5天前
查看: 3118|回复: 6
[已解决] UG nastran分析求助
发表于 2009-6-14 23:20:00 | 显示全部楼层 |阅读模式 来自: 中国湖北黄冈
我用nastran分析的时候出现以下错误,请问要怎么解决,那位高手教下,不胜感谢。急盼中2 z* ~+ V; |, x) T# n' s2 d) D9 q( X
1 C1 f% Q0 M* h) r: _9 h- D
ERROR6 Y# x7 n/ x) a( S. y; o2 z& s
No material associated to mesh "3d_mesh(1)"." ~9 W+ ^4 g$ t! E# c4 y' _* G
Either no material is assigned to the mesh container or some of the underlying geometry
' e) }. l& x; t" q(body) do not have a material.
. A1 |$ k+ w/ q% t4 S; o& ZSUGGESTION: Apply a user defined material to the mesh container or to all of the1 H3 n8 K) w- u* y- b
underlying geometry (body).
( c) N0 f1 |' i7 `& Z$ I& wTotal: 1 error and 0 warning
5 H) L  @, U& G) I& `' Q8 y" Z
5 b- p4 Y. b: D# ?Material-Based Errors Summary
' D. b9 C: Q% a2 @8 W4 C7 K/ [
1 a$ H# G/ `" Z. [3 LERROR in step "Subcase - Static Loads 1"9 z( b, k7 _: j
This step requires loads, enforced motion constraints or external pre-loads to be
4 e4 p3 f* m6 y$ `/ h/ k6 f/ @applied.  None have been assigned for this step.
) A* R8 p- T( R3 ^  |Iterative Solver Option
$ z9 _9 H$ o0 {  s6 b; ~; J- S8 cMore than 80 percent of the elements in this model are 3D elements.
( N9 Z4 |* g4 q. V( W3 GIt is therefore recommended that you turn ON the Iterative Solver in the "Solution
# U, n( n& q2 Y; g* \5 c% Z9 o6 yAttributes..." dialog.! K. f% ~9 ]! _* g
Total: 1 error and 0 warning4 V7 V8 K/ t% A/ ^5 }/ i
  m) |. c: M: \
Load/BC-Based Errors Summary/ v+ r) C, |; t
" @+ c/ Q; W% ?2 @( S
) q( ^6 R5 ]' |% C7 G) }# G
+ w" ]1 {3 y) I+ W! a4 ]! u5 @; J5 c3 E' a& R. K
1 m8 {: u2 l( W! ~% P, |8 l+ G2 X& V
谢谢楼下的答复,我看了下,我是有进行材料设定的,但是就是附着不上去,这是为什么,是不是我装的版本有问题,我用的是网上下载的NX5.0.0.25版,如果是版本问题谁能给我提供个完整版的下载网址。谢谢' p' r3 o5 U1 Y; R, k. @% o
& q. |0 [2 @& j) y5 a5 j
[ 本帖最后由 nathanlee 于 2009-6-15 20:02 编辑 ]
发表于 2009-6-15 05:48:44 | 显示全部楼层 来自: 中国山东济南
1、未定义材料,高级仿真中的静力仿真需要对你仿真的实体赋予材料特性
& m- ?3 b3 y0 m. `- Q& n2、“Subcase - Static Loads 1”未定义边界条件,是否对实体添加了位移约束和力?$ J( K2 ^) o6 X
检查一下,再找点资料看看
astrokylin + 5 应助
发表于 2009-6-16 09:16:21 | 显示全部楼层 来自: 中国广西桂林
楼上说得很清楚了,请检查你的"3d_mesh(1)"网格属性
发表于 2009-6-16 14:32:00 | 显示全部楼层 来自: 中国山东济南
在材料列表中选好材料后,在到绘图区选中你的实体,点确定,就将材料定义了
发表于 2010-1-13 00:36:24 | 显示全部楼层 来自: 中国天津
没有定义材质,我当初也遇到这个问题了
发表于 2010-8-28 23:22:52 | 显示全部楼层 来自: 中国山东潍坊
没有定义材料与边界约束
发表于 2010-8-28 23:24:55 | 显示全部楼层 来自: 中国山东潍坊
再一个问题就是你的nastran有问题,如时间过期等。
