nanyuchun@yahoo.cn这是一个很简单的零件,我录制后再运行就报错了,说有些变量未定义,这是怎么回事?求高手解答。
: ^; `+ G( v1 |! [5 H ******************************************************************************
$ j+ i4 j4 x- y) [ Y, y' x' C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\swx1532\Macro1.swb - macro recorded on 05/06/09 by Administrator
9 O6 q7 x, G2 u# |& P; V' ******************************************************************************
5 r, z8 [ H l! M/ r, s6 m8 SDim swApp As Object( o& a0 `2 n7 \1 ]! r+ Z# p
Dim Part As Object
' u) ?8 P$ \( k+ Q# o( C4 G( jDim SelMgr As Object
) }2 h0 n( @+ T; _6 n1 {" DDim boolstatus As Boolean0 x; L0 m* g5 a3 D! N% j9 n
Dim longstatus As Long, longwarnings As Long" E! C" z! V- E6 _
Dim Feature As Object
3 P' w0 E0 p+ s. LSub main()
, R- N8 n+ B" [8 s) w2 jSet swApp = Application.SldWorks) [2 [2 F/ N/ j! _9 z0 M
swApp.ActiveDoc.ActiveView.FrameLeft = 0& U( N7 Z+ K5 e% k
swApp.ActiveDoc.ActiveView.FrameTop = 01 `4 E( f$ ]2 G6 O( D; ~. C7 s- E
swApp.ActiveDoc.ActiveView.FrameState = 1! q) B# E$ Q' D+ w- ^9 U% B
2 r& f9 E% i4 D' vSet Part = swApp.NewDocument("C:\Program Files\SolidWorks\data\templates\零件.prtdot", 0, 0#, 0#)$ Z# H8 j* y$ U
Set Part = swApp.ActivateDoc2("零件5", False, longstatus)4 M6 k- n9 Z+ ]' D) u
boolstatus = Part.Extension.SelectByID2("前视基准面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
: D+ `. w1 G. T& a8 [/ N. x0 HPart.SketchManager.InsertSketch True+ P# o% F- H" V9 q7 S- j1 y
Part.ClearSelection2 True& U; v; a' b7 x
Part.CreateLine2(0, 0, 0, 0.1317605328377, 0, 0).ConstructionGeometry = True: s0 ~; v5 }7 U, @
N4 o+ B4 G% y8 r* wboolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0.07370563816605, 9.363692688971E-04, 0, False, 0, Nothing, 0)
& w3 M9 |3 y3 t2 e/ g+ S9 q9 E, HDim Annotation As Object$ ]9 M8 M) p: O& [
Set Annotation = Part.AddDimension2(0.0696926, 0.00815979, 0)
1 W2 _5 Z Y4 U$ L9 N: b5 H9 uPart.ClearSelection2 True Y( i& [, D! E, r3 ?
Part.Parameter("D1@草图1").SystemValue = 0.825
; Z; d5 m+ Q, ^' R2 MPart.ViewZoomtofit2! E% u7 x- }, o
Part.ClearSelection2 True, m# x: a' B% o" x
Part.CreateCircle 0, 0, 0, 0.06623296158612, -0.05652973977695, 0
- k6 \1 U* `3 L& V- OPart.ClearSelection2 True, R6 V0 u3 {% E! d$ O; {2 Y
Part.CreateCircle 0, 0, 0, 0.02849029326724, -0.04599690210657, 0
9 A9 _6 K/ Z7 |2 l5 {Part.ClearSelection2 True
/ q! D1 x+ A% V" P, B3 uPart.CreateCircle 0.825, 0, 0, 0.8412742668319, -0.08637277984304, 0
9 b3 K ]7 [ B- z- U1 UPart.ClearSelection2 True8 d$ F3 P/ R: `0 }+ @* U( [: r
Part.CreateCircle 0.825, 0, 0, 0.8307414291615, -0.0468746385791, 0" w3 F0 |* @5 b' W6 i/ |# e M
Part.ClearSelection2 True. H$ R9 p9 U" U; q& { d
Part.CreateLine2 0.06623296158612, 0.05, 0, 0.775, 0.05, 04 C: u9 {$ n1 s7 ?
Part.ClearSelection2 True4 m4 j2 P, G: ` x+ R9 V: t' t; ^
boolstatus = Part.Extension.SelectByID2("Point8", "SKETCHPOINT", 0.06623296158612, 0.05, 0, False, 0, Nothing, 0)
/ p& X# o8 `! P: g9 I3 s! W, L8 sboolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0.07676579925651, 5.231309376291E-04, 5.000000000005E-05, True, 0, Nothing, 0)3 I5 x( n, G+ ?3 L
Set Annotation = Part.AddDimension2(0.293567, 0.0259775, 0)4 {& c; h# k2 R
; B0 r/ N" y; ^- ]. u+ |Part.Parameter("D2@草图1").SystemValue = 0.0425
" [* I9 W# W! @) {0 N) M; V+ Y5 |5 [Part.ClearSelection2 True! R/ V& |+ n* ~% Y! {1 k* r
Part.CreateLine2 0.06623296158612, -0.04775237505163, 0, 0.775, -0.04775237505163, 01 y# D, z: S2 V u3 n
Part.ClearSelection2 True3 `6 E7 c: G5 Q7 t
boolstatus = Part.Extension.SelectByID2("Point10", "SKETCHPOINT", 0.06623296158612, -0.04775237505163, 0, False, 0, Nothing, 0)
5 V, O5 S) Y' X* v" s; Bboolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0.07676579925651, 0.001400867410161, 5.000000000005E-05, True, 0, Nothing, 0), F) [' N' O0 S. y6 Z/ j
Set Annotation = Part.AddDimension2(0.340964, -0.0284422, 0)- y1 B1 N: \7 D+ l) D% L% c
. S8 p$ G, O2 C9 f1 g: a6 APart.Parameter("D3@草图1").SystemValue = 0.0425! [# Z' ?1 N c& l" Z- E
Part.ClearSelection2 True, j' ~# ?+ X! i/ s: n7 |
Part.SetPickMode
0 ^0 [3 v8 o$ h, vboolstatus = Part.Extension.SelectByID2("直线2", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
% J+ X& T$ d: l1 Z6 jPart.SketchManager.SketchTrim 0, 0.06974390747625, 0.04440995456423, 0
. \2 y: _9 }2 g) o# B, A0 pPart.SetPickMode
4 N, {5 d$ A% Q" k% _boolstatus = Part.Extension.SelectByID2("直线3", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
: L% k X h' L0 e1 xPart.SketchManager.SketchTrim 0, 0.08027674514663, -0.0442414291615, 0
# x+ ^6 n' h$ fPart.SetPickMode Y. i! @8 A1 M4 l; w+ G1 A6 A
boolstatus = Part.Extension.SelectByID2("直线3", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)4 z' D7 a8 @$ V# q: z# _
Part.SketchManager.SketchTrim 0, 0.7631557207765, -0.04160821974391, 0/ y+ ~: F- d$ ^7 G
Part.SetPickMode
- w( ?+ |7 \7 P5 p% a8 O/ d: Rboolstatus = Part.Extension.SelectByID2("直线2", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
: N; b- M% I2 E, m7 DPart.SketchManager.SketchTrim 0, 0.7552560925238, 0.04265448161917, 0
' a: j7 ]7 ^. g( l1 X9 }Part.SetPickMode
) j$ o! x1 P7 o- I; Jboolstatus = Part.Extension.SelectByID2("圆弧1", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)$ g; @1 P9 D# g& Z
Part.SketchManager.SketchTrim 0, 0.09432052870715, 0.03036617100372, 0( L9 K5 Z b* V- t
Part.SetPickMode
9 e; b/ J6 c/ p, G' ~boolstatus = Part.Extension.SelectByID2("圆弧1", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
! H/ ]" W, ^: w0 \8 Y" \% TPart.SketchManager.SketchTrim 0, 0.09695373812474, -0.02580896323833, 0
# t8 K2 D+ Q L3 b5 R5 Y' xPart.SetPickMode( ?1 v% Z1 e( i4 s; _! a6 Z* [
boolstatus = Part.Extension.SelectByID2("圆弧3", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
% k3 c. J" ^& g! i* Y/ N7 oPart.SketchManager.SketchTrim 0, 0.7254130524577, -0.01352065262288, 0" ~/ A% v8 E! u' l2 V
Part.SetPickMode
, b5 D9 |+ n: d9 s* D. R- Hboolstatus = Part.Extension.SelectByID2("圆弧3", "SKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
9 e! L: Q) ?; @2 J% u# UPart.SketchManager.SketchTrim 0, 0.7262907889302, 0.02509975216853, 06 u& |9 U) j& p0 p: W/ S" s
boolstatus = Part.Extension.SelectByID2("草图1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)) t( o5 u5 R% g) a1 O8 G. k
Part.ClearSelection2 True7 \" F. l, Q3 z+ g1 a
Part.SketchManager.InsertSketch True4 z2 C* ^- A& a$ T& D
Part.ShowNamedView2 "*上下二等角轴测", 8
1 U5 c% W$ S, y6 XPart.ClearSelection2 True( F. ~9 \) i6 U4 f
boolstatus = Part.Extension.SelectByID2("草图1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)9 t0 Y0 h6 u, H2 O/ h" w3 W( U
Part.FeatureManager.FeatureExtrusion2 True, False, False, 0, 0, 0.07, 0.01, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, 1, 1, 1, 0, 0, False7 y( _. O1 r7 y- I
Part.SelectionManager.EnableContourSelection = 0/ {* t$ ?- a4 O0 { c( x) }& H
End Sub |
