发表于 2009-7-9 18:59:56
来自: 中国北京
在config.pro中加入:
6 r6 f0 }6 Q E# F: U- H1 praster_plot_dpi 300 !设置打印分辨率3 ~& j0 q% G' f- N
shaded_postscript_background no
' l& _" z" m5 s2 T' n& Quse_software_linefonts yes !出图时使用准确线型' a6 j) y: W* ]( `, S
! LANDSCAPE_POSTSCRIPT_PRINT NO,打印时是否旋转90度
2 ~+ @" J! T1 W/ ?5 _% ~!pro_plot_config_dir $PRODIR/../pro_stds/plot_configs
5 U2 A7 r; a: S* |) O( ^. b3 q$ b2 ]. b!PLOTTER SET: To your defaut plotter
( b- b! F/ | k4 ?# ^# r% W9 gplotter HP1055CM
5 b' D, c3 ?' x( Iplotter_command WINDOWS_PRINT_MANAGER% u) _5 |( R8 Y L0 O- ]& l1 m
use_8_plotter_pens YES !设置打印机是否支持8种绘图仪笔,缺省为4种
* c1 t6 |2 G1 y! s, C!pen1-pen8 的缺省值为 4,1,2,3,2,3,1,4;数值越大,笔宽越粗,最粗为16; [2 Y" P/ Z( G% ` G+ A
下面是设置系统的8种笔宽:
+ ?4 \5 P6 o4 n' S& w! ypen1_line_weight 5
- c, X+ a6 L5 open2_line_weight 2) y# W w I7 _9 I4 V: Y
pen3_line_weight 20 y+ @' l. }/ V. W. j' b8 ?
pen4_line_weight 2
% f* z" g! ^9 \7 m# ppen5_line_weight 2$ y6 u- M$ F- D4 v# I
pen6_line_weight 2
1 |; |# h0 [' k$ I3 [pen7_line_weight 27 j$ |+ F$ Z* z( b
pen8_line_weight 2
0 z2 P9 W9 ~. E: q7 U' `$ ^raster_plot_dpi 300- s3 Z* u/ ?$ ^6 [& ~. j& C
use_software_linefonts yes! \- P# m5 |1 w+ r* T) i* ~ z' I
use_8_plotter_pens YES4 ]- X5 r' @/ M3 Q
! Control size of the window by either one of the following config options, i+ n$ \# ?" W, d3 c
windows_scale 1.0
" \3 ^0 P& V' M1 [- Y3 ~!reserved_menu_space 2! I/ L- F: r+ J" @( W j
sketcher_disp_grid NO7 T' j+ n9 l) T/ [2 K
! Select either english or metric drawing setup files as your
5 K/ |# N. S$ q: c! common default. You should refer to the "Drawing User's Guide"
3 U1 q+ e9 s7 H0 t: T$ \7 f' i, i! for a complete list of drawing setup file options.
% u3 J. Z% K% L# ~ l9 {& P!DRAWING_SETUP_FILE D:\worker\图框proe\english.dtl
1 _/ W' {3 m+ } H( ?: bpen_table_file D:\*\**7 A3 U& @$ t9 N; |4 V: Y+ h
default_ang_dec_places 2
; y5 g. {% e3 m7 `7 r- Z; Z+ Tcreate_drawing_dims_only YES
7 |8 a9 `% `, J5 Q7 `highlight_new_dims YES0 p7 X9 J& ^& o( `
rename_drawings_with_assem YES1 E* u/ E- @9 r* B. p7 u9 e+ t
gtol_dim_placement UNDER_VALUE9 a/ u& @2 f8 C9 H z
mark_approximate_dims YES
' `: I0 a1 |2 `9 g0 V" ksketcher_starts_in_2d yes6 g: k& a0 V5 {
plot_file_dir D:\*proe
# n4 O' d/ I4 P r- Q
( n. `) r' u" y) C4 r3 m$ g/ j+ _: I) u+ J. y; R
以上需要自己加入相关路径.既可(有"*"号的行);
) y, j+ y7 r9 q' S除了"pen1_line_weight "是实体线外,其余线宽
, W1 [" M" ?3 i0 v4 O& |1 G7 h( y; |! N+ Y同样自行设置.其中数值根据使用情况修改.以上
* K' ^: g# C3 j连同说明一起放在config.pro中( ]3 j" E4 N& ~, V5 k
- M" E! W& w7 a
[ 本帖最后由 hhq426 于 2009-7-9 19:06 编辑 ] |
