查看: 1592|回复: 2
[求助] vista x64下安装sw2009的出错,基本功能正常
发表于 2009-6-4 03:28:55 | 显示全部楼层 |阅读模式 来自: 中国上海
vista x64下安装sw2009 x64发现cosmosfloworks以及pdmwserver两个功能没有自动安装上,手动安装cosmosfloworks后提示license不能用,pdmwserver手动后正常,....0 E# ?$ T% s" y! a. i) f8 T
......急....盼高高手指点..
% L8 T' f2 R8 O0 h: s3 `: \  E; H$ p4 [3 T: m
另注:在vista32下安装sw2009一切正常. :L :L: I$ ~1 j- ^- D8 \
8 E8 N3 a9 V5 ?0 E$ r' u3 i
9 Q7 y, \) h( D! M+ W! y% Z1 k
:mad: :mad: :mad: 找到这个
- k. ?$ P' p; V' J4 O
May 18, 2009IE8 and SolidWorks RSS news Task Pane issue (x64).6 b2 v+ K; `6 w, p1 l( F
The problem has been confirmed and been reported to development under SPR 480083 on x64 operating systems. It is caused a by conflict between Internet Explorer 8 and the News Feeds in the SolidWorks Taskpane. 9 R! S2 O6 }; m5 n# S5 h7 O, x. z
8 \* U; e* ]! B1 \) {: D" UUntil the issue can be addressed by development, it can be avoided with one of the following methods:1. Uninstall Internet Explorer 8 and install Internet Explorer 7 instead. SolidWorks will launch successfully afterwards.
! g& J! s' h& e5 d- b; f9 p3 P+ R+ k/ P
2. Turn off the News Feeds. Since SolidWorks does not start in this state, the option will have to be disabled directly in the Windows registry. Please use caution while working in the registry. The option can be found in HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2009\General. Find "Show Latest News feeds In task pane" and change its value from "1" to "0." ; ^  b0 T. x! f! X8 R
2 X8 @; x% u/ u# m( t
3. If installing SolidWorks for the first time on a computer, and no HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2009\General key exists to modify, then download the attached registry file, and double click on it to automatically create the key disabled.& ]( m: X' e6 h, x
- U$ V- @2 c) J% z1 l) ]' W+ gYou can find the current status of this issue by querying this SPR number in the Knowledge Base.
( K0 s6 o7 x' J* l7 l7 H0 L# r7 L! M$ ~7 i% R' K0 Z
Also see Solution Id: S-036457 for details.
* Q5 [$ `1 S  p8 j0 p% t, H6 @* K
" m* `( m# }0 ^0 S2 k1 b; i! N; ^[ 本帖最后由 zxccc 于 2009-6-4 20:04 编辑 ]
 楼主| 发表于 2009-6-4 20:13:54 | 显示全部楼层 来自: 中国上海
找到罪魁祸首,IE8...坛友们可别再犯同样的错!!!
# s& ~; D* b/ s$ [$ ~vista x64 只可在IE7下安装sw2009 x64才能无错,运行也正常.
$ i0 r% ~5 E/ C- T) F
# ]3 J$ R  {$ h7 x4 p- N( Q! }4 H. i :L :L
 楼主| 发表于 2009-6-5 12:01:17 | 显示全部楼层 来自: 中国上海
还是有问题,安装中继续跳出一闪而过的出错提示,但是能完结安装,基本使用也能用,不敢上更新包,好像还是由于sw2009和vista x64的兼容性问题...狂衰中.....1 E: Z( q" P2 E
) O( c6 J- [7 q/ E7 C& k. ^, ~ :mad: :mad:
