查看: 1051|回复: 1
[求助] 什么材料
发表于 2009-8-6 14:27:48 | 显示全部楼层 |阅读模式 来自: 中国江苏镇江
UNSG10180这种什么材料
发表于 2009-8-6 14:35:35 | 显示全部楼层 来自: 中国台湾
回复 1# 17091144 的帖子
就是AISI 10185 }" K9 W9 T! }, m" R( C4 i! n
Mechanical PropertiesMetricEnglishComments
Hardness, Brinell126
+ k7 Y, N1 M" X- R/ p  m% w
126
  V2 I; I# d% ~6 e1 l& y
Hardness, Knoop145* S% K) V. C" l8 }& U' ~
145. x$ G# _$ ]& M, V9 p+ v9 L# L" r) z
Converted from Brinell hardness.
Hardness, Rockwell B71* W& q- D5 X9 V% s
71
4 {$ n  C0 S+ K1 ^4 d3 r4 \- b2 B
Hardness, Vickers131
8 j' P/ g+ r0 q* |7 Y0 r) y" b
131
8 w" P5 x  X; Z+ r1 ]' \+ c
Tensile Strength, Ultimate440 MPa6 c  c: q% k$ Y0 X" W
63800 psi0 @5 @+ P( A  _! v4 k9 u9 Y
Tensile Strength, Yield370 MPa' C3 O8 m1 k' c1 ~0 W
53700 psi* F; X0 }* G' d. \5 B7 _* l
Elongation at Break15.0 %
  M7 \0 f0 W# l9 n2 Z' j
15.0 %) x/ m6 r7 A3 W* A) M
In 50 mm
Reduction of Area40.0 %: Z$ b* r: {6 r! ^) Y7 V9 F* z
40.0 %
9 S$ H* c) x/ F# P) j4 |
Modulus of Elasticity205 GPa3 z. D5 w0 E2 {7 P3 `  c
29700 ksi# N  y  O. g! N: Z* x# N3 e" Z
Typical for steel
Bulk Modulus140 GPa% a# X7 `/ ?, N4 O
20300 ksi
, G' ]; |, q' U/ J+ [" I
Typical for steel
Poissons Ratio0.290
0 @! |* P3 j& \; r
0.2908 y! v8 R* z( j: O7 {5 l# M' X/ x
Typical For Steel
Machinability70 %) h3 k- ?) m& z6 V  k2 v; k5 ~
70 %5 z4 v/ |! P7 j, s2 y
Based on AISI 1212 steel. as 100% machinability
Shear Modulus80.0 GPa4 s0 f! i# P4 }) y" }0 T
11600 ksi
4 J- e& e4 V' T4 w# I) _
Typical for steel
5 S7 f& L& r6 j3 d: w' R
$ o, d5 }6 j! H# R  K' w7 ]8 [
[ 本帖最后由 cylin123 于 2009-8-6 14:37 编辑 ]
