4天前
查看: 2781|回复: 1
[求助] SAE 10B21M材料
发表于 2009-7-29 18:47:51 | 显示全部楼层 |阅读模式 来自: 中国重庆
SAE 10B21M材料 ,希望知道的师傅们给与提示或者有这方面的标准的能够提供上来,因本人不是这个行业的,所以接到这个东西搞不懂,希望指导,谢谢!
发表于 2009-7-31 15:30:22 | 显示全部楼层 来自: 中国台湾
回复 1# 梦已随风 的帖子
成份如下表,與10B21相同,為加B之碳鋼,加B一般為了好成形加工
" P: V# A+ d% {* l3 v8 {. l; A! g" d: `/ N' p: S0 y; d) D% O2 y
Boron Steel
  e1 h1 X( y9 |3 J1 ZOne of our most demanded products; boron steel is manufactured by using qualitative steel. The toughness of boron steel is mainly due to the processes of tempering, forming and oil/water quenching. The boron steel products has harden-ability which is similar to the costly low alloy treatable steels and much higher carbon steels. We also provide customized solutions for boron steel as per the specifications of our clients. 3 i% {+ i- S* B! o& e6 w
9 h# w/ l3 g1 V9 _Grade                      C%     Si%            Mn%          S%               P%              Cr%                   B%
0 w' ]9 p. h! R9 ]AISI 10B21M 0.18-0.23  0.30 Max    0.80-1.10    0.03 Max      0.03 Max    0.10-0.20   0.003-0.0005+ c6 n! z* t( F8 O0 g3 K; C' P
. M" N2 a/ L7 c2 _  O/ q0 B1 F* k
[ 本帖最后由 cylin123 于 2009-7-31 15:31 编辑 ]
