那位大哥有ISO9974,麻烦上传一份,谢谢,具体如下:
- \* R. y' y3 w
( ?) Q4 f9 G- B- LISO 9974-1:1996! k& {$ ^. o" y. x9 b5 J7 O
Connections for general use and fluid power" g X a' w; T6 c7 U% O5 `, T+ Y
( Z7 ]4 {" }. H+ I0 JPorts and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing
$ k3 }6 h. v# w3 Y" m( W- Part 1: Threaded ports 用于一般用途和流体传动的管接头-带+ P, l0 a7 }5 u4 N0 z
ISO261 螺纹用橡胶或金属密封的油口和螺柱端-第
% {2 {7 _; \; A0 _1 部分:螺纹油口 ISO 9974-2:1996
4 X3 [0 o- G+ a7 @; vConnections for general use and fluid power
0 N& P9 K! T& c5 _6 G% T+ E- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing9 Z7 s% Q/ U$ w% R! i4 g
- Part 2: Stud ends with elastomeric sealing (type E) 用于一般用途和流体传动的管接头-带
6 ^* q" S' h: ~" `! p0 p5 }ISO261 螺纹用橡胶或金属密封的油口和螺杆柱端-第
3 k- z+ d- s9 k b9 m& t9 b9 e2 部分:带橡胶密封的螺柱端(E 型) ISO 9974-3:1996
- V8 _! {, ?, {1 u) M1 [( O; fConnections for general use and fluid power
! Z; u( m" [6 B& C- Ports and stud ends with ISO 261 threads with elastomeric or metal-to-metal sealing
4 ~) ?" b' ?$ S3 l9 Z; {% J+ y6 y- Part3: Stud ends with metal-to-metal sealing (type B) 用于一般用途和流体传动的管接头-带& x* Q: Z) c4 |& W" z N4 z6 B2 Z
0 ]; E- { c" P4 V! x3 部分:带金属密封的螺柱端(B 型)
5 w- U. U' [) w: e% g4 z 2 _+ Z# Y6 x* S1 P/ N) D
ISO9974-4:2006" {& P2 m, m: d
Connections for general use and fluid power; k+ ^, X e3 k) u
, C- F" v& t# t: @- Part 4: Dimensions, design, test methods and requirements for external hexand internal hex port plugs 用于一般用途和流体传动的管接头-带
! |* x. u! e( oISO 261 螺纹用橡胶和金属对金属密封的油口和螺柱端-第
9 N0 y3 _, `* u+ | u4 部分:外六角和内六角油口螺塞 |
