发表于 2009-6-19 23:05:08
来自: 中国江苏苏州
刚刚下了个新的版本:X.CAT_Welle1_Update_1580,也是英文版。 k7 I8 k# L, [7 E& l% W
还有更高版的,无法下载。
5 R% P8 Z! {/ u, MUpdate for version 7.2.1674 (2009-06-03): # w4 a8 L6 g* O7 C8 @6 ~
Set saved addresses as default values in tabs 'Sales office' and 'Customer' # Y* r9 U4 c0 `! J% R. G
Behavior of discounts and net prices in the project list fixed \' U% O G# T
Price 'on request' inside VSR/Spridion file removed 9 X3 j$ w9 r+ u! ~ g5 |
Couplings, Gear units: Small corrections
3 t. t+ q3 _6 s1 K2 OUpdate for version 7.2.1623 (2009-05-15):
3 h/ e9 Q8 j8 d" o* K v9 C7 ePrintout Calculation for FFA 8 g( q6 B' w2 k! `
Export of prices to VSR, SPIRIDON " G1 J' \" V* y- q3 k( q( y
Update for version 7.2.1616 (2009-05-06):
) f$ B) P% z( m7 O& W; z# aAll copy-to-clipboard functions changed - P$ U8 @. O* M6 d+ c3 `
File for import into SPIRIDON: '+='-Characters in the interface file removed 2 e* C9 x! O0 \) L& o; h
Couplings: Special bore on the right side could not be entered
% X4 g" W. d) {/ g$ ^) DUpdate for version 7.2.1580 (2009-04-30):
) h9 p1 ? B# U: wMajor update with significant enhancements in various areas. 6 f: j7 k) ]; K
2 `1 ]6 v/ M; S% K$ o& N3 qUpdate for version 7.2.1113 (2008-12-18):
1 U' k+ p# s* f" i( vCouplings: small corrections
* s1 F+ W: ?9 p7 @4 Y4 yGear units: text corrections for the product description ' _9 i$ f$ _8 q# ^1 }
Update for version 7.2.1073 (2008-12-11):
: V( i7 `$ D4 S- NUpdate of databases, small corrections * Y) e! c: p+ s' g7 `1 i9 f
Update for version 7.2.881 (2008-10-01): + `: _) C; s0 o
Data update for FY 2008/2009
5 x8 |8 \0 N* h# c% }Spare parts IDA / HD assigned to GCK Service Int.
$ r8 `- B/ k3 H* W4 T5 ] Z8 aUpdate for version 7.2.867 (2008-08-13):
( K9 U( I, a: M. dData Updates (FFA, Gear Units, Couplings) 2 n7 }) B- L9 r
Bugfixes for Direct input of order nummber (FFA)
* N. W% f+ x3 ]$ rGear Units: If radial forces apply, then gear unit is set 'on request' & v+ @% c2 \4 v2 g
Gear units for bucket elevators and belt conveyors: Change of minimal environment temperature in selection of Motox auxilliary drives (Change of output shaft dimension) from '<= -20°C' to '<= -21°C'
% f/ R8 j# Z& e/ L# O" ^+ n( h1 xUpdate for version 7.2.858 (2008-07-09): 0 f9 A; K! {: a: Y* s9 L/ o- d
Gear units: Integration of trunk MLFB for gear units into the general product selection 'gear units'
$ M+ p; D5 t* o5 s" w9 RRedesigned product selection
* i* ~' ~% P& N6 I! g; PNew trunk MLFB for additional services 9 k' _8 Q5 m! U& ^) Y
Improved search for single parts (Combined Search) ! j6 E9 K2 c+ n/ w' G$ F
Reorganized basic settings $ d2 L1 K, z3 f5 ?3 C8 F* m
The MLFB trunks for electrical devices EOC have been replaced by the single parts FFA:000000361460 (EOC Sensor) and FFA:000001205294 (Avalution instrument)! : k r9 G/ V) p
Gear units - ATEX:+ }" r" L( @4 x* f, Y* h$ U( P
Specification for zone instead of category and atmosphere
& T& B% p d1 eAccess to Checklist for ATEX-Conditions ( r$ M' Q4 C( b, t
Gear units – Technical Selection – Search results:
4 ~; C% B4 Y* k- I% I1 vSelecting options added$ y7 i* p; J8 |0 t# }. ]) T: m
Sorting functions for type/size, ratio, output speed, service factor and price added
' h. E* v" n' l& y# V( IGear units – Quick Selection:" O6 `* Q+ Y; T4 t4 |
FSG: specification of ambient conditions added
& z. ]7 p0 c7 H. U+ E; ZSelection of gear units by torque moment possible : |2 {0 E3 v f# ?% z3 x
Update for version 7.2.743 (2008-04-17): : S- }0 z+ ~% `/ g/ G& F
Update of databases, small corrections 6 |- ~3 k9 P7 m! R$ y7 d% ]. ^" m
Update for version 7.2.730 (2008-03-28): ) j. x9 b3 m5 Z' a+ x
Couplings: New Technical selection 0 e. s2 Z/ _$ X
All gear units: Conservation: description field for special colour deleted. Please describe special colours as free text (Y99). / n$ P3 m; r, R. G2 m" G' w; B4 i
Standard Gear units: OPTION H39: for vertical gear units with oil compensation tank! 1 o* A, T" q) _# l
Standard Gear units: Selection for swing bases, torque support (for housings) and housing flanges corrected ' n: C# V9 Q" q5 X* S+ x
Hoisting gear drives: Pictures for gear unit designs changed
" s) E" B. Q4 N" ]Conveyor drives: B3.E: new sealing „TacoLab“ added, B3.E: shaft dimensions changed, Motor mounting flange added, Swing base added 2 J! G% M+ Z3 e8 p% P( b& V+ ^% V
Bucket elevator drives: Motor mounting flange added, Swing base added ) ?' N0 @7 H) \! p6 i. X
Paper machine drives: qear unit H2SH as “Paper machine drive” deleted. Please use “Gear units”. ( U# }; p; a% g
Update for version 7.2.661:
3 D- z' T! X0 P m4 [ B+ aCouplings: Product descriptions added, corrections : |" V; Y ^1 r( V
Gear units: internal corrosion prevention updated when sealing system modified
0 C1 S( d" @' Z# \Gear units: selection for labyrinth seals in consideration of mimimum input speed 6 x1 h3 S* r9 ~( k
Gear units: fan for helical gear units in vertical mounting position deleted
6 t* Y( h |1 iGear units: code letter for high speed shafts with fan corrected (l1 -> l3, G1 -> G3) % p0 B/ |& a( ~4 o! W k5 M
Gear units: selection for auxiliary drives (bucket elevator drives, conveyor drives) in consideration of mimimum environmental temperature (output shaft dimensions for the aux.drive has changed for temperatures <= -20°C) 0 r2 y; ?* Y& ^5 Q
Gear units: new RAL-colors for conservation added $ C: ^+ w" O. M, ]/ J
Gear units: gear unit B2SH as “Paper machine drive” deleted. Please use “Gear units” 2 z) w! ]: O4 B1 ~9 N
Gear units: selection for hoisting gear drives with motor bell housing corrected (MLFB-error on position 15 (motor size)) 0 ], l0 m. o, z+ q" C7 o8 c: n
Update for version 7.2.645:
1 E- R& j/ I% R3 i( Y' SCouplings quick selection: bug fixed (ARPEX)
3 @& |- W9 ?2 X: ?Update for version 7.2.642:
_8 v: ~6 X& H6 }& kVSR (XML based) bug fixed: missing coupling MLFB & s- i- E( y' i6 b- Q
MLFB analysis: bug fixed: output for couplings ; \0 |& j0 d5 z- e* a+ a
Couplings quick selection: balancing quality option restored
0 Q& \5 P& ?/ e7 u$ q: E6 l( I/ G4 bUpdate for version 7.2.641:
8 D+ }/ B3 c5 P0 N7 YNew technical appendix printout option
5 C& ~6 o$ A2 [) |Enhanced options gear units
" W& c9 d% B# F9 ICorrections for couplings - M( j( |' N& t
Update for version 7.2.597: + M4 i' H4 x$ }" h2 j
New option for Copy and Paste to SAP (see menu 'Basic Settings') 5 m( G [2 j- I
Automatic check for available updates (possible to switch of in 'Basic Settings')
( _/ V% Y& A& _* m1 e5 @& h [/ _Options to the MLFB get ascending listed % n2 o! @$ X. C5 H: u3 s9 d
Enhanced options gear units & o& o1 T+ Y4 X* {0 N. I, S( h
Update for version 7.2.586: " g9 b( w1 J0 O0 n2 A/ {. g) {; V+ i
Interface for VSR changed to Excel XML
7 x( k; C7 H( U6 t- y. j% f$ W& k8 kModifications for ZAPEX types ZZW, ZZWA and ZIW (part 3 and part 1/2 switched) * C5 m" J) _% b7 A* ]# [3 ~
Change of minimal bore of part 2/3 of FLUDEX FAD 516 and 590
x, t5 v* ?4 Z/ X% I g8 O( O9 n- uAt the components 'bolts complete (set)' and 'bolts complete and buffers (set)' of the series RUPEX the special bolt option '[STD] STANDARD' added. 3 h2 f: f m% u' D N: Z
Update for version 7.2.577:
) E. T4 `8 X. {, b) b. _Fixed problems with special bores for couplings
& N+ d! ?1 Y8 d& V/ o4 x: t' D1 W* RUpdate for version 7.2.562: 6 ^( ^$ G( e8 [6 L
Changes in the interface to VSR / SPIRIDON
4 h2 ~# F7 t, P. DExtended selection and options for couplings
f2 X! g X$ O1 CCavex worm and wheel sets from now on only selectable by using MLFB 2KJ1984-0A 1 N0 V6 ~% d/ o* g3 S! v- _
Update for version 7.2.550:
: W% `2 e u, ?& iCorrecions for the options of helical and bevel-helical gear units
( Y/ v# F0 `0 s P' F0 L* t2 eUpdate for Version 7.2.546: ! l k/ u. F; F- t7 f. b
Many changes and extensions for the options of helical and bevel-helical gear units H [2 Q8 Q' I2 w. V C, f
New selection possibility for single parts (FFA) ; c: A) f9 M% @6 H, I+ y
New options for the export to SPIRIDON International and SPIRIDON DE (former VSR)
1 l2 u `* C' jCustomer description from project list is now printed with the detailed printout of each order position
+ d1 z3 ~) \9 c9 c9 L% r8 dAdded column for short description to printout order pos table
, J* P3 D" O5 ?* w5 T. t" _6 y$ VAdded additional text for project to printout
1 h$ n- R! A7 G5 {/ ^( H4 ~& YUpdate for Version 7.2.504: / v# `% ]3 [( K2 c
function for copying a MLFB into the clipboard for inserting into SAP (e.g. stock master creation with PMI )
+ |$ k& N4 g5 U. @" t3 s4 I% Q0 jcopy directly into the clipboard from the projectlist.
. |4 G( C }4 M6 \Helical and bevel-helical gear units: Adjustments and extentions for preservation.
0 I# i% A0 B u0 IHelical and bevel-helical gear units: Adjustments and extentions for ATEX.
0 m9 m" E' Z+ V. SHelical and bevel-helical gear units: Extentions for lubrication, low temperatures .
! X3 _3 b9 G" j' AHelical and bevel-helical gear units: Input field added for P1 in the quick selection. 4 b. u$ t) i. U1 ?" i0 S R& w. ^! v) P
Helical and bevel-helical gear units: The drop down lists in the quick selection now only show allowed values. |
