发表于 2009-6-7 19:30:40
来自: 中国江苏无锡
!-----------------DISPLAY FUNCTION--------------------------------1 N+ s" t6 w' d* c/ c% `6 V
, q1 S! [9 G* I+ \6 `
' f' a6 w) M/ a
9 u: k) C4 N4 ?' X1 J/ T: F
# ] `( ]% b; n1 z% E
9 ]6 G9 U8 }* t E) w9 K& i! f
% K+ c- |3 Z: e/ j8 _+ m. b
4 l7 G( S0 z9 ?& ]* d
: P$ F( A& w5 ]" [( e/ a) P6 i0 k0 ~8 J9 y: H: A
0 H4 }, T+ B) M/ D
0 s% x5 s0 T) P& Y9 P s w
3 e7 x5 C5 F* n
* q# D& w& T( j$ l
. @; i6 j( A- A
" W$ p* g2 A6 ~" D3 ?0 {" ~5 d' c3 t. B) _5 B) D9 _
# v% ~- n, u4 {
; c: w2 S' s" E
p% q% T$ h6 S0 u+ Y& q, y: H; \8 x
( r1 _7 T) Y9 g" d/ t) n9 c: G" `4 |' s( x
7 M* q* `! m6 L
9 a! \" v( J* \* H [& _, C!--------MAKE DATUM PLANE (FRONT, TOP, RIGHT)--------------------
" f' U; D9 q# r
$ c- P, f2 o( ~
( J$ P0 z+ c$ ]!--------MAKE FRONT, RIGHT, LEFT, TOP, BACK, VIEW----------------7 L/ v2 ^) \! h& O- D8 g
" B" U/ }, _1 M! w* {
' }0 Y! {5 N; y
!--------Setup layer-------------------------) ^) b) i9 ~) a" C
9 m- {1 `$ @) H3 S5 `7 H( i6 {9 T, B& L+ p$ @$ d; a: P
!--------ADD PART INFORMATION RELATION--------------------------
( L% M u$ H7 v; U3 p% ~2 ^$ ?% l' \" f4 j& |4 k
% R# @6 {" }1 i+ k9 d) s& S
!--------MISC. FUNCTION------------------------------------------7 x' H3 O# G6 \' t8 U& n7 y
, `# B8 c; _: T* _6 S" B% l" z0 q8 \) {( @3 j8 w) X) A
6 y/ J$ f" {9 ?9 @' R6 Q+ z9 }
!--------CREATE FEATURE FUNCTION / EDIT FEATURE FUNCTION---------
- }5 y( I2 L( j& T
" A3 d$ u0 i( V- x; b) g/ h8 G( R% \, z6 S& h
; t0 b4 I6 Z1 y+ }# q# E/ s7 B9 K+ j; L7 c% @
' S9 S! l$ S( l9 _8 B5 Y
! o# Y- ~ A9 H0 \/ R( N
& F* _8 P: `$ _; J!--------SKETCHER FUNCTION--------------------------------------8 k* [2 G! j: {' l* X, d
! `; F4 {2 b3 @# H3 p7 B! @) l! D2 ^' l
!-----------DRAWING FUNCTION------------------------------------" K" b* O( O2 P8 K; I" D
9 {1 i2 v8 b/ l# ?$ s8 k2 u) T5 z+ D
& w$ Y. _/ W- w( H# [4 a!------------INTERFACE FUNCTION________________________________9 _( c$ [4 S( f& T7 h3 y4 A9 H
. L8 _- n" {9 D% \
!------------Pro/ENGINEER SYSTEM SETUP--------------------------
S6 r+ U2 }' wpro_unit_length unit_mm
: h1 t: D- H3 Q! l! K npro_unit_mass unit_gram+ Z1 [8 c T6 U5 u2 H) h
relation_file_editor protab* W, d; ~8 w3 M! N$ q! s
tolerance_standard iso
l! X" e! G1 p1 a; ~0 t; m; ]1 q, Ntol_display yes
1 |& A) o1 n! J5 E" c% t, l0 n- ctol_mode nominal8 S# v' }0 _; z/ G4 i8 o: s
tolerance_class medium
7 k0 Q/ z$ G6 H- Fallow_old_style_round YES
# \5 P/ Q& }/ n4 }: O/ tpro_symbol_dir E:\work_2005\color# e+ k( n$ L3 B6 E0 S0 s7 F0 d# t
drawing_setup_file E:\work_2005\dtl\drawing.dtl& s: t. }( j2 }* k5 W, n
drawing_file_editor PROTAB2 e$ i' L, o) n9 E7 h7 Y. Z/ F
allow_move_attach_in_dtl_move yes
}5 d3 s6 Y8 y' k) B# }default_dec_places 5
0 E# q. e0 a% ^( f4 ^mark_approximate_dims yes
: x4 ` }! F& q9 A' E" Rplotter LASERJET4V2 S8 E$ q: D3 L: v6 {
plotter_command windows_print_manager1 R/ I: C- y7 H6 X2 V0 ?
tolerance_table_dir C:\Program Files\proeWildfire 4.0\tol_tables\iso% A* I3 s" m* X+ {/ _8 P
plot_names yes( ~# E3 F/ V9 Z+ e8 r
pen_table_file E:\work_2005\table
/ D7 J8 n* u- p/ A: stangent_edge_display dimmed
$ n* h# L$ J$ ]9 B- G [datum_display NO
! q- Q" E- z& j- d, r$ ?6 [datum_point_display NO+ S/ W1 r7 ^! r$ u; w
display_coordinate_sys NO+ ^8 O) K5 o: [, E1 `0 w. D7 T
axis_display NO
. O* ?( A5 J) h2 g& C/ r3 idisplay HIDDENINVIS! r& Z9 i+ B& r$ `4 ]+ U
bell no0 p* ~4 y! _- D5 e
bitmap_size 250
9 d; ]' y2 p% U* a. Ysave_bitmap NONE7 d! i6 `* C: H" Y/ y. n5 w
button_name_in_help no
. v3 K9 \" I. L1 ~7 v! c* [compress_output_files yes
! d4 E4 @2 C5 B; g7 N!MENUITEM_FONT -arial bold-14-400-09 h1 {' I3 g m3 E, e' @- I8 {. g4 R
graphics OPENGL1 v9 J/ C4 s2 B0 R/ C
todays_date_note_format %dd-%Mmm-%yyyy4 r) m- z! Q1 t3 S
min_animation_steps 0; t, K' m& x3 D' z2 o
iges_out_dwg_color YES1 V2 T8 a" z$ r/ t1 ^
pro_group_dir E:\work_2005\udf
7 \& [; o: B7 \8 h* Ytrain_file_path E:\work_2005\temp\trail
8 _: F, t# A0 t% ltrail_delay NONE+ \ c H5 y$ {7 u. e; g
trail_dir E:\work_2005\temp\trail7 D5 B( \: G& }, H
pro_material_dir E:\work_2005\material& ^- v" s# g/ d5 l
allow_anatomic_features yes: N' a# u. w" L/ x) E
msg_translation no: e! T2 a# N9 n j' E. V0 ~
template_designasm E:\work_2005\start-part\start-asm.asm.83 a( {4 Z2 e: l( K9 ?& L7 O5 w. e! j
template_solidpart E:\work_2005\start-part\start.prt.20
! \9 F$ o2 I% f: Zsave_drawing_picture_file embed( _* r- ]1 y- f) j
enable_absolute_accuracy yes
, Q* C7 H6 a2 _ F' qtemplate_mfgmold D:\PTC\wildfire\templates\mmns_mfg_mold.mfg! i4 p$ U$ y* D( `
dialog_translation no
4 j# I0 ~6 Z6 Ymenu_font arial,12,,
/ R& }4 P* a7 ]0 Epro_library_dir E:\work_2005
) j9 Y9 V: R$ f8 `+ upro_catalog_dir C:\Program Files\proeWildfire 4.0\libs
# U# g% t' K5 V+ L1 O& mshow_all_mold_layout_buttons yes
* K8 `1 R0 E# A# ?allow_move_view_with_move yes
# t# C* a% v5 k% i x$ F( }/ ]! F2 Y" vtemplate_drawing E:\work_2005\start-part\drw_part.drw.6+ U* a/ J5 }- v7 a6 R
intf2d_out_enhanced_ents spline_and_hatch
- r2 P& n# }3 \8 n' h% C( |7 Guse_export_2d_dialog yes
( p$ q+ d, r& |( E8 Q. y' _system_colors_file E:\work_2005\color\syscol.scl
/ b* q8 \ c8 m# J) Y5 U( tpro_font_dir C:\WINDOWS\Fonts0 s" c5 b+ a, C2 a; _& q
rename_drawings_with_object both
- c# G; m( a5 Isystem_section_color (0,0,200)+ C- z. P0 l) n6 t
sketcher_animated_modify yes
( t" m/ j: _* G5 M6 Y$ gfile_open_default_folder working_directory
[; r- _) l6 O, Y7 s& amdl_tree_cfg_file E:\work_2005\config\tree.cfg; l$ y, g" _& l
autobuildz_enabled yes
4 w* }, B" E" s" S) Ohelp_translation no' O) d V1 f& }
mass_property_calculate automatic
( x/ Y- f9 [/ j+ b. Npro_format_dir E:\work_2005\format& {( x: m3 m& v, L5 I
pro_colormap_path D:\0_objlib\color
" n+ c. Q0 E& lpro_colormap_path E:\work_2005\color
/ |* k9 U. ]4 r6 W& Y" Jpro_colormap_path C:\Program Files\proeWildfire 4.0\text
" D1 }0 U; Z, T: ~/ I$ U4 Z8 S+ Sopen_window_maximized yes: @- ^( e8 H+ f
default_ang_dec_places 2
- k7 Z o2 ^+ n* Y/ h( J; [2 csketcher_dec_places 3
R7 ], ^/ x- o" vdefault_draw_scale 1
% {/ |- ]% ~% T, ]% q4 c# x! ddxf_out_scale_views yes: ]* p' j& f9 S/ k5 ]
step_export_format ap214_cd1 D* K1 `+ V4 {
sketcher_dim_of_revolve_axis yes
2 R( k1 j' J& G# M. Y; Duse_8_plotter_pens yes/ F* ]9 K1 e+ I" P; y! ~
pro_note_dir E:\work_2005\notes
4 T& B0 R5 o8 J0 l5 spdf_use_pentable yes3 X9 y* o0 P$ A2 p3 d1 _; K8 N% O
display_planes yes B+ x; o" h/ X
display_points yes
- R+ @# X" v. a+ q2 ~4 ^! sdisplay_coord_sys yes
! x# O. x* J- I: C3 ?+ bdisplay_axes yes
3 W4 a ~" V5 R' ?5 G& U( ]) mdim_inactive_components never
% k6 Q0 L) i- I# q! A6 Otopobus_enable yes |
