楼主 |
发表于 2009-4-24 10:00:32
来自: 中国黑龙江佳木斯
初次上传,总照顾不周,决定取消权限
版规也非常仔细看了,但是第一次上传书籍的时候还是丢三落四,照顾及此,丢了彼处。重新回复编辑,取消下载权限的限制,并且重新上传,压缩包内容与一楼完全一样。自己以后也会多学习经验, 并为给论坛管理人员和论坛其他朋友带来的不便,深表歉意。% ]; t6 S7 r: M; P. O& W0 c
《Crystals and Crystal Structures》这本书是由Tilley所著,在晶体材料领域影响比较大。这次版本在2006年再次发行。 将其压缩后制作为两个压缩包。 主要目录及封面摘录如下,供大家参考:
& N% J, x' L( Q: u2 GContents2 T- P2 X9 K& a4 J$ P: ?
Preface
) y; `9 a5 q! ^8 _; |+ X9 E1 Crystals and crystal structures
+ l/ _8 v5 Z8 i/ r! j1.1 Crystal families and crystal systems
0 N6 q1 ^* H" r. n0 n+ t7 n* ?/ L" z1.2 Morphology and crystal classes9 Y$ t, _$ U& ]3 m+ n
1.3 The determination of crystal structures
" D( D: ~& i% a1.4 The description of crystal structures
2 h. o0 v% H+ h( Q1.5 The cubic close-packed (A1) structure of copper
9 \' ~0 o5 N+ V% G( ]) `1.6 The body-centred cubic (A2) structure of tungsten8 e) ~5 K' I1 y8 p4 F" F1 f
1.7 The hexagonal (A3) structure of magnesium# K- l8 |% @& E5 M6 Y
1.8 The halite structure
" W& s( c1 h; d& U. t% b) p8 y% j. Y1.9 The rutile structure
& \1 x9 G O c/ e, \$ ?1.10 The fluorite structure
7 S+ P$ N, ] j6 O; L7 W0 ]1.11 The structure of urea
7 \; b1 Y1 q- R% i1.12 The density of a crystal% l3 R. @7 G2 F' S
Answers to introductory questions
; M( @1 B% B8 iProblems and exercises
. n; x8 q* M- X1 p& s1 n5 L2 Lattices, planes and directions8 Z) ~+ v# S! [" h) n5 w
2.1 Two-dimensional lattices+ W8 G- f5 A5 I W4 {; L9 C
2.2 Unit cells
5 n4 x) d: _, A. a1 D, n2.3 The reciprocal lattice in two dimensions" o4 d" M" A' W
2.4 Three-dimensional lattices
: N5 z" G' \( M2 x5 G/ z2.5 Alternative unit cells
' ~3 b9 G! p( R8 Q- i2 U: l% D; t3 [2.6 The reciprocal lattice in three dimensions
- z+ K3 d) O% R: _. T2.7 Lattice planes and Miller indices. o z/ n3 k, |; \8 l0 `4 L
2.8 Hexagonal lattices and Miller-Bravais indices
2 o0 U( V7 {/ l" C% V5 R# }2.9 Miller indices and planes in crystals7 H# b/ W! V6 i9 w! W
2.10 Directions# y5 I* g- U: ^, I+ e. @6 Z- O
2.11 Lattice geometry8 b' m- R# Q$ D# s' Q* r& u" [
5 Y+ \3 B8 Q# `% K- M5 vProblems and exercises
# i9 z( b$ r) r& `) M* e3 Two-dimensional patterns and tiling
! I) R+ `8 G5 A2 S8 j8 e3.1 The symmetry of an isolated shape: point symmetry
; D; I5 v4 l& M1 \3.2 Rotation symmetry of a plane lattice, }7 W3 `9 K6 x% F; I p& i
3.3 The symmetry of the plane lattices: [/ ]) }: f5 ~: I
3.4 The ten plane crystallographic point symmetry groups$ q+ U/ Y. g" S: P* X1 Q/ H
3.5 The symmetry of patterns: the 17 plane groups. a1 c2 Y0 z: i. P3 H& t
3.6 Two-dimensional ‘crystal structures’6 }9 \8 [2 H* R% y/ ?. K4 t
3.7 General and special positions
I3 s+ @, p4 `1 @9 v* A* `8 e3.8 Tesselations% f& v+ o* s0 A( }) e
Answers to introductory questions9 e6 ?7 o5 _# l# N# K
Problems and exercises$ M# Y7 \( x) I# \9 W
4 Symmetry in three dimensions
" J( b" P* i* A4.1 The symmetry of an object: point symmetry8 G" v# L, k* \, a# |
4.2 Axes of inversion: rotoinversion' m+ b5 e0 z( h- Q- I* g
4.3 Axes of inversion: rotoreflection W% o2 e! {5 e, F" _: c% m
4.4 The Hermann-Mauguin symbols for point groups
% I. n1 X# k6 m" F4.5 The symmetry of the Bravais lattices& v4 E5 H' J/ Y; ^6 y! j1 z
4.6 The crystallographic point groups
/ u l/ t0 x! \2 ]2 ~0 H6 @$ b4.7 Point groups and physical properties: N M$ ^: e, z% g9 a
4.8 Dielectric properties
h2 L, s0 N$ i5 A4 _6 Z( D6 K4.9 Refractive index5 C; c& G4 |: ^% W7 P
4.10 Optical activity
, b6 J, _; p% ^7 ~# ?4.11 Chiral molecules. _: W9 n4 k% o; m, [6 m! v
4.12 Second harmonic generation
& p) Q' e9 V7 j3 c4.13 Magnetic point groups and colour symmetry( y! n' x+ _# Y) x$ w/ C
: J1 r' R) O$ v4 ~7 u6 @Problems and exercises3 `; m0 l/ s# C# T0 ^
5 Building crystal structures from lattices and space groups
+ q* v4 ?6 H' E$ K: O5.1 Symmetry of three-dimensional patterns: space groups
) X2 K, P; n' S# s& K5.2 The crystallographic space groups
/ f7 K/ i" ~3 P: P% ]8 N/ J' d5.3 Space group symmetry symbols0 X2 r6 U% z( g2 v6 Z' K; r
5.4 The graphical representation of the space groups
0 z+ U& R+ m5 p5.5 Building a structure from a space group
. o4 ? u! G, g5.6 The structure of diopside, CaMgSi2O6% m1 ^# d l$ O2 y* Y
5.7 The structure of alanine, C3H7NO2! Y. C' G+ [" H' b- K
, y9 R0 |) c% M5 f8 SProblems and exercises- h6 {: |5 v% o
6 Diffraction and crystal structures0 ]- ~/ P( f( k! v% J5 S. Y
6.1 The position of diffracted beams: Bragg’s law
; ]: n4 k; @ F+ f% j6.2 The geometry of the diffraction pattern
# J: q; Y. Z" }5 T6 l; Z6.3 Particle size' N. \2 j* Z6 g$ l, P3 Q0 \
6.4 The intensities of diffracted beams
7 h) y4 ^6 J( G p6.5 The atomic scattering factor. d |/ Y, b( s( r! W% Y# G
6.6 The structure factor
/ q+ L9 h0 [. ^. o6.7 Structure factors and intensities
; N z1 d- A2 l6.8 Numerical evaluation of structure factors W: x- a: M+ u/ U( d7 x5 o
6.9 Symmetry and reflection intensities4 L0 p- `( }" D
6.10 The temperature factor
6 Z; U. l8 N% x5 N9 [9 Z# l6 k, z6.11 Powder X-ray diffraction9 w3 ?$ u4 f) P1 j5 s3 k
6.12 Electron microscopy and structure images4 n5 }1 M. F' T, [
6.13 Structure determination using X-ray diffraction
' p1 C+ A7 z3 V. e- [4 x9 _6.14 Neutron diffraction
: \% f+ L- \0 q0 M9 Q4 F6.15 Protein crystallography7 J; q+ n# z0 W, G7 C _
6.16 Solving the phase problem
c9 P' q k. J2 y; m4 C6.17 Photonic crystals
/ n5 x3 Q1 ~8 T4 N/ dAnswers to introductory questions+ f ?; n+ @. j2 ], E. @9 y0 w7 J
8 `/ Z% I% Y* _2 `& f7 The depiction of crystal structures, D* }4 g2 b4 r% O1 R& u9 V
7.1 The size of atoms) d/ K; |. Y& T1 ]! p% Y
7.2 Sphere packing
+ e* T( I. [* @$ I9 j- e2 E7.3 Metallic radii
* l; r; z5 r$ A9 M9 ~- c( O7.4 Ionic radii
^4 W# M: O( j6 j( j8 c7.5 Covalent radii. L8 y8 ]1 _; h2 n) ~
7.6 Van der Waals radii
) a$ u8 @/ p2 Z7.7 Ionic structures and structure building rules; y% C9 C Z0 B" k& n4 X' S
7.8 The bond valence model
8 ?; M. Q7 Z* q0 n7.9 Structures in terms of non-metal (anion) packing& ~. S( [, S# ?' o$ H$ M+ l8 s9 R
7.10 Structures in terms of metal (cation) packing
7 x; h! F9 _0 {0 U% f7.11 Cation-centred polyhedral representations of crystals
( q+ J2 v. J$ L) D7.12 Anion-centred polyhedral representations of crystals) q7 H) N2 G2 e5 m0 q a
7.13 Structures as nets* B( X* ^, q, i
7.14 The depiction of organic structures6 {0 r$ m3 i; ~! ~
7.15 The representation of protein structures3 c8 g3 T( n9 R. p
Answers to introductory questions$ d& P* a& l) h# n0 C3 } U }
Problems and exercises. N5 O- a$ K$ a) i1 a, C. j% P
8 Defects, modulated structures and quasicrystals
- e0 j8 ~# J5 x6 t! q# s8.1 Defects and occupancy factors
+ T/ O8 v2 r7 Y3 J8.2 Defects and unit cell parameters
- F4 S0 _3 h: H1 H% U+ a; }1 N8.3 Defects and density3 z0 c* P1 t/ h) @4 e
8.4 Modular structures
; ?! n! k$ W0 h4 \8.5 Polytypes+ l9 u5 e: t8 Z
8.6 Crystallographic shear phases+ I5 c5 r% K+ z& ^
8.7 Planar intergrowths and polysomes4 |8 o* A y6 L; k5 j3 O
8.8 Incommensurately modulated structures
& k8 S- m3 V$ R& {8.9 Quasicrystals0 F9 [# F3 t1 R3 y1 r0 n$ N
) @5 N& G2 p/ m5 d7 p; ^Problems and exercises
9 Z Z3 q$ m7 s3 f3 ^2 u3 |Appendices, r! N! `/ W) D5 X/ \
Appendix 1 Vector addition and subtraction8 c3 Z& v# }: g0 ]( T s' }
Appendix 2 Data for some inorganic crystal structures) K' h+ a1 {4 ], J Z' c
Appendix 3 Schoenflies symbols1 ^) p/ I$ R& C4 {& r: T" _, D
Appendix 4 The 230 space groups4 m% w& V% t* P
Appendix 5Complex numbers/ z/ r: M, u' l
Appendix 6Complex amplitudes+ a( x: |# C4 L E
Answers to problems and exercises
& |* O/ q/ ], t8 M( G0 u- kBibliography3 ?3 a& l& \; K# {. n. {% u+ C
Formula index
5 H1 b5 B$ q+ p: n. x) }Subject index |
