6天前
查看: 1088|回复: 0
[求助] 求美国腐蚀学会文章:Corrosion inhibitor
发表于 2009-3-27 21:13:06 | 显示全部楼层 |阅读模式 来自: 中国浙江嘉兴
Document title:
" @+ k8 Q% _4 W5 `6 f* HCorrosion inhibitor evaluation for materials used in closed cooling water systems" t$ q2 W0 _7 c  }/ k3 S
Author(s):MOCCARI A. A.. }; U* V* x" @& p9 G. j: Z8 z1 t
Journal Title:Materials performance   ISSN 0094-1492  , f! L, f  `+ Z& k1 G
1999, vol. 38, no9, pp. 54-59 (8 ref.)
, o1 t5 D( M6 d8 GAbstract5 E- q% v7 {9 H6 w: C: D1 D& v
Electrochemical tests were conducted to evaluate the inhibition effects of a commercial sodium nitrite (NaNO2)/sodium tolyltriazole (nitrite/TTA)-based corrosion inhibitor added to deionized water at 50°C. General and pitting corrosion of materials commonly used in closed cooling water systems were examined. Tests also were performed in deionized water which Cl- had been added. At the tested concentrations, nitrite/TTA was found to be an effective corrosion inhibitor for all of the materials tested in plain deionized water and Cl--containing water.
