查看: 1356|回复: 0
[求助] 哪位高手帮忙改下这个装配体空白文档中添加零件的程序?
发表于 2009-5-24 21:48:39 | 显示全部楼层 |阅读模式 来自: 中国安徽合肥
程序如下:(是装配体空白文档中添加零件的)* r. Z( k, Y& V/ q: a1 S/ r6 n
Dim swApp As Object
& y" \( K8 R, s/ JSub main()
/ Y8 n+ D$ P6 e& \3 R; n7 O) ~  E6 e- x% t
Dim Part As Object/ G  Y' Y' w# s7 g
Dim SelMgr As Object/ k$ q: T6 c# g4 m( y
Dim Boolstatus As Boolean8 ~. O, I0 p2 }) X9 A
$ W9 e! S6 \( y) |, @+ F) j/ u7 |6 bDim Model As Object% G: [% E& f! b% B8 i+ l  X7 T
Dim longstatus As Long, longwarnings As Long
, c3 C# `: W' J$ k* a; oDim Feature As Object
5 p+ A; @$ c$ g0 s- ]; ]7 I2 @* ?4 g- t4 [
Set swApp = CreateObject("SldWorks.Application")
2 y8 r1 R! J  d. H2 e( a
! D3 T0 j( p2 Z; d! h9 w2 B
( V' o; n* H, i$ z! y1 E
8 b3 |, W+ s- T+ d) |Set Part = swApp.OpenDoc6("E:\毕业设计\新生成零件\连杆.SLDPRT", 1, 0, "", longstatus, longwarnings)
" H8 s6 ~$ o' g$ ^7 t3 u9 `& |1 y! Z/ I4 S4 J& H) e
'Set Part = swApp.NewAssembly  }$ y0 \/ @, o
Set Part = swApp.ActiveDoc
+ r4 w3 u6 l! z$ [. I2 u' USet SelMgr = Part.SelectionManager# ~: C$ M' H* b$ F1 x# H
2 P/ e3 U& s4 N1 v5 H- A+ ?
Set Model = swApp.OpenDoc6("E:\毕业设计\新生成零件\连杆.SLDPRT", 1, 0, "", longstatus, longwarnings): @; Z4 O  M9 E' l
Set Model = swApp.ActiveDoc: A" _1 h  ^- K: [
Set SelMgr = Model.SelectionManager3 M( N9 z% S7 e9 E# B5 z# [3 A  ^
" ~, ?+ z# _5 e3 Y1 J, j
Part.AddComponent "E:\设计\新生成零件\连杆.SLDPRT", 0, 0, 0+ W9 a' `3 B: t  j: E. t+ p
7 S  u& I6 M+ b+ T
Part.ClearSelection2 True/ c& J& F. c; }3 b- N
Part.ShowNamedView2 "*等轴测", 7
! {: a  s2 B1 s! [( S4 q1 e  oEnd Sub- U$ K. W, Y; z
运行到这句(Part.AddComponent "E:\毕业设计\新生成零件\连杆.SLDPRT", 0, 0, 0就报错,但零件已加载进去了,错误内容为:对象不支持该属性或方法。这是为什么呢,该怎么改,谢谢!
