查看: 1549|回复: 1
[已解决] 德标1.1172对应的国标材料是什么?
发表于 2009-5-7 15:27:29 | 显示全部楼层 |阅读模式 来自: 中国上海
如题:
/ t6 \# p$ H, N+ P! E碳钢材料1.1172对应的国标材料是什么?
8 s1 X/ Y$ J' Z以下是一些参数:
7 V  o6 T3 W/ ?' G
Composition
0 q8 H9 U& I7 t# u
http://cid:image001.gif@01C9CD98.0E12DC90# S8 W5 v1 H; }* ~4 q
- s% l( a5 r' e- b
6 a9 K; ~( {+ u* D7 F, }
Element
) B# j! ^5 ~$ H
Weight % 4 E. v( b& \3 r& i5 `) q
" M2 m- j) F9 ~
0.28-0.34
. i. L& \7 u9 Z& X6 a
3 t) O+ r  p0 o8 ^* x
0.60-0.90
4 N# B/ W6 E( Q3 a5 t- C
) x" y5 |8 E" F
0.04 (max) 1 q- N1 _: ~; W1 z" o
$ ^9 L. \9 X/ P
0.05 (max)
7 P. {, D. |% c6 r3 E3 i1 A) ]
: _3 ^0 Y1 R$ V7 L/ I( y& |7 _
+ c! h" E; t8 k6 x7 K/ s
Mechanical Properties
# }3 c6 `: I; Z' M3 A0 W) g
" O1 z$ c8 U, ^5 m+ {3 U# N
; z' p" q0 r8 y" F. I7 W3 G$ X7 c1 C
Properties
) A- c6 I( k! j3 k& Y
Conditions
2 o+ h5 @3 Y7 p2 N/ \. \3 u
T (°C)
5 @. ~6 D# w- q- s4 M* q
Treatment
* Z; a, w% v) Z0 b( B' |" C
Density (×1000 kg/m3)
0 V7 `# D7 O) p3 {4 c0 R1 z6 k
7.7-8.03
6 V2 O* z( U% i4 S% @
# @4 T+ Z1 ^! P' ?$ }4 o$ H9 w
6 ^- ]% Q& r7 e6 }6 j7 ~7 f
Poisson's Ratio! A8 A5 {* D6 k$ W. H/ M$ ^
0.27-0.30
& w, d, u3 |  X5 t, C, M' @
& \' t$ c) }+ q
; r, `, V! z3 l
Elastic Modulus (GPa)
) t- l% y) f$ X1 A6 |6 H& ?- p- O# B
190-210 0 B5 t4 Q2 A; q6 S  q( ]4 C
5 a7 k7 ?5 R: @/ M  B" d0 j* E
! d" Q' g. l1 ]( i
Tensile Strength (Mpa)6 m) Q% p. }" D+ z7 R# `4 S* j5 L
463.7 , h8 e% V8 O+ m  e  {
+ D* A* {7 g! X3 H& ?+ m
annealed at 845°C  more
1 h2 @; F6 ~( ^
Yield Strength (Mpa)5 v4 r3 o5 l. ^* l& R
341.3
. b5 `, e; w/ H6 w- _' A
Elongation (%)9 z3 c; P$ k/ w8 X" K- w* \1 R
31.2 ! H5 n% A3 @( Y1 f# G
Reduction in Area (%), ]  r" m: |* [1 Y1 _8 Q, z
57.9 % X* P, j% N8 f6 x( n7 M
Hardness (HB)
4 f: K' s2 u& v8 J7 @
126 4 A3 d5 i& G2 Q8 r; c0 }
2 o& @9 ^0 y% I* E
annealed at 845°C more6 n; L) T) o. l1 ~# K
Impact Strength (J)
$ L  ?( c& n/ E(Izod)
! I& r, s. s& ~4 I& g& `
69.4
. L; L  {, e; \4 r$ K- d
5 X4 \, b) B9 C0 @8 ^
3 Q4 _$ v3 |6 m% K
: q7 [. H% G' w- G( S
- A6 \! x1 a8 E4 R6 U
Thermal Properties3 z( T; q. ^, z. {$ V
http://cid:image001.gif@01C9CD98.0E12DC902 G) ~+ G; C! t
- A# I' O+ E  D6 Y$ P
, O" b! A; v* _+ `' t% N( S
Properties
1 V* V9 J* _: B7 k$ N% _3 ^; x  Q3 o
Conditions
) [/ |3 {8 }. M1 \1 J% a
T (°C)
# s8 J0 B+ H& H, T2 N; i- E
Treatment
0 d& Q/ w# m; |5 |' u
Thermal Expansion (10-6/ºC)! M2 E6 \" v7 }- v* z6 w5 F
11.7
8 j2 h4 q( O, F- P, G
+ C) W$ v% L/ B4 W: k
8 D( [! F% \5 x$ |% ~; ~. ]' e
2 n/ u% k4 L8 W" d
% V, ~' e& p, v; s( a0 `[ 本帖最后由 aviatefish 于 2009-5-7 16:06 编辑 ]
发表于 2009-5-7 15:40:14 | 显示全部楼层 来自: 中国江苏泰州
相当于国标GB/T699中的30#钢
