2021-06-25
查看: 4038|回复: 5
[已解决] PROE如何控制工程图打印线的粗细?
发表于 2009-8-11 21:24:19 | 显示全部楼层 |阅读模式 来自: 中国江苏连云港
PROE如何控制工程图打印线的粗细?请各路高手指教./ K0 M* g  ^- ^  i' i
先谢了!
发表于 2009-8-11 22:34:39 | 显示全部楼层 来自: 中国北京
在config.pro中加入:0 j+ {5 e! ~8 a- X+ n
raster_plot_dpi 300   !设置打印分辨率4 n) F. ]: @0 ]. K, F7 {) J) C
shaded_postscript_background no: f0 t. z( p: I  D
use_software_linefonts yes    !出图时使用准确线型7 o9 x; e1 f2 D/ \! ~2 z
! LANDSCAPE_POSTSCRIPT_PRINT NO,打印时是否旋转90度
7 g# u6 o1 E- \- m7 e!pro_plot_config_dir $PRODIR/../pro_stds/plot_configs. P& x, u) ^8 z) t) ~7 @
!PLOTTER SET: To your defaut plotter5 N  ]' X. `! K9 Z
plotter HP1055CM
1 H! @9 D5 s& {1 Q/ x& ~( nplotter_command WINDOWS_PRINT_MANAGER
6 _$ [! j. c0 S' s' T4 cuse_8_plotter_pens YES    !设置打印机是否支持8种绘图仪笔,缺省为4种
) ]* b+ Y! Z. j6 \!pen1-pen8 的缺省值为 4,1,2,3,2,3,1,4;数值越大,笔宽越粗,最粗为166 d9 c/ s6 m4 z8 v! y9 C/ T  N
下面是设置系统的8种笔宽:$ E, N2 c  Q: G/ U) O: x
pen1_line_weight 5% U: [% |6 n  _* T  v9 j! h/ K* ?
pen2_line_weight 2
& E4 Z9 `& y. Z- C- |$ Y. i2 S2 Tpen3_line_weight 29 e) h. l. W* Y% X: M3 Q' E# t
pen4_line_weight 2
$ k, |1 K; q: X# U/ \+ `pen5_line_weight 2
; T% y' G5 n) g0 {' wpen6_line_weight 2$ n( B' P) ]1 E2 B
pen7_line_weight 2
7 w, b# S1 ?% D) D1 J% ppen8_line_weight 2
2 N7 }/ y/ @" N: draster_plot_dpi 300
- N! z* U4 P6 s* Euse_software_linefonts yes8 c! H5 @! B+ }7 I& f
use_8_plotter_pens YES# L* Q( i/ [& a. B& W
! Control size of the window by either one of the following config options
6 W  _3 {1 ]/ z" M% @windows_scale 1.00 `9 a% X. ~7 m5 `0 n2 F, S
!reserved_menu_space 2; S0 p; }% O0 h+ M4 _% s8 A% P
sketcher_disp_grid NO
5 o- I! Q& z8 r* N( p5 P! Select either english or metric drawing setup files as your; A6 k' m0 b/ b- C, z0 L4 t
! common default. You should refer to the "Drawing User's Guide"! F/ I2 |! [& F" n8 v3 S
! for a complete list of drawing setup file options.: E; y3 A  h( l; x; G
!DRAWING_SETUP_FILE *:\worker\图框proe\english.dtl  W1 D/ X$ z! R3 D. t( G
pen_table_file *\worker\图框proe; Q0 o2 M1 G7 G8 Y: |+ P9 }; ]
default_ang_dec_places 2
2 G. [2 r7 \/ n4 e% l8 `1 i' Q  ?8 y) i7 k( r# U+ b" Q
* g' C7 {) g& I2 z1 j上面的"pen1"是实体线宽,其余线宽可以按照一样宽设置..打印的粗细可以自己修改.
9 h1 s9 F& D. {+ p' {$ s
6 b: b' A; h+ C[ 本帖最后由 hhq426 于 2009-8-11 22:39 编辑 ]
wz_111 + 3 应助
 楼主| 发表于 2009-8-11 22:45:39 | 显示全部楼层 来自: 中国江苏连云港
太感谢了,大兄弟
发表于 2009-8-11 22:47:44 | 显示全部楼层 来自: 中国江苏无锡
在打印设置里面也有线宽设置的
发表于 2011-3-26 22:21:27 | 显示全部楼层 来自: 中国山东潍坊
好东西,今天正在学。
发表于 2011-3-26 23:05:10 | 显示全部楼层 来自: 中国江苏徐州
进来看看,谢谢了.
