FINISH
& O1 z( ~, C3 b+ ]4 J/CLEAR,START" A, P/ T" `* x3 l$ [- f: N
/CONFIG,NPROC,1 !Your CPU Number& R6 B( \: d9 M' ?' N8 I
!****************Parameter Define*******************
9 v- ~0 ~" H, t- z+ u*SET,corrupt,1.5
* e; o0 C& O+ ] Z+ s! X& H+ b*SET,NDTA,9
# L/ ^' Y; Q3 l*SET,DTA,NDTA-corrupt
d" W: L$ X( K!Flange size1 [) h% h/ [9 B
*SET,FLANG_D,420+ M, e( x: C& k5 \- H$ l9 G
*SET,FLANG_N,273; X* |% k2 z4 E5 z5 W
*SET,FLANG_A,219
( S8 i" X7 g% t7 n0 |7 s. r) g8 Y7 m*SET,FLANG_B,FLANG_A-2*DTA
; G5 b6 i! Y8 K) f*SET,FLANG_H,133
0 W4 H# h* F1 N+ i*SET,FLANG_C,55.5" z. T) b/ J5 }- s' S" m/ w! D( T
*SET,FLANG_H1,15
9 D" V# \, A! I1 G*SET,FLANG_DF,270- h. w6 C0 M4 [2 N% t
*SET,FLANG_F,1.6# ?& ^ u4 ?& o- }' R- B
*SET,FLANG_R,50 V; l8 T* }5 Y7 d7 [* X
!Shell size9 f8 O' M& x& p
*SET,SHELL_L,539.6
2 \9 {1 ^! M7 Z+ R*SET,SHELL_DO,219$ r/ t- i: o" u5 Y) h" B. H& X$ b
*SET,SHELL_DI,SHELL_DO-2*DTA- l( Y# z7 q, t: I$ N n
!Intergrade' B9 A" P. Z- b) P
*SET,INTER_H,200.66 L* |* J0 F! x$ ]( g9 Z
*SET,INTER_H1,30
" u3 {9 a& Q5 }7 N*SET,INTER_H2,40- t) T' Z/ V- q' ~) j; w
*SET,INTER_DO2,70- A& l0 E4 |# T
*SET,INTER_DI2,INTER_DO2-2*DTA. w3 E, J7 X8 u6 ]: s, V
*SET,INTER_R,60
" k% M1 g8 j" \. ]% Z*SET,INTER_R1,60
, y/ T0 K1 ?8 @# j!Pressure8 s+ K1 ~, O' H' t; w
*SET,pi,5.2
& i6 B2 ]+ v' p4 l*SET,flang_area,pi*(SHELL_DI/2)**2/((FLANG_DF/2)**2-(FLANG_B/2)**2)
: Z+ b( s h4 o4 C+ e*SET,inter_area,pi*(SHELL_DI/2)**2/((INTER_DO2/2)**2-(INTER_DI2/2)**2)# P9 W# i9 V. }6 Y% P
!****************Model Create*******************5 o9 N+ ^0 G# S5 l
/prep7
# Q+ m( X5 {' y& N) K3 j6 |4 wet,1,185' F" b _% k0 B. C+ F
mp,ex,1,1.95e5
% h7 E8 ~7 K/ A' k* @mp,nuxy,1,0.3
# i4 m% }6 X, h$ W/TITLE,Creating Modling$ ?7 P, p* ` l7 h" p
!Create Up Flange" G4 @" q( ^5 c$ }, u! O
( Z7 ]: }- s: x. g3 h4 O' _; n) D
!Create Key
; i C& i4 c! `' M& m5 j% |8 xk,1,FLANG_B/2,FLANG_H# a9 D6 [# y0 l. q' m
k,2,FLANG_A/2,FLANG_H
8 s( H2 y ^4 J D1 D' j- _k,3,FLANG_A/2,FLANG_H-FLANG_H1
) _8 f4 J* A% O! Ak,4,FLANG_N/2,FLANG_C
/ u9 u3 R# m, Q' U) M9 c5 _3 |k,5,FLANG_D/2,FLANG_C R3 X0 T/ ~0 @1 U. l" v$ z8 [8 {
k,6,FLANG_D/2,FLANG_F
8 V- |/ [. U9 h y+ T: h" B' {k,7,FLANG_DF/2,FLANG_F) @7 l* D1 F/ o) d$ _+ K+ S5 z
k,8,FLANG_DF/2,0, w8 e9 ~& A! [, F7 U
k,9,FLANG_B/2,0
( I3 L6 y* d9 ~2 G8 s!Create Line From Key- e1 w% g4 }. b1 [
*do,ii,1,8
8 g4 A+ h' _6 E7 f, `. r4 Y6 L1 Nl,ii,ii+1
8 z) L2 a7 ]" ?0 e5 N& q& s*enddo2 ~# o1 o6 V# @' X) }( F
l,1,9
7 H6 y) _" ^9 X6 \' a' Vlfillt,2,3,FLANG_R: d! w& s0 w( H8 @6 M- H2 z
lfillt,3,4,FLANG_R
7 P, X: I$ Q/ l$ J2 r( s1 O!Create Area From Line7 |8 o2 C2 f8 e) @
AL,ALL
% K' ~4 W" K; `( O6 d( ]0 QCM,FLANG_LOW,AREA% v4 Y: Z5 ]- [, ~3 f j, E! Y
( t4 Z0 D6 R' V; M7 I' N4 o6 p: a
!Create Shell
7 R' f1 P" F& @! VCSYS,4' ^- a# `- R0 Y$ W
wpoff,0,FLANG_H; Q) Y" ^' e! O |# U& S
RECTNG,SHELL_DI/2,SHELL_DO/2,0,SHELL_L,
" J1 W1 H. b5 N# OASEL,S,LOC,Y,0,SHELL_L' z6 @4 N' p: W! y8 ]7 {5 e
9 n- E) [8 w8 f; P6 P!Create Intergrade
3 q8 q) H5 g9 }wpoff,0,SHELL_L0 ^- U+ Z1 t, `+ M! ]" u+ ?5 D& U
*GET,KPMAX, KP,, NUM,MAX
9 @ ] S( ]$ _) s% ^( c- Ck,KPMAX+1,SHELL_DI/2,,
' }5 {& f# ?: c0 S0 \% O( Nk,KPMAX+2,SHELL_DI/2,INTER_H10 u' A+ E( `; ]( y) @
k,KPMAX+3,INTER_DI2/2,INTER_H-INTER_H2- F- k# I4 `( N" @" d1 _0 ?, j
k,KPMAX+4,INTER_DI2/2,INTER_H0 I' Q8 _, F! r$ c9 a4 E/ I
k,KPMAX+5,INTER_DI2/2+DTA,INTER_H* e, Y3 z g3 a
k,KPMAX+6,INTER_DI2/2+DTA,INTER_H-INTER_H2
- |. i3 u7 F: H2 S; ]7 Lk,KPMAX+7,SHELL_DI/2+DTA,INTER_H1
. T0 X2 t& C& y! E% V7 H' dk,KPMAX+8,SHELL_DI/2+DTA,,5 E: x) q7 r7 e3 @
*do,i,KPMAX+1,KPMAX+7! V* W2 t2 \2 l( y& s U
l,i,i+1! B, {9 T7 z w/ j
*enddo
1 R" Y8 N. l& r' F- Dl,KPMAX+1,KPMAX+8- P$ h+ ]7 U4 i0 |3 y! ~ m7 s
LFILLT,17,16,INTER_R, ,7 i& X1 ^4 b3 `' P( {0 w5 V
LFILLT,17,18,INTER_R1+DTA, ,
$ B7 Q: e8 U7 W+ SLFILLT,20,21,INTER_R1, ,) X4 Q/ H& U) P! N/ u) R& e2 i' U
LFILLT,21,22,INTER_R+DTA, ,
+ h# [- B, ?' e1 g* V6 `ALLSEL,ALL
8 s. j) V! y% l3 lLSEL,S, , ,163 W8 a4 D) c0 ^& Z
LSEL,A, , ,17$ B: p& A0 V( ^8 C7 U( C/ A
LSEL,A, , ,18$ X4 H9 l$ m7 o; X
LSEL,A, , ,24, j/ O J. A2 a& `
LSEL,A, , ,25+ w! |, j0 |% k
CM,INNER_LINE,LINE* S$ V3 I2 s V! E/ O
CMSEL,A,INNER_LINE
* A0 O2 E$ E: R2 o. kALLSEL,ALL/ H# A9 q, |# S' M |: q- Y
ALLSEL,BELOW,AREA+ c* F- u9 T1 H Y
CM,TEMP,LINE
1 q! w/ ?- B( _, W/ w- q6 C% t4 r' J" NALLSEL,ALL
9 s/ q4 D t% s# m+ ~+ L8 CLSEL,U, , ,TEMP$ b. q9 _5 A8 ~+ H/ k/ ^
AL,ALL! L6 d" Q: N( f* U1 S
CMDELE,TEMP, v3 p- s0 a* {& \ ?8 | Q
. M) W4 E# w+ a) `( I) Y' u3 j/ `( n!Rote Area
9 v6 E& g) Y2 q' s; z5 L; R. }6 h. ~ALLSEL,ALL# l& {% g) [- N% X
CM,ALL_AREA,AREA8 ]# t: c2 s: p+ a
wpstyl,defa" r6 V3 E L- Y) k: Q
; X% O0 [0 ?: D0 o1 y& t6 H8 ok,KPMAX+1,,,,
& [) t, W. H0 ?8 xk,KPMAX+2,,FLANG_H+SHELL_L+INTER_H,,
) D! l8 C0 p, I! @# z/ N4 YVROTAT,ALL_AREA, , , , , ,KPMAX+1,KPMAX+2 ,180, ," h( ]" i) t2 b) z Y
VGLUE,ALL
4 ?" o) Q. O) H+ c' [7 i4 p0 l# Y1 A9 _! A/ D) D
/TITLE,Meshing Modling
# H; o& \3 U" X7 ^TYPE,1
" G/ f! K! G) c. T0 FMAT,12 R/ g3 c% C- _8 u: N9 r: Y
VSEL,S,LOC,Y,0,FLANG_H+SHELL_L+ u% M+ U. `, ~( `2 a6 ^, Q6 P8 t
ESIZE,10,0,
- t) y6 ]' ?+ y* a" }' O( e& o4 z1 ZVSWEEP,ALL. [. n5 V* t4 {% M: T
VSEL,S,LOC,Y,FLANG_H+SHELL_L,FLANG_H+SHELL_L+INTER_H
$ i u/ n- G+ }5 v* p: fESIZE,1,0,
1 i1 q [2 _5 u- ]4 E6 L2 q8 V4 cVSWEEP,ALL
4 I% H6 K1 q0 y, g+ Z# VALLSEL,ALL% t& g9 i2 P& t& n6 ^, O0 H$ F. h
NUMMRG,ALL, , , ,LOW5 k; f1 U/ i5 H- N" @
NUMCMP,ALL, , , ,LOW# ?( a0 m( k5 A! a
!****************Load And Solve**********3 n$ G" D; |# j
FINISH
) {3 b6 _, n, `3 O8 j- X- h/SOL
( C5 ^' ]2 @0 w1 d* m' U/TITLE,Define Load Pressure
+ C( |) ^8 }$ y# G' t! h9 G* S/REPLOT: z, y' m c0 s: E W' G
ASEL,S,LOC,Z,0
+ Q# ]; j1 b C8 z9 S2 {# V3 yDA,ALL,SYMM6 i( d; X, g4 k& u* i( ?) O
ALLSEL,ALL
% q% a& O2 a& J7 w9 i' wASEL,S,LOC,Y,0: \3 _/ ~) J- e2 \. T# r/ C& U- U
SFA,ALL,1,PRES,-flang_area
) w: V; e- C. t5 ~: _ASEL,S,LOC,Y,FLANG_H+SHELL_L+INTER_H
# a1 n- x) x/ ]SFA,ALL,1,PRES,-inter_area2 r+ M+ P0 V8 D7 J( h& P" g
ALLSEL,ALL
8 o. P- X0 W: P& K9 P2 S Jwpro,,-90,+ T& x, x4 R9 M/ j8 ~& l1 _
wpstyle,,,,,,1,,,9 i3 t H' w8 x1 e: {" _ N" b) n L9 {
ASEL,S,LOC,X,FLANG_D/2$ B/ S4 e2 @, a
DA,ALL,ALL,7 e# O. f! p0 I" @; S- ~! \) j
ALLSEL,ALL+ a- ]: z) B" _
VSEL,S,LOC,Z,0,FLANG_H+SHELL_L9 m; m8 Z! U2 A# _% K
ASLV,R) f% ^* F4 |8 I2 Z2 }7 x
ASEL,S,LOC,X,SHELL_DI/29 T% j2 o, t3 G6 f. f
SFA,ALL,1,PRES,pi- x: A+ y, M2 Q9 k9 O n
ALLSEL,ALL
. ^5 x9 H' J/ o' Y: ?5 ~LSEL,S, , ,INNER_LINE2 g; B9 u+ H1 W# r \( M
ASLL,R
6 ~/ d- F7 S; d: ]$ z( S$ `6 h, \wpstyl,defa# O1 X C- Q: T
wpoff,,FLANG_H+SHELL_L+INTER_H1. k0 h# c+ }. t" g) _
ASEL,U,LOC,Z,0
. F E6 X7 d0 b; _* DLSLA,R( H) H+ M) [$ J% A: n1 `# b1 M! b
LSLA,S/ ?7 i% S9 \: D" W
LSEL,R,LOC,X,0
& u) F o, i: m1 p' kASLL,S$ |+ I( s: w/ P0 Q, A
ASEL,U,LOC,X,0
1 H) `4 Q9 b; R( M+ W0 \) qSFA,ALL,1,PRES,pi
+ Q2 a. W0 P# c3 A( N D4 R! a6 \ALLSEL,ALL6 O0 L9 O$ j) A+ Z
SOLVE, z9 A1 B! G8 a+ N$ D) g) m, o
FINISH
6 l* m" J& A# `7 ~/POST1 ?" y. `/ z& j: J* B5 X9 \
/TITLE,Giving The Stress Intensity Plot* ?' o; e6 c B4 Z5 i
PLNSOL,S,INT,0,1 |
