查看: 2064|回复: 4
[讨论] UG5.0二次开发中创建一个二维工程视图(大虾请进)
发表于 2009-4-8 17:30:57 | 显示全部楼层 |阅读模式 来自: 中国广西桂林
使用的例子是:《图表详解UG NX二次开发》第11章的例子(11.4.1)4 ~4 n/ N0 P' K4 a& `
: a; a. }# F0 N8 r) L5 e
代码如下:
1 U) S  W7 a1 D#include <stdlib.h>
' x' k5 f  c" c#include <stdio.h>: B! l2 c9 X5 i  K3 e$ D
#include <uf.h>
+ U$ e  \) ?+ l$ e#include <uf_defs.h>
) R4 U# z) w% ^3 Q9 z#include <uf_draw.h>
  f4 |! N' A  ]2 Y1 O( g#include <uf_draw_types.h>+ S0 ?2 a' o2 R7 a: r( s! h
#include <uf_obj.h>! V& U/ K+ n$ t' j/ Y6 b0 j
#include <uf_part.h>
  z' g( g" D1 R# O4 hvoid ufusr(char *param, int *retcod, int param_len)
9 L" E. C1 R4 R( u# v) M4 Q{* q( @3 r# O. F: S+ H$ Y
int         ifail = 0;
$ t! W/ b* [+ R' L2 a. Cdouble      reference_point[2] = {70.0, 160.0};
$ s+ @$ z9 g0 u$ o, ^$ jtag_t       drawing_tag = NULL_TAG;
- S) a, u) W# M( x* Z6 ftag_t       part_tag = NULL_TAG;0 z( L0 F. b/ x  B' L* _
tag_t       view_tag = NULL_TAG;6 Z* M2 X+ H4 ?
tag_t       draw_view_tag = NULL_TAG;! W( ]; v+ B- W' w2 o2 h5 B
char        *view_name = "BOTTOM";9 M/ k1 f1 a7 A* m; @4 W* r
UF_DRAW_view_info_t view_info;8 E/ F1 ~. [  v: T' n9 X* u! X. ]
view_info.view_status = UF_DRAW_ACTIVE_VIEW;7 r* o! H& p0 F) x. {
view_info.anchor_point = NULL_TAG;
+ B! Z8 T0 S& I  ]+ D* dview_info.view_scale = 1.0;! C: R# z( |% }$ Q- S8 r
view_info.use_ref_pt = FALSE;! o$ N2 I6 F8 F: l6 {% [. d6 e
view_info.inherit_boundary = FALSE;
) }1 Z' c( q8 E5 dview_info.transfer_annotation = TRUE;
2 S: v7 C& W; J$ K4 ZUF_DRAW_view_prfs_t view_display_parms;/ R4 V* c, b% T% N1 J
ifail = UF_initialize();0 p& Y( ?0 B+ ^$ |
if( !ifail )
, g# k9 P) I. z' w3 @8 m  P  part_tag = UF_PART_ask_display_part();
3 W9 p0 S  d9 r3 A% c5 Aif( !ifail & part_tag != NULL_TAG )
, d* S9 a3 `/ Q# g% I  ifail = UF_DRAW_ask_current_drawing( drawing_tag );5 {' [1 g3 d+ G/ U0 D
if( !ifail & part_tag != NULL_TAG && drawing_tag != NULL_TAG)1 M* [, Q$ c# ^2 h
{  K3 [) H" @. A( N4 c5 v
  ifail = UF_OBJ_cycle_by_name( view_name, view_tag );
/ d) z. n! |- @' C: Y. q  if( !ifail & view_tag != NULL_TAG )
8 j9 c2 }4 Z  B- Z! [0 \  {
7 r, K0 F' o1 @. t4 n   ifail = UF_DRAW_import_view( drawing_tag, view_tag,reference_point, view_info,  &draw_view_tag );
8 ^7 p  ]% s; e6 h; V& P   UF_DRAW_delete_view_label ( view_tag );* m1 O5 X6 O1 q4 g$ v
   UF_DRAW_set_view_display(drawing_tag,view_display_parms);    ) J/ l/ P- Y8 N9 G" D' X0 z: d
   UF_DRAW_update_one_view(drawing_tag,draw_view_tag);
/ F5 k# G: U- S* w( M( x& P- [9 I  }4 j% h4 x* Z7 J: ?0 Y& A
/ o# C! J# \: S! L8 O# Oifail = UF_terminate();
1 }6 Q" m) L- b}
0 N' \( L+ m- v8 w7 S(以上是全部代码)1 C- M! |/ b: S& I' z. u
1.在投影之前,UG中已经建立了一个三维模型,而且已经进入图纸空间(SH17 u; H+ ~' G# G. F
2.执行ImportView.dll
8 _5 ?6 m, r6 G1 B9 X" \3.应该是俯视图(X-Y平面)出现在图纸上,但是我运行的时候什么都没有显示。
' G) L$ T9 H3 {' K6 j问题:8 I3 S& A; q9 A; }
1.如何进入图纸空间& d, ^8 D! G" f" V
是不是点击“开始”-》“制图”-》确定
7 k$ r; t9 K/ t; b9 G2.请大虾们试试这个例子,在UG5.0下到底可不可以运行。
, D  |. W. ?0 k) ^0 z6 c我调试过这个程序,各条语句都运行了,但是图面就是没有反应。无奈啊!!( w; ]3 X. i  h
请大虾们帮帮忙,小弟不胜感激!! ; ]: `; W/ o5 H
求详细的操作步骤!
 楼主| 发表于 2009-4-9 11:05:59 | 显示全部楼层 来自: 中国广西桂林
哪位老哥指点一下啊!
 楼主| 发表于 2009-4-10 11:07:29 | 显示全部楼层 来自: 中国广西桂林
高人们,显显灵吧。。!@#¥@#!@" G: c9 `; y4 ^' c( @! X
俺呼唤你们~~
 楼主| 发表于 2009-4-10 21:34:34 | 显示全部楼层 来自: 中国广西桂林
最后找到了可能出现问题的原因了。运行到' b( X5 }% ^& ]2 I9 a, I
UF_DRAW_import_view( drawing_tag, view_tag,reference_point, view_info,  &draw_view_tag );. v0 g; j3 p, R/ s
语句的时候调试显示可能出现了内存错误,没有强制跳出。
% N' A" i1 b3 r: u( F! t& v另看到一个英文网站上说UG V15.0修复了一个引入视图错误。
9 P  ~5 y& [/ j/ V' @1 t而我看到帮助文档上写的是V13.0.可能这个错误在13.0没有修复,所以出了问题。
% q% j7 v& @/ x6 L' V2 }3 q2 }% W对于这两个有点疑问。UG5.0到底是什么版本的,引入视图这个问题有没有被修复?怎么才能用上V15.0这个已经修复的版本?
 楼主| 发表于 2009-4-14 11:18:13 | 显示全部楼层 来自: 中国广西桂林
天灵灵地灵灵,论坛高手快出现!!
