发表于 2009-12-16 12:46:56
来自: LAN
UPC产品认证的标准:
3 A$ w! p9 J# Y/ V! f1.Plumbing fixture fittings / ASME A112.18.1-2005 水龙头标准
1 `1 |3 k: S6 P1 a9 t) j# f2.Flexible water connectors / ASME A112.18.6-1999 金属软管标准
. E- ~, F: {5 t) e3.Vitreous China plumbing fixtures / ASME A112.19.2-2003 陶瓷卫生洁具标准
% l$ [& L0 r" s+ U, \% m6 l8 f4.Anti-siphon fill valves (ballcocks) for gravity water closet flush tanks / ASSE 1002 水箱配件- f+ }" ^& j3 O0 O3 c# O
5.Trim for water-closet bowls, tanks, and urinals / ASME A112.19.5-1999排水阀标准3 A' n- b- T! N: [) |
6.Hand-held Showers / ASSE 1014-2005 水龙头花洒(连接、可移动)% E$ W7 H) F9 M
7.Shielded couplings joining hubless cast iron soil pipe and fittings / ASTM C1277-97 管箍及配件
A- A! p3 P& N/ D" M4 T& Y8.Hubless cast iron soil pipe and fittings for sanitary and storm drain waste, and went piping applications / ASTM A888-04a 铸铁管/及管件1 y( T: \/ e3 U: K* C
" g( J' o% L# H0 Y0 F" [
- E6 S, E$ ]& t' d; P. nIAPMO产品认证规范分类说明
& }8 W/ W5 C; w' \' j $ e! w7 ^% w7 [1 Y- z
2 M9 e9 U# o; t! ]% b( G4 n- `+ S# M8 H% [- J- `- @: v
! K# d7 h# f/ R) N) l7 C# Y
: D3 u; C$ R9 S# z5 L) k: B$ t% J
止回阀 (Backflow Preventers)
' r6 P! Z Y" t* q7 k. AIAPMO PS 38 ; q& B# [- B6 p2 V0 e1 W
6 i/ ?( k' [( v/ M
! }7 o$ p. V3 }$ ^( g( G8 ^1 \$ H
水泥、焊料、结合点混合物 (Cements/Solder/Joint Compounds)
9 \ ~5 F3 @! k, S5 {- w; m0 VIAPMO PS 36; ASTM B 32 B 813, D 2235, D 2564, D 2672, D 2835, D 3122, D 3212, F 656
5 J( r1 Z9 s# d* q
- k; m4 P4 J2 H2 k: p1 y$ P. }1 u% `% b& L. N1 {. ^# N
电气设备 (Electrical) # Q" V5 H& e, M" H/ a5 m
UL 651 9 l% H+ `3 J* X$ w: I) R8 |
9 T F8 ?% q: _/ F0 x; T/ X5 T6 f. ~- y- _
房车及娱乐车用制造设备产品 (Manufactured Housing/RV Components)1 b3 a4 }" Z( g: N1 {7 y) Q
ASSE 1049, 1050, 1051; IAPMO PS 42, PS 47, PS 54, PS 94, PS 95, TSC 2, IAPMO PS 55 , PS 69, PS 74, TSC 4, TSC 7, TSC 8, TSC 14, TSC 15, TSC 19, TSC 21, TSC 25, TSC 26, ANSI A112.21.2M, ASME A 112.21.1M 7 `! I1 y: [, W3 T" Y O( P
G; E* N+ n* _' |: Q2 G% a( p4 w" G
c) _2 t0 \! z" a2 p金属装置 (Metal Fixtures)
9 r1 K7 z3 ]- D' a+ p4 U2 i9 b. O" x) xIAMPO PS 5, PS 54, PS 62, PS 9, PS 14, PS16, PS 41, ANSI A112.21.2M, ASME A112.19.1M, ASME A112.21.1M
5 y5 ~, e9 K4 B$ C: m, b+ c
X0 e5 g7 t K: [* [$ I1 d! d" l \) q, [! J* { u8 X
金属管件及配件 (Metal Pipe/Fittings) ( i) P8 D6 u2 Q7 U; ?4 ]0 L4 {
IAPMOPS 2, PS 7, PS 9, PS 14, PS 16, PS 23, PS 74, PS 4, PS 5, PS 44, ASTM F 1807
# h( K/ I$ y2 J+ I8 b9 x
' K/ K& M/ O2 q+ U1 e" n) [, P& H; u g3 E0 A
管道外涂层及覆盖物 (Pipe Wrap Tape/Coatings) 7 i' T; ~ j1 W0 M
IAPMO PS 37
% K/ w1 o7 {. O, E
" Q/ A& }9 B% ?) N
' |4 L8 G, D8 c9 ~( k' ]4 U* r' {' K" }& M
塑料设备 (Plastic Fixtures)7 O0 a! G- G8 W# d: S
ANSI Z 124.5, IAPMO PS 94, PS 69, PS 74, PS 90, ANSI Z 124.1, ANSI Z124.2, ANSI Z 124.4, ANSI Z 124.8, ANSI A 112.21.2M, ASME A112.21.1M
: u x# J) D/ }5 x, }0 O . o0 v/ |6 i0 f. S
: u/ G) v% a" }) z8 Z塑料管件及配件 (Plastic Pipe/Fittings)
# Y! g( ^; h% g. P. xASTM D 1527, D 1785, D 2104, D 2239, D 2241, D 2282, D 2447, D 2246, D 2467, D 2468, D 2661, D 2665, D 2680, D 2729, D 2737, D 2751, D 2846, D 3034, D 3036, D 3212, D 3311, F 405, F 409, F 437, F 438, F 439, F 441, F 442, F 628, F 667, F 789, F 794, F 810, F 876, F 877, F 891, F 949, F 1412, F 1673; IAPMO PS 4, PS 33, PS 38, PS 47, PS 51, PS 69, PS 74, PS 90, PS 94, SPS 3, SPS 4, ASME A112.21.1M, AWWA C 900, IAPMO PS 16, ANSI A 112.21.2M
/ k; n8 ~; y$ e8 H0 ]" t( f7 Y+ R" c1 h
1 `% U3 r! @1 ?5 \4 ~5 i
0 D* a' R4 ?9 ~5 ?* ^阀门及龙头 (Valves/Faucets) 4 S: _( y/ {$ T E1 k7 R# \
IAPMO PS 45, ASSE 1016, ASSE 1025, ASSE 1014, IAPMO PS 69, ASME A 112.18.1M
: W3 |! K3 k1 T( N) {
' X/ e* S5 e5 w: N& _4 w: b, Y9 g
! `% A6 w; B; J, v+ P- u供水软管标准 (Flexible water connecters)
# C0 F. d }4 i0 N5 _7 LASME A112.18.6
R' o; M5 n4 I
4 Z+ R6 Z: a/ `0 |玻璃陶瓷洁具设备 (Vitreous China plumbing fixtures)9 F1 a- K5 b, \5 u0 I! f
4 q& o3 G6 g `/ B- J- {' c# C
ASME A112.19.2m-1998
) O6 Y, `* C. ^% P! C K7 J
" L% [" X+ y: r: H卫生洁具功能要求 (Hydraubic Performance Requirements for water closets and urinals)2 j/ E. P2 [" A% s' k i4 U! ~
2 R/ U/ e& j, L. {5 z& e/ ~
ASMEA112.19.6-1995* u4 I3 `9 m8 y! H* o
* z$ q# i) L6 [8 S水箱配件(Anti-siphen fill valves (Ballcocks) for Gravity water closet Flush Tanks)5 t, m& O8 d# o! o& S+ M& f' p
% T# d9 V! u! L/ U/ t9 S0 f& A# }9 q6 SASSE Standard#1002
- x- r: F* {7 B) F* B( s y9 `
- g( N( ]) L+ N卫生间及卫生洁具排水阀 (Trim for water-closet bowls tanks, and urinals)) q; `( d4 t! \! y* S
6 L% k4 G& p/ r% v/ u! u& h
ASMEA112.19.5-1999: f* x0 \) [, |" v7 V
& E7 i% v7 L: l* l1 s; ]
水龙头花洒 (Han-held Showers)0 g0 z( M8 ]$ b7 y2 y& O
' ~+ T6 E+ p4 u' n4 w
ASSE Standard No.1014
* y2 K6 i; x3 _2 _0 V( } J% N* C' s# r6 z* v% b
管箍及配件 (Shielded couplings joining hobbles cast iron, soil, pipe and fittings)
" q& F+ V! v6 U* D8 F) }" Z3 w- Q9 J+ _' X
ASTM C
- O, _- g, ~# R5 N8 f: |7 F n) b1 @9 R; J
铸铁管/及管件 (CAST IRON, Soil pipe)
( m) J/ _! c* V1 |7 h1 E8 y4 Z! U( v/ }" d! X7 W9 `
CISPI 601 ASEM A888$ b. h% i2 W9 Y/ G" p( H
2 R2 ~0 _3 d; ~2 T1 o# b( D# ]. _$ I) ?; x
游泳池、健身浴池设备及配件 (Pool/Spa Components/Fittings)
7 q/ ~" D: y$ C& ^3 h' J' J! i9 \* kASME A 112.19.8, IAPMO PS 33, SPS 3, SPS 4 4 }# c+ u/ v8 M( a( L
9 K, f1 B& B6 _" }8 `% D2 x8 R% R" F, m) ^! A4 l. f2 i* }# I% J" l
. M5 ^; s* `5 r& \! X
9 E% r: t) E6 ~, J1 Y) }污水系统 (Septic Systems)
7 K7 u; K% W4 G9 k* r3 SIAPMO PS 1 7 Z7 y) I T9 ?
/ \9 ?7 N( r4 S; s2 R# w4 w" C
. i* l4 _- g: a7 ?# t8 K5 z
林浴盆 (Shower Pan Liners) * ^+ `. z$ I( ^, C6 E8 v' X5 a9 P
ASTM D 4068, D 4511
" S2 Q6 b! K% z. F( N6 v3 K: o7 L
; I$ l+ I# f3 _9 i; H
* }% ^# c0 a/ B+ A真空破坏器 (Vacuum Breakers)
3 d! y: `: m) z. Y! OASSE 1049, 1050, 1051 |
