发表于 2009-7-29 11:33:06
来自: 中国台湾
回复 1# SSBEE 的帖子
AISI 8660
0 |% z: S: H1 D1 ]/ M AISI 8860 Names Nickel-chromium-molybdenum steel
! j6 n1 s) x% ?* RDesignations United States: ASTM A322 , ASTM A332 , ASTM A506 , ASTM A519 , ASTM A711 , SAE J404 , SAE J412 , SAE J770 , UNS G86600 1 t* L4 i& [4 E% _+ b
Composition
% v/ n3 A- y2 t4 T' R. b0 C6 U Element Weight % $ w A/ f% D* u; H0 n
C 0.56-0.64
* r3 H, |3 V P5 R: _Mn 0.75-1.00
; h/ M6 A8 ^2 n: X" ]: |! Y+ TP 0.035 (max) 1 \- s' w7 e& W
S 0.04 (max) * W; s+ L- ^' ~
Si 0.15-0.30 / W; T; c% C, ^ d& k2 w
Cr 0.40-0.60
" B& Z# Q' Z l; \9 KNi 0.40-0.70
+ V8 W9 }& V) }# b7 ]+ @Mo 0.15-0.25
6 a4 A n; c5 H( }3 z% } Precision castings' W! P4 t. o9 ~4 G
specializes in all kinds of precision castings.4 Z3 I6 M. b9 y: ?1 ]5 W8 ]
7 F8 i6 [/ l3 k$ }; \+ G8 SMechanical Properties : Q: X# ] f: Y; Y( T
Properties Conditions 0 ^" j% f: D9 ]! L
T (°C) Treatment
: r a$ [8 |" Q% K" l9 {Density (×1000 kg/m3) 7.7-8.03 25
1 }/ G0 e+ _$ j6 G) zPoisson's Ratio 0.27-0.30 25
7 P4 s; D/ `6 T' l9 FElastic Modulus (GPa) 190-210 25
$ w0 H8 x5 G' J' Q& rTensile Strength (Mpa) 1634 25 oil quenched, fine grained, tempered at 425°C more
6 P9 F% ~' \9 [& }* S4 IYield Strength (Mpa) 1551 & K" u$ e: x( ?7 H
Elongation (%) 13
q' R: i, ]5 V- `% W+ Y. |Reduction in Area (%) 37
4 t* J# B) O. \; e0 v, G% yHardness (HB) 580 25 oil quenched, fine grained, tempered at 205°C more |
