发表于 2009-4-27 12:08:24
来自: 加拿大
If you use " 5-Axis Multi Surface" function: Tool axis control - 5 Axis, Tilted through point, 刀具旋转中心 give by youself.
, P" ^4 |* l" P* ]$ RBut I'm not sure I get your question point. Which type 五轴机床 machine in your co.: table-table, head-table, ...etc.. You need let us know first. |
