查看: 1421|回复: 0
[讨论] 这样的NC在G17平面螺旋走圆弧吗?
发表于 2009-5-28 20:31:50 | 显示全部楼层 |阅读模式 来自: 中国上海
这样的NC在G17平面螺旋走圆弧吗?& h$ H6 O6 r2 h+ ^  K9 w0 F
# M6 w: r- x, d. a2 ~! R' O%
7 ?# N9 J3 y1 G/ T, j(PROGRAM NAME: lgj.NC, Thu May 28 19:59:08 2009)
7 P" G2 {6 e! K$ A- y! _(后处理创建人*刘公军*测试阶段请同仁多批评指正)7 n, A& h+ G1 C+ s; k
(请阁下在每次加工前检查刀号,刀补。既刀具大小正确)% i& v7 s  l% u
  D5 V/ i2 [' V* t$ S* Y# V(                                   T O O L   L I S T                                           )& H. p8 p+ P* Y4 r! v9 Q
. v, d) _/ {2 f4 c. U5 ~: V(        )& k7 q8 L2 F$ \1 M6 r* k
(-----------------------------------------------------------------------------------------------)2 H4 |2 e/ h5 z& [
(MILL                 DESCRIPTION          DIAMETER   COR RAD    FLUTE LEN  ADJ REG             )
+ O: N1 u9 Q# e+ j% ^/ M(-----------------------------------------------------------------------------------------------)
2 ~* d+ r  q; Q+ W3 n0 x(D10                  MILL                 10.0000    0.0000     50.0000    1         )
. E# Z) g9 o3 }$ G2 g; Z6 k(===============================================================================================)+ |" }6 j3 Z  D0 a
G40 G49 G80 G90
7 v: b5 v# A, Z0 \9 z# _5 ]G91 G28 Z0.0% l+ }' D2 j6 X. |6 K( c. o
T01 M06
- f' h! G" R8 P' H1 XG17 G0 G90 G54 X4.016 Y-6.6425 H; U- U0 M" F1 M- i8 u
S3500 M03
6 J" z# D. b: {; x* ~  a4 cG43 Z20. H01 M086 Q0 b9 i; Z; n
G1 X4.016 Y-6.642 Z20. F1000.
8 ?' K* V7 d8 m% G6 q" F" Q5 gX4.016 Y-6.642 Z14.1015 S. |* t) g0 B
G3 X4.016 Y-6.642 Z13.114 I-1.993 J4.035 K-.157 F500.
; h- e6 ]* E2 Q! c0 C* @X4.016 Y-6.642 Z12.127 I-1.993 J4.035 K-.1575 `# f; a2 q7 j: P
X-.736 Y.948 Z11.601 I-1.993 J4.035 K-.1579 |8 g$ U' i) n( X0 _9 H' }: Z( ~
X-1.2 Y0.0 I.736 J-.948 F1050.
1 y2 c. a- ?; p* n0 C% mX0.0 Y-1.2 I1.2 J0.0+ [7 w: }$ s# i" Q' r. U
X1.2 Y0.0 I0.0 J1.2$ n9 |# F0 `, n5 ^5 d
X0.0 Y1.2 I-1.2 J0.0
0 q$ z6 r, F" c& AX-.736 Y.948 I0.0 J-1.2- _1 k. N, c- u' M; B( {( t7 Q
G1 X-3.801 Y4.898 Z11.601 F2500.
8 ?" f0 h  ]' @' s. l. V" i  QG3 X-6.2 Y0.0 I3.801 J-4.898 F1300.
0 y: g& q+ g5 g! u: hX0.0 Y-6.2 I6.2 J0.0
: t: d* |4 c3 |" UX6.2 Y0.0 I0.0 J6.2+ u8 A& ~4 `, |( l& b# j
X0.0 Y6.2 I-6.2 J0.0
: u9 `; y: Z& _  k) U+ BX-3.801 Y4.898 I0.0 J-6.2" I( X" @4 l& @) Q  g: p
G1 X-6.866 Y8.848 Z11.601 F2500.
