查看: 1540|回复: 2
[求助] 谁帮我看下,装配体空白文档中添加零件的问题
发表于 2009-5-23 11:35:40 | 显示全部楼层 |阅读模式 来自: 中国安徽合肥
程序如下:(是装配体空白文档中添加零件的)
0 m8 o( R# o0 G6 R0 r0 A$ y/ s& ?Dim swApp As Object
5 z! f) y6 Q/ u) H+ i4 kSub main()
1 D1 d$ v, \( I9 b
  q. Z, t  S$ f% t( E$ c) d$ PDim Part As Object
0 J& t! y2 J/ ]0 d4 tDim SelMgr As Object6 ]' f) E# B% n( J6 V7 i
Dim Boolstatus As Boolean
. b& z& C+ _  ^) I, ]1 u& R
7 [6 o2 {& ~! @0 E- `6 nDim Model As Object8 q' r1 d* _; x7 p* D/ ]
Dim longstatus As Long, longwarnings As Long
( i/ R5 V& a2 `6 u/ wDim Feature As Object: y) }/ a, Y. {) V, Z, `9 I- g! ?
. g+ |0 V9 ?. E
Set swApp = CreateObject("SldWorks.Application")) [  ?6 C6 d0 Z; T, e% S! Q' v# O5 L  C% {
0 ~' v, Y2 V' e) l8 s9 H4 s) w0 d. R
" K% F1 A: a8 v0 R1 o
4 I" x  G% D& w, i% I. ~9 HSet Part = swApp.OpenDoc6("E:\毕业设计\新生成零件\连杆.SLDPRT", 1, 0, "", longstatus, longwarnings)
; r$ ^2 N) w  A7 @- Q+ n' i- Z9 P% d* q- w4 W
'Set Part = swApp.NewAssembly  ]% n% A, \8 i/ u" j' U8 O9 l
Set Part = swApp.ActiveDoc
$ D5 `2 @& I* t1 S4 ESet SelMgr = Part.SelectionManager- W; h& ?9 |' e7 _# _
$ n9 _- y+ k" n& VSet Model = swApp.OpenDoc6("E:\毕业设计\新生成零件\连杆.SLDPRT", 1, 0, "", longstatus, longwarnings); c! N  }/ T- \, |% B- P
Set Model = swApp.ActiveDoc6 j1 O" a, c9 z+ i
Set SelMgr = Model.SelectionManager" l5 V9 x# i3 f
/ v- x8 H: l$ R* |3 s  sPart.AddComponent "E:\毕业设计\新生成零件\连杆.SLDPRT", 0, 0, 0, }2 G% z) ^( [3 z$ B: q' P' H* y
6 ?3 L4 T/ t% Q0 Z, t' o" d* Y
Part.ClearSelection2 True' m9 w. @8 N! L, Q- U0 @! M
Part.ShowNamedView2 "*等轴测", 7
( ~  ]) P& J* L8 f. _End Sub2 x6 e  L# w" J. o( [" L; G
运行到这句(Part.AddComponent "E:\毕业设计\新生成零件\连杆.SLDPRT", 0, 0, 0就报错,但零件已加载进去了,错误内容为:对象不支持该属性或方法。这是为什么呢,该怎么改,谢谢!
发表于 2009-5-26 16:02:33 | 显示全部楼层 来自: 中国北京
Part.AddComponent "E:\毕业设计\新生成零件\连杆.SLDPRT", 0, 0, 04 N# }9 k; e) Q% W6 p: j0 t, e5 n
这里的“Part”应该是个装配体,你把 'Set Part = swApp.NewAssembly给注销了,所以Part 是个零件图,当然没法插入零件了,我给改了改,仅供参考:
0 D; d2 _8 u3 R! m- |- W; h0 l
5 l! n4 x3 l2 u6 PSub main()- i' d, k) r1 d" }; f; V
; }. I/ ~$ k5 J' V8 ]' [    Dim swApp            As SldWorks.SldWorks$ T! h+ _2 l, e7 N2 W* Z/ c
    Dim swAssy           As SldWorks.AssemblyDoc
' s$ j! r/ `; m) X$ ?' o    Dim swPart           As SldWorks.PartDoc+ `* k/ g, Q) y+ }! I" a! h
) m1 p5 N  G: a  p    Dim longwarnings     As Long& i! m( I* r" u, Y, K
    Dim sPartFileName    As String
* U' P- ?& r" a0 V0 L2 J    Dim Boolstatus       As Boolean
8 R. h! i- k4 ]; H4 Z+ D6 u6 Y3 ~8 \4 g
: s) Y& j9 U7 m/ z9 q8 U    Set swApp = Application.SldWorks) i' a5 I/ E$ D7 r
    Set swAssy = swApp.ActiveDoc
  d( n! F% d# Q    8 s# U6 }7 a' }+ _1 J) }
    If (swAssy.GetType <> swDocASSEMBLY) Then Exit Sub    '当前文档若不是装配体则退出( j+ T1 H) K$ a7 s3 E0 H
    " j( t) G3 N" w  Z7 _& w$ e2 l2 h
    sPartFileName = "E:\毕业设计\新生成零件\连杆.SLDPRT"
5 I* P) ?8 p" b    0 X+ ^5 |  N3 u: B8 o* O6 z
    swApp.DocumentVisible False, swDocPART
. n  U6 a& X+ l  L( a7 v9 q" \    Set swPart = swApp.OpenDoc6(sPartFileName, swDocPART, 0, "", longstatus, longwarnings)
2 Y  P. L# k/ c' I! m! N    9 o, ?; k4 f2 L9 }8 `% f5 f# w0 q, K
    If swPart Is Nothing Then swApp.DocumentVisible True, swDocPART: Exit Sub" e% }2 ^$ [* B
2 _2 U7 v$ M0 B* z    Boolstatus = swAssy.AddComponent(sPartFileName, 0, 0, 0)* Y8 V& B" V" N" u
    $ o" _( G, h$ y- c9 |; B* ^
    If (Boolstatus = False) Then swApp.DocumentVisible True, swDocPART: Exit Sub    '若零件插入失败则退出
0 J/ E/ a  U0 _* w! g6 ?3 d( w    & u5 O' S3 G- z# R% f0 Z( E( @
    swAssy.ShowNamedView2 "*等轴测", 7
2 g# n% A8 H( g+ \& _    swAssy.FeatureManager.UpdateFeatureTree  '更新特征树4 e7 M" |( {$ v% q- C: F
$ t+ x: e  U0 O7 w    swApp.CloseDoc sPartFileName
7 R' t8 A9 |8 U3 d' h    swApp.DocumentVisible True, swDocPART
1 a& R& h4 R; ?6 o6 D1 `4 b) _8 }2 g4 ~& u+ \- O
End Sub
7 a* u! X/ G# P/ v  ?9 ~, p) f- B+ k) {! s! W- ^+ z0 n
[ 本帖最后由 swabc 于 2009-5-26 17:24 编辑 ]
发表于 2009-5-26 17:26:23 | 显示全部楼层 来自: 中国北京
发现一个问题,现在改过来了
