发表于 2009-7-7 12:27:29
来自: 中国北京
在config.pro系统配置文件中加入
4 H4 u6 g6 @( j1 {! Kdxf_export_mapping_file *:\Dxf_export.pro*
6 A2 r" F! D% ?- s) M( T4 Z5 a! Vdxf_layer_file d:\worker\图框proe\def_layer.pro5 f* n1 \# Z3 X7 j
dxf_out_drawing_scale NO6 u3 G& w7 H+ s" c/ p
dxf_out_scale_views yes
r, |4 N/ |3 B0 W! m- f6 `: ?def_layer layer_<item_type>
& ~& e! \. d+ j* @9 Z% T( Hdef_layer layer_sfin sur_rough layer0001& R1 ~' s7 g: b& |% d' d
map_layer Dxf_Dimension_6
) l1 z, r" L1 W5 q; O0 K, j2 Umap_layer Dxf_Format_40 d( N7 A8 n. ]- O# L* f
map_layer Dxf_Hatching_12 R4 t5 x* u; z0 ?7 W
map_layer Dxf_Axis_809 w! N% H6 o0 b9 l. G2 D3 w
map_layer Dxf_Continuous_Line_7# D. I8 R2 M$ y( V& `
map_layer Dxf_Text_3
) B8 |6 ^2 Z( G4 Z/ x+ a+ u# Smap_layer Dxf_Hatching_12
' i0 Q" I9 A4 Q* F3 o7 nmap_layer Dxf_Table_1& N1 K& K5 F+ H
map_layer Dxf_Balloon_30
5 [$ a1 `" D$ ?6 x, A. Z% s/ Kmap_layer Dxf_Format_5
. P. m; U) ]" M* p8 W9 U; `0 M( M5 H7 D9 c3 q& `& l
并将我提供的Dxf_export.pro等放在与前述同一路径中。* U0 L; a& C6 E; s ^/ s/ z
可用记事本打开Dxf_expor,对转cad的线形的颜色进行修改。
, N7 x) ]0 r; W8 m2 C9 F. l
/ c4 M4 i, c& e& P[ 本帖最后由 hhq426 于 2009-7-7 12:36 编辑 ] |
