发表于 2009-3-25 20:51:51
来自: 中国浙江宁波
lisp中可以通过调用vba宏实现;. @ X2 E* w" n3 q, P
VBA中使用lisp,可以使用vlax类来实现;
& R; m0 H+ d) |1 z) b; D& G# {vlax.cls: v% V5 `2 V9 } p, }
VLAX.CLS v2.0 (Last updated 8/1/2003)
5 |& Z2 ~: I' d* J- T' Copyright 1999-2001 by Frank Oquendo. o1 U. r# J7 }' |
' 该程序由明经通道修改支持2004版本- Z" W' @. d7 Z& A4 d# t
' Permission to use, copy, modify, and distribute this software5 ~- W0 {, |! a: q8 r+ c
' for any purpose and without fee is hereby granted, provided
( {$ B& _) ]6 Y6 X+ P0 I3 l7 C3 f- X4 g4 R% I' that the above copyright notice appears in all copies and
) n" D8 I3 ?4 m8 B' that both that copyright notice and the limited warranty and
7 [# I7 p1 {8 T' v9 Z; g' restricted rights notice below appear in all supporting
6 T' ^, w4 X9 q0 G. |# d* p" `7 a4 O' documentation.5 h6 S2 ~: h/ z4 Q' q( f( n% u
'! o4 t) `5 c% \# j7 h7 i
' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH7 h' E4 C" D1 K/ A0 J, J
' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
, q+ y' `0 K i: Y+ i% C7 y/ U' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. THE AUTHOR/ l0 c, B2 h* t- O% p
' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE2 H2 u6 }. [+ o/ @4 b
' UNINTERRUPTED OR ERROR FREE.; L T5 P- \ [; j7 h
: E# `. s4 |5 M( f' Use, duplication, or disclosure by the U.S. Government is subject to) U" k: \3 M# v
' restrictions set forth in FAR 52.227-19 (Commercial Computer
. {2 o* r# h$ }* ^5 `' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)1 Z5 r8 h. g' l! |& `2 |; d
' (Rights in Technical Data and Computer Software), as applicable.
$ H2 O2 ]! c; _8 d0 C* j$ a4 |/ q8 ~'# p J$ `! w7 Z/ a5 k
' VLAX.cls allows developers to evaluate AutoLISP expressions from0 r$ Q* N9 H2 v2 s# E2 R/ @ ]
' Visual Basic or VBA {+ U3 P5 [" T
'0 y$ Z2 J; k9 W( o
' Notes:4 z0 }8 M, y9 Q4 ~) F0 u! `$ `
' All code for this class module is publicly available througout various posts
4 D6 U2 @, l0 M2 Y) Q n2 V" @0 [) y' at news://discussion.autodesk.com/autod ... stomization.vba.Idonot
. w' q H# z7 F) w0 |' claim copyright or authorship on code presented in these posts, only on this, p6 K) \5 b Z; f6 K. \! s
' compilation of that code. In addition, a great big "Thank you!" to Cyrille Fauvel
/ k2 s& |* W) L7 W1 H& a. U' demonstrating the use of the VisualLISP ActiveX Module.9 \) y1 |9 O3 z) n9 w" ^
'. d4 b0 E) w5 Y5 t0 g& M. P
' Dependencies:+ L( S* [2 h% n* d/ G" M# O
' Use of this class module requires the following application:" x; n; Z6 ]1 B- |6 _* m* ]* Q+ Z
' 1. VisualLISP/ S+ C% s( t% E$ C
Private VL As Object8 m6 J! M- `& s, Y4 w) i
Private VLF As Object2 v& Y, z$ Q i' `7 I
Private Sub Class_Initialize()
. [& \5 M: {/ Q: U" `9 @ '根据AutoCAD的版本判断使用的库类型" l* h2 E) P' {- c$ @" ]
If Left(ThisDrawing.Application.Version, 2) = "15" Then
9 h7 K1 w+ ~6 [4 P& i1 p8 x Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
, Q; G$ k. {/ e$ A# e ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then
]% M I3 o* ]& P* T Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.16"); D9 w+ [% ^1 {/ a7 U+ Q2 B. d
End If
: _6 J1 Q7 I* k& A5 T8 ^3 P. G $ {( o$ a! i0 h; x
Set VLF = VL.ActiveDocument.Functions
* a+ L0 ~1 G- `, A1 ]! R/ j/ xEnd Sub' n2 W9 m" h# x+ Q# [9 B
Private Sub Class_Terminate()
+ G; _, ^8 t& @7 r% j( w. u5 c3 B" A '类析构时,释放内存9 t8 r% ?9 Q& ]
Set VLF = Nothing% H: b0 f8 |+ s" @% c! L0 L
Set VL = Nothing
; @: r8 q- M4 R( l0 TEnd Sub2 W! V' f$ S6 H5 }
Public Function EvalLispExpression(lispStatement As String)
: I3 K+ t. b, D; d- X% P '根据LISP表达式调用函数# H1 w; A" u+ e# r$ V S4 P. r
Dim sym As Object, ret As Object, retVal
. x6 p7 G; V4 O' [- |" ^& F( p Set sym = VLF.item("read").funcall(lispStatement)
$ k! {- X% A7 p* n/ o5 q+ w0 G 5 }1 @2 g3 [# y
On Error Resume Next
5 e0 V& N5 T/ i
9 \( }7 X' c$ [6 _ retVal = VLF.item("eval").funcall(sym)
: ~8 k. E1 e7 Y! U
0 ]3 n! B3 H2 x If Err Then. E6 W+ A. F l7 c' t; S
EvalLispExpression = ""
2 R6 {7 {% i6 {- E" i Else
y/ H* p# {/ Y3 o2 w8 @ EvalLispExpression = retVal- B7 j9 r& Z' A& K
End If
- R; O) J# J9 g! @- Q6 O) tEnd Function
6 V1 n2 ]' f9 @Public Sub SetLispSymbol(symbolName As String, value)) y. U' o) ~* K; e: v. |
Dim sym As Object, ret, symValue
; p0 }8 f; M/ s% b symValue = value; o' k. X* ]3 n
' P/ g: n1 ]3 H
Set sym = VLF.item("read").funcall(symbolName)" a; y C- b' ]+ s4 n, r
2 N0 r' `! C% |. P% V
ret = VLF.item("set").funcall(sym, symValue)
( G2 R+ _+ ~' t" W$ u, ^: W2 _ EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"9 c4 p( n7 S( Q" _: R" u9 g8 A
EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
- l! B0 Y+ Y$ N) P0 J) }1 ^. }- C EvalLispExpression "(setq translate-variant nil)") ?8 {( r* _0 S- U+ J- q: z2 d
End Sub
- a+ s$ H! a! V7 C9 p( B$ |Public Function GetLispSymbol(symbolName As String)
5 X/ O2 g% q/ X" D- b& M Dim sym As Object, ret, symValue
6 E( D+ j1 \& {4 B( v symValue = value2 S! a& C3 @3 l0 ^, t* f( r
( t' z/ M* a' [/ ~4 z& d$ \/ }* n# B
( Z. |* b2 b8 w' c
, f2 U# R; e# ^/ L GetLispSymbol = VLF.item("eval").funcall(sym)
7 Z- P$ s5 T9 `" v& bEnd Function* m+ `1 E2 h$ `; H z0 g
Public Function GetLispList(symbolName As String) As Variant7 ]; E( C1 U: M6 S6 `% P
Dim sym As Object, list As Object
& D; e( o" Q8 j- b, R3 K Dim Count, elements(), i As Long8 z4 M1 y/ A* q3 r8 A5 P
8 M8 q5 [$ R# P& J
Set sym = VLF.item("read").funcall(symbolName)* F! P8 {6 a( _" D$ d! [4 A$ s
Set list = VLF.item("eval").funcall(sym)
. P8 U& @5 Z0 D
- {3 ~& U: f. E9 ^& L Count = VLF.item("length").funcall(list)
+ G) A. J. F4 p9 d( W% g
/ b! G6 w% L' K' K ReDim elements(0 To Count - 1) As Variant6 f! J8 ]6 L; ?. H/ i, M& o
. `% P, K5 I, V" l' N3 `. [( p
For i = 0 To Count - 1
h$ h( i( I# K+ Z elements(i) = VLF.item("nth").funcall(i, list)
6 M" O1 D- t, J6 d) l Next8 d% }3 \' A) m2 f4 q
2 q2 u0 B6 [" L, e3 S1 }) C" P1 y
GetLispList = elements
# r& [5 J* `9 \7 ~% d- l- pEnd Function: d, z/ i+ Q2 E
Public Sub NullifySymbol(ParamArray symbolName())
( ^7 |8 Z5 k* `4 Z Dim i As Integer
5 l% o: \8 C! }" `$ c5 W
" @. e* o6 J' t& C, T6 V For i = LBound(symbolName) To UBound(symbolName)9 `* @- [5 X( C- ^) j; L: S
EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
' l ]" @) i$ ~# k1 r6 w) Z5 W z Next+ p9 t' O" @3 D2 s4 f
End Sub4 S" }1 G# ?8 E5 ^" R: \% e- \
- H6 o' R& N0 j/ | ]+ m6 u
实例:9 [, b1 A" k. G8 K7 B5 e c* S
鼠标移动块& y! C+ m- s% B1 H
7 J7 h' a T- G5 O3 FPublic Sub BlockInsert(Name As String)
" j( B, K) e$ G0 n @Dim pLisp As String
$ x) ] _! k8 M" u% w; gDim obj As VLAX. T8 l3 `4 f& B) U
Dim pnt(2) As Double2 G8 {7 Q2 e2 u; i4 P) F0 J7 ^
Set obj = New VLAX
+ _# l2 R( f% N6 G) c: T* n0 |6 d+ @& ?Dim pObj As AcadBlockReference; d/ G5 D; @; c2 |
Set pObj = ThisDrawing.ModelSpace.InsertBlock(pnt, Name, 1, 1, 1, 0)
1 V; i. ?$ S! M" o0 W! G: _obj.EvalLispExpression "(setq ed (entget (handent " & ToStr(pObj.Handle) & ")))"' e1 |$ J) E! K* S
pLisp = "(while (not (= (caddr " & _1 t8 S" z' R7 v% V0 W
"(setq pTime (grread t) " & _. G/ g6 u+ M5 N# x$ h) P4 A2 I
"pSt (car pTime) " & _6 o) B7 s7 ]% _. c/ x
"pnt (cond ((= pSt 3) (List 0 0 -1)) ((= pSt 5) (cadr pTime)) (t (List 0 0 1))))) -1)) " & _
1 F7 M8 ~: l/ w' n) I"(setq ed (subst (cons 10 pnt) (assoc 10 ed) ed)) " & _; O' ~' h. ]) [; R- q
"(entmod ed) " & _
$ ~! ]- E0 R1 E, d") ", @* e9 j% F5 |3 R) k2 Y: L
obj.EvalLispExpression pLisp! a* t1 p0 q5 N1 o1 e
Set obj = Nothing
4 T% U) M& k+ v, V- O0 TEnd Sub4 a0 j+ z# S7 g, `5 x) I
Public Function ToStr(ByVal str) As String! s. M: E1 A3 F
ToStr = Chr(34) & str & Chr(34)4 f. i& G7 O G3 l2 H$ W
End Function
% m7 b- t6 ?3 hSub Test()
5 I1 X0 Z) r3 j. U' |BlockInsert "123"+ L' J( l+ o2 ^0 e: l& X
End Sub |
