求美国NACE期刊“Materials performance”中的文章:Corrosion inhibitor evaluation for materials used in closed cooling water systems
, c5 \7 u( ^5 \0 p% h; i4 ~Author(s):MOCCARI A. A.
$ e/ i* c4 u) N$ |Journal Title:Materials performance ISSN 0094-1492
* V: u6 n, e, D B4 c3 f1999, vol. 38, no9, pp. 54-59 (8 ref.)% |; ^+ H: D. ^8 K5 ~$ Q
Abstract
r4 I5 T% M8 [: v8 CElectrochemical tests were conducted to evaluate the inhibition effects of a commercial sodium nitrite (NaNO2)/sodium tolyltriazole (nitrite/TTA)-based corrosion inhibitor added to deionized water at 50°C. General and pitting corrosion of materials commonly used in closed cooling water systems were examined. Tests also were performed in deionized water which Cl- had been added. At the tested concentrations, nitrite/TTA was found to be an effective corrosion inhibitor for all of the materials tested in plain deionized water and Cl--containing water. |
