b- s. D3 }" H, S a7 a6 q, j0 j, Z
)6 ~0 ~1 _# a4 S' }" {
)% t8 `5 u. v- y& `' b
))& X- ]' B: c, k$ ^" ~9 T) L
2 i! }' v9 ?1 u- h8 g! {2 b )# E# I. i5 W9 L; H4 p3 t
) m3 I# @0 a; o4 t# ~
! b' q! P: b1 [. n9 |9 L9 Z# Q(defun selectx (xpot / int_list pot_int pot_angl pot_14 pot_13 nam_dim dim_name dim_full)
|( T) e' i2 Z! V( q( I (if (> (cadr xpot) (cadr p01)) (setq angl (/ pi 2)) (setq angl (/ (* 3 pi) 2)))
4 H- e; o# n7 H% i (if (null (ssget "C" (polar xpot pi texthigh_half)
; Z4 s' n' I: p' z/ y H (polar (polar xpot 0 texthigh_half) angl textwid)))
' K( t, V! X% v( C( c* {1 F# g (progn
* E& b' ~: y$ t2 j* W (setq dimx_angl (angle p01 xpot)) T4 j6 @) g5 h. [2 x7 v# r
(setvar "pickbox" 3)
" u M& c* T3 q' o, \0 E/ \ (setq dim_full (ssget "C" xpot (polar p01 dimx_angl 3)(list (cons 0 "DIMENSION"))))
* F# t' J$ g# X: m (setvar "pickbox" 0); L3 ~: T: a h) [
(setq int_list nil)
* o; V/ ~' o: c3 |0 i (if (not (null dim_full))
9 O9 K& y. [! R7 U: p. Z0 M' l (progn
# u5 a! o6 `9 U1 `% s (setq noadd -1)2 ^9 D8 R7 _ w9 @# l- @/ i8 Z6 V
(repeat (sslength dim_full) C9 a. _9 X6 o. o8 [$ y
(setq noadd (1+ noadd)# u$ }* s+ s0 h; Q x/ W \3 ]- |8 c0 L
dim_name (ssname dim_full noadd); e5 n9 `4 o; {5 C* K
)& n* n# w4 T6 G, I6 @
(setq pot_angl NIL)" r5 e7 U; O+ j
(SETQ pot_13 (TRANS (CDR (ASSOC 13 (entget dim_name))) 0 1))9 T1 ~. R; `7 y( x$ v( H5 \8 G
(SETQ pot_14 (TRANS (CDR (ASSOC 14 (entget dim_name))) 0 1))
! C6 R* n0 d% R% V' t: H5 L (setq len_13x (strlen (RTOS (cadr pot_13) 2 2))
; Y8 w0 Q# D2 M1 t7 ? textwid1 (* (* len_13x texthigh) 0.7)& e/ J. v6 }3 `3 l" Z( e" _
) }- Q2 S0 ^, N7 n* r6 W
(setq pot_angl (angle pot_13 pot_14))
( j1 v) }5 L5 V. t4 w- s1 }( U2 z (if (or (<= 0.79 pot_angl 2.3) (<= 3.95 pot_angl 5.46))- y( o: U, \1 s4 [3 S
(progn! j/ t- e' Y6 t% V5 c- Z
(setq pot_15 (polar pot_14 pot_angl textwid))
2 F8 [* s0 V6 U# R2 ^+ }0 ? (setq pot_int (inters pot_13 pot_15 p01 xpot))
/ `0 n" ^9 W. ?5 G/ Z (if (not (null pot_int))- G4 Q3 N$ ]) @: k0 d( ~- M4 _
(setq int_list (cons pot_int int_list)). a/ i( n, `/ i! j; B
(progn
{% n. \( L' x& h (setq x_14 (car pot_14)5 h1 M7 F' w- i6 T6 R
x_p01 (car p01)
5 D2 @( B& i5 c x_xpot (car xpot)
7 J. w: z9 s0 i )
/ p; P7 b1 i o (if (or (<= (abs (- x_p01 x_14)) texthigh_half)3 T- |1 I$ A F* f( M& ~
(<= (abs (- x_xpot x_14)) texthigh_half)
/ h5 H9 Z$ m" t )0 R4 w( y8 x. Y; l: k% X) @+ o' ^0 L
(setq int_list (cons 3 int_list))' R, F0 C" a! _7 p$ f& Y4 r
) : O: g# F9 S- K* @
7 @5 U! _: F5 h, b6 l4 ]8 H L ) X7 I0 C& c7 |& @9 U& s9 g
)) W3 j' S( H" l) M2 {0 Z- m7 p- _& k& M
(progn5 P- |4 F( z. ~# J
(setq pot_16 (polar pot_14 pot_angl textwid1))4 q' x& l8 B9 s9 {; J; q8 z% g- h% p# p
(setq pot_int3 (inters pot_14 pot_16 p01 xpot)): H. v( }$ C2 g t+ ^
(if (not (null pot_int3))
% s$ K% x/ p: K (setq int_list (cons pot_int3 int_list))
' |& ]' u, `* `" F )$ l9 D9 |+ V# z! B
; x# |! L) Y" t# i; w ); ~9 ~8 b' _# y& ?6 e
)7 W, @7 C0 C1 H
' o5 C- b/ P) n )
% w/ \3 W+ i1 N" n& l- ~# T: o (progn (setq ok_p01 xpot)), H4 i* Q6 ]3 v) t/ W9 Y2 V) e
)/ N( f0 u. H- h/ ?9 p/ l
" h" }5 T9 y2 Y, {9 J6 \ (progn f4 M) k. ]0 S% S
(setq ok_p01 nil)# o3 H6 L, p: v, w% v' v0 i5 q1 g! O
7 }) R4 U2 K+ V )) ?$ B7 @* m0 D1 a( Q6 s! B [
7 K# V0 q, W7 ?+ @ W) ]6 H;;;;;;;0 X/ \. H& I4 T) x" I- ^9 Z
(defun check (number)9 A2 x) q, ^ ?% A5 W
(set_tile "error" "")
0 T4 j& v8 R/ G0 R: p6 C& j y (if (not (distof (get_tile number)))
, W' S$ D9 i$ O (progn
4 m2 T$ _" Z% T2 ^- v5 ]# F1 _ (set_tile "error" "error value")# ]9 y7 b8 L$ c
(mode_tile number 2)' g7 D8 s; l4 Z- [' a
(mode_tile number 3)* S0 w4 E2 D4 ~& a& N
nil
J- u5 H v. g' D) H7 n )2 y& V: o/ H7 _3 L! l3 u
' t8 U5 d6 A$ R* X6 U' T! B )
8 I: g2 w% ^' e2 V; d)$ |
