查看: 3626|回复: 11
[分享] 09年4月最新SolidEdge ST(v21) 32位补丁SE-STmp6.exe下载
发表于 2009-4-30 16:07:08 | 显示全部楼层 |阅读模式 来自: 中国广东佛山
6 s" ?! N* a/ m- D6 M; Lhttp://www.ugst.cn/download/SEMP6.rar1 {/ {( }! m! @( v( w
  主要解决问题:. P: [5 a$ n& h) L" U" f: f+ W
8 v5 E9 f; a) }4 {Legal Notices7 A' Z! E5 z# \2 g7 ~& K" _
* p+ m( k( x( r( u©2009 Siemens Product Lifecycle Management Software Inc.
1 ?$ [3 N4 y# H" C$ E5 v
( J6 i$ y' g. t' |2 SAll Rights Reserved
: b" p, N; i! [* z5 CSoftware, file formats, and audiovisual displays may be used pursuant to the 9 @3 t' h9 q3 a
applicable Software License Agreement and contain confidential and proprietary
! F) N7 k9 |. x* X4 F" cinformation of Siemens Product Lifecycle Management Software Inc.; which is
& L) J+ H" |  k; o/ Rprotected by copyright and trade secret law. Such materials may not be reproduced . `; Q! T& {! k0 h7 S: O( z
or transferred to other documents or used or disclosed to others for manufacturing 1 e! n; b5 h/ U7 {$ F4 }/ Z# A
or for any other purpose except as specifically authorized within the terms of the % f9 o+ |4 ]4 D4 @5 z
Software License Agreement, or as specifically authorized in writing by Siemens & O' H2 u. _* d4 Z$ ~, ^: v9 ]& {
Product Lifecycle Management Software Inc.  y$ f- B; d  F& g
& q6 F2 V8 Z) u8 q* N/ h
! v, ]3 y+ f; B5800 Granite Parkway
. u% {( |  r4 J7 D' P3 `Suite 600" f; o/ K/ Q5 l) E& \% x1 |
Plano, TX. 75024
2 B1 R9 T) w9 n5 b7 [9 p
) y4 {, B& Z7 i7 p8 {4 e8 a0 H$ u: M' |" P0 T) {
--------------------4 C- ^9 @& V$ L5 G! s3 |
End of Legal Notices
2 B6 ]% F$ L- d3 [" U. ]% H! ]--------------------# ?8 _1 D/ s. P9 @" u
. i1 n; \6 b, _* m
--------------8 c5 i+ p2 u: g8 y1 S
Release Notes:/ I. d9 v. g6 W! X# R& G
$ Z- M  W, N" U+ b: X" a! i, Z9 m4 v5 B. A4 H! V& \# ^1 W, v' i
Product:        Solid Edge ' K$ P; }, k; I, F) S7 C5 g
Version:        100.00.06.03
2 k/ K$ T3 S6 f0 @7 M5 p1 zDate:           15-Apr-2009, K7 b  U- [! i9 Z
  `6 c2 C: H: }+ n/ r6 }This Maintenance Pack can be installed on top of Versions: : ^; i7 A( j3 p$ j0 Q) X/ Q
100.00.00.133, 100.00.01.07, 100.00.02.07, 100.00.03.03, 100.00.04.04, 3 a& v1 {' Q$ q! x& w; |- e
100.00.05.04# Q5 ^* b  v, I" ~9 m
( S5 k! K7 s- u+ w* }4 k& E2 ~* [Note: Maintenance Packs are all inclusive and can be installed on top of the base & t$ M# y9 C/ R$ }: N0 y) Q/ q8 B. l
release or any released Maintenance Pack.
5 y& f# K3 b/ m6 D$ e1 E7 J& g$ p
( w  `- [7 w6 K4 C--------------------: b/ \( G3 o# Y& g: h/ [9 M
End of Release Notes( O. `1 G6 N- b+ e2 z8 @! o) f
--------------------: s& D- j; V( \( v! X& _/ G9 n
. ?$ m% I3 e4 E
2 X* T, J. T1 kInstallation Notes:
4 L6 t7 n7 R& I9 `# {% G-------------------6 P; u5 A1 u3 Z. p! X# H. E2 n
- z0 j* }, [4 x4 V/ s, D- t9 BAfter downloading the Maintenance Pack to your machine, dbl click the downloaded 0 z6 P* k% a- ?$ s# N# n' m; x& |
file and the Maintenance Pack will install.
1 o+ t7 u* f* M6 ^8 G. _* |2 |
* _/ f2 S- I+ V% i- l, K0 p) K-------------------) R% d" o4 H) E# F& k$ X
End of Installation8 U" |. U  X2 e9 Z% k( s/ y& o
- x7 d9 s. J0 O
; |8 z, e; E: R2 n" U$ N--------------------------------------------------
* h' g8 d: v" r3 p& E  n( KThis Maintenance Pack addresses the following PRs:
, H) A- a( `3 l$ p* \) H--------------------------------------------------
- N/ V& W) O3 G) f9 P: P2 T
( I, P: x4 F7 P% K=====Assembly=====
1 d. x3 B' W, Z! H* M1 s# Y
7 g9 ?# A" b: K8 KPR 6097501: Weld features failed each time the weldment assembly file is opened
) Z4 j5 `) w, B0 yPR 6101187: SAT File Fails to Open
8 i7 k! H, @! [4 U4 nPR 1713572: Reference Feature step selecting faces instead of entire feature6 d8 @4 K( W  y: t% g% H) m/ A
PR 6069017: Assembly aborts during open2 h1 L' |: S8 J8 k5 B1 N
PR 6111867: Unable to select individual sketch items when IPA into sub-assembly
! L/ b+ B& @3 }8 ^! O' m+ b3 F$ GPR 6119191: Solid Edge hangs when opening this draft file3 w4 l& s4 L9 Q; B* o
PR 6124646: When translating Catia assemblies, curves, surf's, and solids are lumped together
  L8 I2 F) H6 V1 Q9 o- O) c4 \  n% l9 ]
=====Part/Profile/Sheet Metal===== 9 S+ o3 V7 z& }0 W4 o
$ P) V* i) |9 V0 jPR 6101666: Running quickly out of memory on a 64 bit machine (SE 32 bit)
0 E% O! z% W% \PR 5983131: EMS Translator fails to import any file% p$ k  w7 M* k2 p1 S3 N
PR 6119137: Solid Edge (French) crashes when moving cursor over Quickbar Single/All button
( t' X+ |: x* X: [! JPR 2118948: File hangs at the splash screen
% l: u% Z$ Q- B3 [6 zPR 6118550: Mouse Scroll wheel on edit should adjust value of a round by 5% of initial value
9 @3 t7 V4 P( f! _- K0 C1 S
7 l* B1 g& ~8 ~% p! r3 `, `# \/ O=====Draft=====
& H) w2 w5 a5 p  F! `/ x
# q" Y1 ^) T' DPR 6123655: can't extract bodies from MDT files
  l4 a: D/ \6 k" N+ v% v- nPR 1643072: Unable to save a PDF file from Solid Edge to a path with a comma; v4 Y, ?' Q$ U7 f" W( I
PR 1694065: A scaled dimension is no longer scaled after being re-attached0 n& m8 J" B# q/ H6 d
PR 1711103: Solid Edge will export elliptical arcs as splines
) @; g6 q$ |! \
/ e2 G# X* o. O===API===- H9 L* F3 R7 U$ a$ U
' q+ x3 U6 b  h0 w0 ~% H7 F
PR 6098711: SelectSetChanged events not being fired properly from select tool in Synchronous. m4 O0 D% f2 l; a. {3 |
0 A6 e1 M4 R/ v5 I: ^$ S* H2 A& F===Insight/View & Markup===
" r0 F% j: K: W3 A
1 W. p9 b! V( }0 P: j( y: n& D* e2 r" _PR 1720400: Cannot open Parasolid files in View and markup with Hebrew filenames* @1 o- H- ?5 N# @
+ Y) }" Z! d: d2 L8 V/ y4 X
=====Embedded Client=====
7 h, `- W% J  d7 J7 t9 I9 a( Y
; A: t9 [( ~% w* O& Q& R1 c8 l( ~5 p# ZPR 1678740: The Dataset Keep Limit is ignored
/ S' C& {* u, \2 d* j0 a) y8 N) c- ]1 b! S; \PR 1691073: if the query from Solid Edge contains an Integer LoV the search results are empty
$ y3 \# P7 R9 G" z6 m+ EPR 6023631: When an assembly is viewed via PSE the assemblies JT override file is not used" ]; X3 w. d$ V4 S* X3 l& v
PR 6125319: JT overrides created by SEEC do not contain BREP data as specified in the ini file3 K6 L1 f% K5 C
0 q" w* O; k  N---9 Z. D- r# ?: g% l1 S2 ?& x& L  F
End
msyanzi + 2 好资料,感谢您对论坛的支持!
发表于 2009-4-30 19:23:19 | 显示全部楼层 来自: 中国上海
坐沙发,好东西快下载吧
发表于 2009-4-30 20:54:24 | 显示全部楼层 来自: 中国广西钦州
楼主是个大好人,谢谢
发表于 2009-5-1 06:18:41 | 显示全部楼层 来自: 中国辽宁大连
正在下载,谢谢分享。
发表于 2009-5-1 16:06:03 | 显示全部楼层 来自: 中国江苏
楼主是个大好人,谢谢
发表于 2009-5-3 22:24:54 | 显示全部楼层 来自: 中国陕西西安
已经下载了,多谢提供资源
发表于 2009-5-4 08:27:39 | 显示全部楼层 来自: 中国浙江宁波
非常感谢啊,(*^__^*) 嘻嘻……
发表于 2009-5-6 01:00:10 | 显示全部楼层 来自: 中国山东临沂
为什么不能安装?
发表于 2009-5-6 01:04:42 | 显示全部楼层 来自: 中国山东临沂
求助SE 补丁安装
出现:“failure opening New File :c:\progra~1\SOLIDE~1\Program\RTF42500"后就无法进行安装了
发表于 2009-5-6 11:27:39 | 显示全部楼层 来自: 中国山东济南
原帖由 cecey123868 于 2009-5-6 01:04 发表 http://www.3dportal.cn/discuz/images/common/back.gif& \1 e0 b* m4 ~9 }7 ~
. W) j0 x/ h& w7 X: W+ s8 j8 G请问你是什么版本?怎么V20和ST的补丁都安装呢?2 ?% X; Z6 \" z/ i. E- s
不出问题才怪呢。
发表于 2009-5-6 16:58:39 | 显示全部楼层 来自: 意大利
楼主是个大好人,谢谢
发表于 2009-5-21 23:59:43 | 显示全部楼层 来自: 马来西亚
谢谢分享
