发表于 2010-11-8 10:57:37
来自: 中国香港
詳細的請查看WIKI4 C5 n) y& C$ y) Z8 u9 A# x
而JUS M.B1 023 看來是德文的簡寫
" l3 w" g) G/ Y" f+ `+ B$ B; W# G4 n' n6 e; v7 G0 p8 K; W
DIN 267-1 Fasteners - Part 1: Technical delivery conditions; General requirements Withdrawn 4 R! c# z0 H, l6 T8 r
DIN 267-2 Fasteners - Part 2: Technical delivery conditions; Bolts, Screws, Nuts and Similar Threaded and Formed Parts; Types and Dimensional Accuracy Active DIN EN ISO 4759-1 ISO 4759-1
4 _- ~& K4 D/ J$ I- L( U1 k, ?DIN 267-3 Fasteners - Part 3: Technical delivery conditions; Property classes for carbon steel and alloy steel bolts and screws; Conversion of property classes Withdrawn DIN EN ISO 898-1 ISO 898-1
& I/ r- A" o/ ^! J) i# H! A$ u; C: _DIN 267-4 Fasteners - Part 4: Technical delivery conditions; Property classes for nuts (previous classes) Withdrawn DIN EN ISO 898-2 ISO 898-2 x, L8 m/ v3 S: {
DIN 267-5 Fasteners – Part 5: Technical delivery conditions; Acceptance inspection; modified version of ISO 3269, 1984 edition Withdrawn DIN EN ISO 3269 ISO 32696 Y* H' Z' ]( H3 w
DIN 267-6 Fasteners - Part 6: Technical delivery conditions; Designs and accuracy of measurement for product grade F Active
6 {3 @5 a8 T9 o* ZDIN 267-7 Fasteners - Part 9: Technical delivery conditions; Bolts made of unalloyed or low-alloy steels Withdrawn DIN EN ISO 898-1 ISO 898-17 l2 H/ S: E, j: O, P) B; G
DIN 267-9 Fasteners - Part 9: Technical delivery conditions; Components with Electroplated Coatings Withdrawn DIN EN ISO 4042 ISO 4042! j. {5 [4 T% P' k& ^3 J2 N9 g
DIN 267-10 Fasteners - Part 10: Technical delivery conditions; Hot dip galvanized parts Withdrawn DIN EN ISO 10684 ISO 10684
+ M p; L% d: O% |6 aDIN 267-11 Fasteners - Part 11: Technical delivery conditions (with additions to ISO 3506); Corrosion-resistant stainless steel fasteners Withdrawn
# B+ n }( z3 LDIN 267-12 Fasteners - Part 12: Technical delivery conditions; Self-tapping screws Withdrawn DIN EN ISO 2702 ISO 2702
0 a, |+ z) A/ \, o cDIN 267-13 Fasteners - Part 13: Technical delivery conditions; Components for Bolted Connections Made Mainly from Materials Exhibiting a High Impact Strength at Low Temperature or from Materials with a High Temperature Strength Active 4 m4 W3 I0 K8 G, G; q
DIN 267-15 Fasteners - Part 15: Technical delivery conditions; Prevailing torque type nuts Withdrawn DIN EN ISO 2320,
8 @& Z, \/ k N. B7 [9 `# @DIN EN ISO 3506-1,
8 E$ h& Q3 N/ A/ N7 [. A( r3 DDIN EN ISO 3506-2,
) @1 L/ P. i: O( t+ HDIN EN ISO 3506-3 ISO 2320,4 z% i- y% y4 ?9 j& T q3 P* r
ISO 3506-1,
! m8 j% I) }# h1 WISO 3506-2,
! F9 A7 a& p9 m. r6 ?' K( }ISO 3506-3
- b. t" X; Z6 n, w+ [DIN 267-18 Fasteners - Part 18: Technical delivery conditions; Components made of Non-ferrous Metals Withdrawn DIN EN 28839 ISO 8839+ ~( x1 \1 x# B9 S9 w& V; p1 Z! A f
DIN 267-19 Fasteners - Part 19: Technical delivery conditions; Surface discontinuities on bolts and screws Withdrawn DIN EN ISO 26157-1,( x, w5 a' }) M. V3 ^6 A; C
DIN EN ISO 26157-3 ISO 6157-1,6 p& p- o5 K3 I8 Z
ISO 6157-3
6 }7 r+ B+ V/ X& wDIN 267-20 Fasteners - Part 20: Technical delivery conditions; Surface discontinuities on nuts Withdrawn DIN EN ISO 6157-2,1 \" E( x Q% l4 Y& p, L
DIN EN ISO 10484,
9 ]6 a2 w* C5 E/ T0 w2 r6 jDIN EN ISO 10485 ISO 6157-2,+ Y9 ?# O4 T& C) ]
ISO 10484,
/ }9 A2 \2 Q3 n5 J) E; Q5 Q# K6 t" ]% rISO 104854 n6 m) d. C& x) o* o* O' V7 z
DIN 267-21 Fasteners - Part 21: Technical delivery conditions; Widening test on nuts Withdrawn DIN EN ISO 6157-2,
, _4 n. s( }, ? CDIN EN ISO 10484,9 M) L3 J) w5 D( A& v& ?
1 _' W m0 V$ Z3 h. N& OISO 10484,
8 ^" C b, k% z/ HISO 10485
9 u/ S. P3 |& _- }DIN 267-23 Fasteners - Part 23: Technical delivery conditions; Property classes for nuts with fine thread (ISO classes) Withdrawn DIN EN ISO 898-6 ISO 898-61 J, _) _- c. ~8 R
DIN 267-24 Fasteners - Part 24: Technical delivery conditions; Property classes for nuts (Hardness classes) Active 8 O, c; i9 |/ _3 j
DIN 267-25 Fasteners - Part 25: Technical delivery conditions; Torsion testing of M1 to M10 bolts and screws Withdrawn DIN EN 20898-7 EN 20898-7
, `/ U0 }( z2 d) g, A, ~DIN 267-26 Fasteners - Part 26: Technical delivery conditions; Conical spring washers for bolt/nut assemblies Active
* P* j4 L, J( v6 fDIN 267-27 Fasteners - Part 27: Technical specifications; Steel screws, bolts and studs with adhesive coating Active
: a( k* ]3 {; B7 L. a" v3 JDIN 267-28 Fasteners - Part 28: Technical specifications; Steel screws, bolts and studs with locking coating Active
4 s: o. }& j+ U& TDIN 267-29 Fasteners - Part 29: Technical specifications; Product grades for parts for bolted connections for use at temperatures ranging from -200°C to +700°C Withdrawn 3 n' h0 g/ Q4 _# T% X
DIN 267-30 Fasteners - Part 30: Technical specifications; Metric thread rolling screws of property class 10.9 Active |
