#FEATURE CORE_ELECTRODE cima-d 8 31-dec-2012 uncounted0 S1 S- \# N2 _2 {
# HOSTID=00138FC66C2C ISSUER="Team oDDiTy" SIGN=6DBC437817BE
/ _6 W9 M, o/ U# E
5 l/ E! u" ?3 W. w) RFEATURE CORE_STANDARD cima-d 8 31-dec-2012 uncounted \
( \0 i% R& e2 ?" E6 h HOSTID=00138fc66c2c ISSUER="Team oDDiTy" SIGN=E68FF3083250
/ M5 [3 l. e/ U2 E! B; ^& gPACKAGE ODT_SHOOT_PACKAGE cima-d 8 COMPONENTS="$oDDiTy 2D-TO-3D \
3 S& k$ { Z' C1 ^ 2X_MILL_LITE 2X-MILL 2X-WIRE 3X_MILL_LITE 3X_SIMULATOR 3X-MILL \5 t; ]9 m3 v) ]5 ]- D* O
4X-CONT 4X-WIRE 5X_AEROSPACE 5X_SIMULATOR 5X_TRIM 5X-CONT \
/ x! \: c J/ B: Z* @4 j: L ABIANT ADVANCED_ASSEMBLY AUTODRAW AUTOMATED_DRILL BEND \0 v) L2 A4 Q* K5 l2 {$ T0 z. O
CAD_MODE CADENAS CATALOGTOOL CATIA CATIAR2D CATIAR3D CATIAW2D \
U( L3 a% q8 T7 }2 P7 d$ h& ^ CATIAW3D CHINESE_TRANSLATION CIMACABLE CIMADEK CIMADEK-NC \# G/ A' _. Y, _& I
CIMADEK-RUN CIMARENDER CIMIT-D CIMIT-M CIMIT-MD CIMIT-MDN \
& C# C3 J/ y8 ~2 |6 F CIMIT-MN CIMIT-N CONCURRENT_DESIGN CORE CORE-M CORE-X CPDM \
& ^2 u5 d9 B) L9 b( Y( t: a* n5 b DIE_BLANK DIE_FLANGE DIE_FORM DIE_LABEL DIE_PLOT \1 n- V1 T& E+ l! a6 I, l
DIE_PLOT_SAFETY DIE_PLOT_THICK DIE_SET DIE_STRIP DIE_TOOLS DMS \7 ~/ V h! d: i. o5 U; L0 D F( l, G! k
DRAFT DWG DXF E_STAMP EDM_SETUP_WIZARD EDM_WIZ_AGIE \
7 A- W6 O/ _' u0 h/ [, \! O3 \" [; s EDM_WIZ_DPC EDM_WIZ_INGERSOL EDM_WIZ_MITSUBISHI EDMS-LINK \
5 u; N/ D/ y8 H! l& s7 R9 B ELECOTRE FAST_BLANK FEM FIKUS_IGUS FUSION_FULL GPF GPP \
1 d2 S/ k2 E/ T, ~) v4 d9 d- ` GPP_DEV_EX2 GPP2_3X GPP2_5X GPP2_DEV_3X GPP2_DEV_DF2 \8 s+ y: T6 v3 p0 B2 \) G v
GPP2_DEV_EX2 GUN_DRILL IGES KINEMATICS LATHE LATHE_2X LATHE_3X \
# g- ~9 F1 h5 W' N LATHE_PP_COMPILER MACHINE_SIM MACHINE_SIM_CONFIG MACRO \- \. O) f$ @2 S! x0 I
MICRO_3X MICRO_5X MICROSCRIBE_IF MOLDBASE3D MOLDDESIGN \
( M& q2 l) g( R2 o: l MOLD-EXPERT MULTI-USER-1 MULTI-USER-2 MX_MOTION_BUILDER \' H a- h6 @) G2 l+ y4 }
MX_MOTION_EDITOR NC_UNDERCUT NC-LINK NESTING NETWORK_ENABLED \; o/ q: M+ p) }1 g2 z
PARASOLID_READ PARASOLID_SAT PAR-SHAPE POST_CONFIG \
8 a: Q8 B9 h& v* _! {" b POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT QCOMPARE \$ v' H Y3 Z0 ~$ h# K, b
QCON_C QCON_Q QCON_S QELECTROD QSPLIT QUICK_NC QUICKCONCEPT \
, n$ ?- u( a/ i: Z4 o& }" r QUICKDRILL R_CATIA_2D R_CATIA_SAT R_CATIA5 R_IGES R_IGES_SAT \
& q6 m4 i' b6 \) ?+ P R_INVENTOR R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT \
+ E- W( j# M$ W1 q( f R_UG R_VDA R_VDA_SAT R_VRML RD-PTC RE-ENGE SHEET_METAL SAT \
* \% L- p, f' Z" W5 G( Y SHOP-NC SIMULATOR SLA SOLFAST_FULL SOLID SOLID-ASSEMBLY \
) {) F' t/ U; V6 I# E. k- N) { STEP_READ STEP_WRITE STL SURFM TACFAST_FULL TEMP_KEY_CODE \
6 |$ p" g6 q9 H/ n UGR3D V_CONTROLLER VDA VERIFIER W_CATIA_SAT W_CATIA5 W_IGES \0 z1 G. S3 P8 t1 _, h7 X" Z' A9 O% l5 ~5 y
W_IGES_SAT W_PARASOLID W_STEP W_STEP_SAT W_UG W_VDA W_VDA_SAT \- l2 C: K; F6 o& w* O+ ?' K2 l4 y, O
W_VRML WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE X-CIMADEK \
- I+ j' x- h( ]6 q X-CIMADEK-RUN" SIGN=A7ECA376CC4E# H& Z8 z s% ~2 I
FEATURE ODT_SHOOT_PACKAGE cima-d 8 31-dec-2012 uncounted \) r- V% q. f! |" M: |) U
HOSTID=00138fc66c2c ISSUER="Team oDDiTy" SIGN=F0E2E9AA038A
7 Q$ v6 j1 p% O0 \PACKAGE ODT_CATALOGS cima-d 8 COMPONENTS="CATALOG_DANLY_INCH \
0 D' o, p: c S9 t( G: A. t: h8 K CATALOG_DANYL_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \) ^4 b; I' O) J2 j7 X
CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \& H* p" F& t" o- P6 m$ }
CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \
# W) S _3 A' d) W4 u* X* \% V5 x7 d CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \4 Q. N8 d7 P2 J6 C
CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \
% S* ?! I8 ]1 u8 V5 U9 c1 c; U* ^ CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \
5 Q/ ]" u k+ B CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \
/ c( i o. } I! e5 h, J0 T CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \
, d5 v! ]" F& k2 f CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \
A: [7 {$ `+ r' X; ?, y) u9 M CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \
* t8 v+ _4 @% s: i9 f. g) Z CATALOG_UNI CATALOG_VAP " SIGN=32AC419C92FC
2 F. M" Q( X& e+ G# Q8 A' |2 HFEATURE ODT_CATALOGS cima-d 8 31-dec-2012 uncounted \0 s+ n$ m) \. i* e+ d# B& g
HOSTID=00138fc66c2c ISSUER="Team oDDiTy" SIGN=2138371EEB281 V1 |2 m' w0 U# \
FEATURE CHINESE_TRANSLATION cima-d 8 31-dec-2012 uncounted \
6 ^7 X( ?/ m' H2 {, \$ m3 R HOSTID=00138fc66c2c ISSUER="Team oDDiTy" SIGN=FB2AA90AD036# |1 b5 p2 o* S0 b+ m! f- g
+ Q) r5 d5 O* C$ ]- H% d[ 本帖最后由 greennc 于 2009-4-5 19:01 编辑 ] |
