发表于 2009-7-12 15:42:25
来自: 中国广东东莞
#FEATURE CORE_ELECTRODE cima-d 8 31-dec-2012 uncounted8 p/ U2 `, O- ~* ]+ t5 T2 K3 `( A! V
# HOSTID=00137749dbf8 ISSUER="Team oDDiTy" SIGN=6DBC437817BE9 G6 r7 {% e( Y4 N: Y
- r# \3 P) y2 P- f, i4 zFEATURE CORE_STANDARD cima-d 8 31-dec-2012 uncounted \, O! {! y& A, }6 D6 F4 _0 x, R" y: f
HOSTID=00137749dbf8 ISSUER="Team oDDiTy" SIGN=628496483BFC
5 x+ t4 T4 D' D* WPACKAGE ODT_SHOOT_PACKAGE cima-d 8 COMPONENTS="$oDDiTy 2D-TO-3D \# j% _3 |0 H7 ?5 T
2X_MILL_LITE 2X-MILL 2X-WIRE 3X_MILL_LITE 3X_SIMULATOR 3X-MILL \
* W5 T1 u7 J |, W+ S& ~" H 4X-CONT 4X-WIRE 5X_AEROSPACE 5X_SIMULATOR 5X_TRIM 5X-CONT \
2 l6 H. y, {- Y ABIANT ADVANCED_ASSEMBLY AUTODRAW AUTOMATED_DRILL BEND \
3 n' u% W* y% i2 ~8 j7 _4 { CAD_MODE CADENAS CATALOGTOOL CATIA CATIAR2D CATIAR3D CATIAW2D \1 o7 B$ }1 Z8 l- d5 ]) M
CATIAW3D CHINESE_TRANSLATION CIMACABLE CIMADEK CIMADEK-NC \
* ]2 s( s1 u$ U2 G/ P3 Y- u CIMADEK-RUN CIMARENDER CIMIT-D CIMIT-M CIMIT-MD CIMIT-MDN \
% f% C8 l8 c. W* G. d CIMIT-MN CIMIT-N CONCURRENT_DESIGN CORE CORE-M CORE-X CPDM \! {& k' M) X: v1 k' w' m3 a" c
DIE_BLANK DIE_FLANGE DIE_FORM DIE_LABEL DIE_PLOT \
x: @ m9 W4 Z- m* Z! K DIE_PLOT_SAFETY DIE_PLOT_THICK DIE_SET DIE_STRIP DIE_TOOLS DMS \/ C S2 f, }3 J' I2 }2 |% k
DRAFT DWG DXF E_STAMP EDM_SETUP_WIZARD EDM_WIZ_AGIE \
# Q: ^ N& S- }+ k2 {- g) q" B EDM_WIZ_DPC EDM_WIZ_INGERSOL EDM_WIZ_MITSUBISHI EDMS-LINK \3 p$ }3 A" c( k' r
ELECOTRE FAST_BLANK FEM FIKUS_IGUS FUSION_FULL GPF GPP \
& V( U5 `0 r8 I, t8 S: A GPP_DEV_EX2 GPP2_3X GPP2_5X GPP2_DEV_3X GPP2_DEV_DF2 \
: _* q9 U. g. T! o, @ GPP2_DEV_EX2 GUN_DRILL IGES KINEMATICS LATHE LATHE_2X LATHE_3X \3 E4 b) C. J' R* E! n$ ?' \
LATHE_PP_COMPILER MACHINE_SIM MACHINE_SIM_CONFIG MACRO \
5 D7 u7 Y8 y5 e7 ^: N+ d+ n MICRO_3X MICRO_5X MICROSCRIBE_IF MOLDBASE3D MOLDDESIGN \
6 l8 ~5 j) u# D5 A$ V# P- X* L& J MOLD-EXPERT MULTI-USER-1 MULTI-USER-2 MX_MOTION_BUILDER \
3 K$ z% i: J: Y4 S: {/ ~: d MX_MOTION_EDITOR NC_UNDERCUT NC-LINK NESTING NETWORK_ENABLED \& C7 q. p6 ?2 i6 b" c- @- ^
PARASOLID_READ PARASOLID_SAT PAR-SHAPE POST_CONFIG \6 U4 [4 j! u6 ]6 m6 a# Q
POST_DEVELOPMENT POST_PRO POST_RUN PUNCH \
4 ^6 a* a+ e$ a- l6 d4 W Q5X_CONT QCOMPARE QCON_C QCON_Q QCON_S QELECTROD QSPLIT \
) t, s& g6 _) P QUICK_NC QUICKCONCEPT QUICKDRILL R_CATIA_2D R_CATIA_SAT \4 u$ z2 a6 C8 \" S* d; }% A/ D
R_CATIA5 R_IGES R_IGES_SAT R_INVENTOR R_PARASOLID R_PROE \
- Y6 z0 c2 L2 E& @4 i R_SOLIDWORKS R_STEP R_STEP_SAT R_UG R_VDA R_VDA_SAT R_VRML \% a6 {# b: P. u
RD-PTC RE-ENGE SHEET_METAL SAT SHOP-NC SIMULATOR SLA \
- M) u/ A! ]9 c SOLFAST_FULL SOLID SOLID-ASSEMBLY STEP_READ STEP_WRITE STL \: P& L5 r( Q% J1 s n% h; `5 ?+ k& r' _
SURFM TACFAST_FULL TEMP_KEY_CODE UGR3D V_CONTROLLER VDA \
% f: G- c& o2 Y9 i4 g5 P% a5 s9 | VERIFIER W_CATIA_SAT W_CATIA5 W_IGES W_IGES_SAT W_PARASOLID \4 b, a. Y, ]# b0 U0 e/ L: Z- V
W_STEP W_STEP_SAT W_UG W_VDA W_VDA_SAT W_VRML WF2SRF WIRE_2X \
- Y; m( S J C, }6 Y) ] WIRE_4X WIRE_STANDALONE X-CIMADEK X-CIMADEK-RUN" \! J9 e% T% c" d) T
SIGN=BC3606CED78C
, P0 ]' y# |. [% J% d% hFEATURE ODT_SHOOT_PACKAGE cima-d 8 31-dec-2012 uncounted \
& O. s6 }( ?0 E6 G1 q% B( j HOSTID=00137749dbf8 ISSUER="Team oDDiTy" SIGN=AEFE2D743A60- f, h4 C3 F" }3 |
PACKAGE ODT_CATALOGS cima-d 8 COMPONENTS="CATALOG_DANLY_INCH \
# f# H6 Y' `' E0 B8 y$ P CATALOG_DANYL_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \
2 G5 I! R8 {6 y4 C+ r* c+ ` CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \
) L7 O2 I( X& |* I- b CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \. U" K) z5 Z4 O5 R
CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \
( y. F4 q9 J1 u8 p% @# i CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \9 z2 F. K t7 P* @. W) u, F" J0 L6 Z
CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \
" s# A7 n u, y$ }, s' ~ CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \
+ v, D1 w6 G& b+ d- n/ z CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \& l% N8 V; W4 Y6 |/ z2 A2 D
CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \
2 I" Q7 a+ O7 l+ p CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \
& }/ p" x* k7 O3 |0 s+ {0 [ M; [ CATALOG_UNI CATALOG_VAP " SIGN=32AC419C92FC" l" q1 p/ d( N0 B, A' S' C
FEATURE ODT_CATALOGS cima-d 8 31-dec-2012 uncounted \
6 C2 v" q8 y% l& z% v9 e5 b HOSTID=00137749dbf8 ISSUER="Team oDDiTy" SIGN=7E3144B416E0
5 S2 }2 _" s& A# QFEATURE CHINESE_TRANSLATION cima-d 8 31-dec-2012 uncounted \
4 e4 q% r! ?, i) k5 ~ HOSTID=00137749dbf8 ISSUER="Team oDDiTy" SIGN=94F581D895F6 |
