查看: 3156|回复: 8
[分享] Autocad 3D commands shortcut
发表于 2009-8-13 03:10:41 | 显示全部楼层 |阅读模式 来自: 加拿大
; ============================= Start ucs.lsp ==============================
& j( [! b6 ?. x) y0 S- B; this file is created to have quick access to ucs and view related commands  h3 ^( y% W: s
; created by: Don Wen+ N& o1 D8 O4 q
;         on: August 12, 20095 y  m$ M7 M4 I. l4 y! _% C7 Y
; Usage:
( y, o0 K) {! O# o# w9 u* {3 J, D4 ]4 U; Run appload to load ucs.lsp in AutoCAD
0 l8 _! \: w/ e5 x0 J9 f1 Q. B, E; then all the following shortcuts can be used as: u3, uz, ub, v1, v2, vv1, vv2, etc.
1 g: g. ~5 X4 k- d4 }" T# m: d* I: _5 Z. m( |
;create shortcuts for ucs commands8 w/ A" F" V% I3 M! n/ p$ D
;u3() ---- UCS with 3 points, e9 k. [6 ]$ {
;uz() ---- UCS with Z-Axis"  p, y! n" U  U/ ?+ ~% g% u
;ub() ---- UCS with Object"
5 X: ^, M) I4 F2 n4 B
4 J6 r2 q0 Q' X# J' t, H; create shortcuts for view commands
, Z. R/ u4 {& W& K# |;v1() ---- view from top3 ~# ~0 p& K3 r8 g
;v11() ---- view from bottom
2 y9 D( i  a1 c
& ^4 i8 |# @9 s& C! z;v2() ---- view from left
; D% r; W6 r, E;v22() ---- view from right
* K% ~! s$ h( ^" `7 `* P' i% M0 T2 s0 t* \9 J2 A1 a6 G0 Y- p
;v3() ---- view from front4 N4 Q0 V4 M7 J0 v2 C3 V9 O
;v33() ---- view from back) ~. a( X# X% _2 a4 o4 I
6 `3 E  c8 e; y9 W# L! ~4 r;vv1() ---- view from south west (SW) iso
8 D  G& y$ \, d  |9 E  ^;vv2() ----  view from south east (SE) iso+ `4 m, t: w, z, H6 E/ O* u. d
;vv3() ---- view from north east (NE) iso2 ~' `9 S; `* E7 `+ V+ I# S0 Y
;vv4() ----  view from north west (NW) iso
- \/ b2 S6 U8 n$ c* r* d( \
4 P  ^, o2 ^4 U3 `$ b3 g! g- a;===============================================
- g: O. M: {: g  {8 F0 b
8 |4 H; s1 o9 l2 d" _8 ?7 {9 ~7 o* a(defun c:u3()
9 j( b* R3 ~2 h6 Z& m; `    ;UCS with 3 points8 t: y0 n( k6 L: c, b8 h6 b
    (prompt "UCS with 3 points")8 O9 i4 H) T+ G9 h. N! E5 W& a# S
    (command "_ucs" "3")
, n8 m. g! ]( s. t    (princ)8 O  e4 ?+ D3 A. j) ?
)2 ~5 a# m. |2 `! A! n
+ L% L8 v! y+ l4 o3 A: C6 o(defun c:uz()+ B0 L" l5 Z) b& a: A) U
      ;UCS with Z-Axis
2 a$ K3 \; ^+ h3 \4 R4 u    (prompt "UCS with Z-Axis")
, b) ?! P1 p7 P4 `# \+ s    (command "_ucs" "za")
% z, l) D0 C5 ]3 u    (princ)
$ O  V& Y/ W7 O0 A8 [+ D)
0 b1 g8 ^$ o" s4 @1 x. Z* m- g8 Y' l1 }: ^5 Y
(defun c:ub()" E* q2 S' j( ]7 m& S9 B$ X
      ;UCS with Object
7 V# G: z* ]5 ~4 Y7 O7 ?+ F    (prompt "UCS with Object")
3 Y" V! B/ c6 N; E& ^    (command "_ucs" "ob")
! {$ a. i3 D2 u    (princ)
5 i7 {7 v' g5 O/ D4 M9 Z, Y)
# W, f+ K" X* \; U' q* D
  j' X6 \: ]0 w$ w. L4 \  c; create shortcuts for view commands9 m/ y. P3 M1 R9 U
(defun c:v1()) A% U& d5 p* M0 ~# h
; view from top/ p, f$ y! }8 x
    (prompt "^C^C_-view _top")
: E( E- ^7 L/ h% S% x    (command "-view" "top"), M6 f! u% H! x$ E2 P& B. D
    (princ)
& b$ `) a. `+ f$ y. N. N)
3 e6 H! O3 d  T  a0 ]
/ X+ p! D" v9 d" D
; V) l) j4 r$ ^3 u% d. w5 O1 `. y* v(defun c:v11()
+ p# P- m; f# e, @! P; view from bottom
+ E5 x7 o# a. T' Y    (prompt "^C^C_-view _bottom")
. `( Y( b+ ~* ?1 F+ h2 S    (command "-view" "bottom")
" i) m( ?7 I' z5 u    (princ)6 J3 @5 u. c+ B- D9 S2 T
' D% D( s# V: t' {- |' M# m1 |  `! i1 K
(defun c:v2()5 ~. W1 k* g7 Y% \
; view from left
. c( }% X. u& M( h; b: O4 l    (prompt "^C^C_-view _left")
0 y1 o: y, h# ~    (command "-view" "left")6 \& k, c8 Q/ ^- a3 D8 X- B% s: k
    (princ), j# e! `0 @6 J
), Q- w" j4 Q, }2 B2 `/ Z4 ?$ A
8 x' C# X8 m4 A7 B" @2 F- Q(defun c:v22()
5 r( G4 m' h, Z0 C5 o' D; view from right: d- v% w% N2 q1 @
    (prompt "^C^C_-view _right"). r2 J6 @) o+ q# o9 h$ H7 [
    (command "-view" "right")( o" d1 c: z& y6 x' J. k
    (princ)
* @0 N0 @% Q) o# f& ~)9 j0 J& ?% x) y; M) V7 S/ u
( ~, b8 t( z  s; t2 s' }  e
(defun c:v3()
4 Z1 p2 b3 B+ c, b$ A2 O  E- y; view from front3 u: B) B! k+ o: `9 y- y% m8 m( ~" r
    (prompt "^C^C_-view _front")1 l) Q( ]9 ]; A, i  y3 [6 x
    (command "-view" "front")
' L7 J- J9 Y. f3 ?    (princ)0 H% I, a, o) p0 A  p6 I
. o  C5 K) M5 q1 D! J* g% X, G& Y% H$ T+ ]5 X9 A7 I
(defun c:v33()
! f/ L7 f4 L/ }" N; i; view from back
  X) {/ y7 A5 X    (prompt "^C^C_-view _back")6 I0 [% Y; S+ m& j
    (command "-view" "back")
! s- s1 s% D& ~    (princ)
6 @% o% J8 c: L)$ D' M. v6 ?" y! e7 ]# E$ W
! E$ D8 R1 M' S+ G(defun c:vv1()9 q$ {! |0 A  f1 j6 E
; view from south west iso3 t/ d5 j0 O* @4 j4 i
    (prompt "view from south west iso")" c; R# r) Q  k. N8 R" ?5 o6 P) |
    (command "-view" "swiso")1 W! a# \* i0 o# L- v2 A" ~
    (princ)+ Q5 {2 G" a; p! I& N
" v! ~5 O7 t9 {/ b
7 A$ A$ E$ n' Y! f# d) w(defun c:vv2()
6 {" z2 r" |2 v. S) z; view from south east iso8 M% i1 t: W6 Q& o0 l/ [
    (prompt "view from south east iso")! v9 O1 H& I: d9 y  I
    (command "-view" "seiso")8 r( Q! e+ o( n9 u
    (princ)
; i7 |  f, Y7 ^2 \% R/ H, p% Y7 w)
. n* W' H. w6 ], S6 E
. F4 z1 w# m. U. B(defun c:vv3(); U8 [+ c7 P4 }
; view from north east iso" v: v. r# }" Z! @6 t, \, ~
    (prompt "view from north east iso")2 g; B7 k, l& n
    (command "-view" "neiso")
$ l: x# B+ v" R8 j    (princ)5 L2 R, q" S6 a+ b2 y" f. C6 U
), g0 _  R( V5 T* e7 J8 z
  G% F3 X& @2 T- I(defun c:vv4()' G/ D% O. I' a( \$ v/ `& d; ?# o
; view from north west iso
+ h4 Q9 @: p+ N$ ^    (prompt "; view from north west iso")
3 Z1 P' L2 {. U    (command "-view" "nwiso")" v' A% }' V( w3 Z
    (princ)6 }8 w8 K$ T* P. Z; m, N$ O
)2 C  ~) g: J$ }2 M* P& V, v
9 ~$ l) \! L$ p+ B
; ============================= End ucs.lsp ==============================
ucs.lsp.txt
2.37 KB, 下载次数: 17
 楼主| 发表于 2009-8-13 12:13:58 | 显示全部楼层 来自: 加拿大
说明
说明:
% S$ ~: ^3 G4 D! ^1 G. J8 O% z1 所制定的快捷键尽量将键位放在左手容易触及的位置,又有规律,从而达到左手负责键盘命令,右手负责鼠标的目的,提高作图效率。% b3 w) ]$ F$ D/ f( ?
2 这些快捷键定义替代了相应工具条,熟练掌握的话,对于大量作  3D  建模的,比鼠标点击工具条快捷。
woaishuijia + 5 技术讨论
发表于 2009-8-13 12:35:01 | 显示全部楼层 来自: 中国广东佛山
是个定义快捷键的好办法,借用了。(再改成自己习惯、好记忆的键,效果更佳)
 楼主| 发表于 2009-8-13 15:12:43 | 显示全部楼层 来自: 加拿大
原帖由 gongwen0519 于 2009-8-12 20:35 发表 http://www.3dportal.cn/discuz/images/common/back.gif
1 ~5 R& l) V2 k是个定义快捷键的好办法,借用了。(再改成自己习惯、好记忆的键,效果更佳)
0 a( v2 q* b6 M/ C. {的确,每个企业/个人都因工作性质有不同的最常用命令,上面提出的例子只是提供一种思路,以期抛砖引玉。
4 Z/ l- g) j0 B' d1 m9 l* `+ Q) {, j7 m2 A4 _( s- U3 ^
补充一下:在定义组合的时候,使用v1, v11, vv1, 其思路是:
4 n) L' f- P+ L0 A+ O
  • v 代表 view (视图), v1 - 上(俯视图),v11 - 下(仰视图),v2 - 左视图, v22 - 右视图, 依照的是上下左右前后的顺序。
  • vv1是两个 v ,还是与 view 有关。两个 v , 有代表立体视图的目的。
  • 这里用了字母或数字的重复组合,是为了尽量减少手指的移动动作,达到提速的效果。
  • 尽量选用键盘左部的字母和数字来定义快捷键,减少左手奔波程度,呵呵。
  • 效果:单个字母 v,  实现了最基本又最常用的 10 个视图命令。
* s" r9 y0 U( Q6 h* \8 z此外,上面这些命令在工具条上对应的是命令选项组合,不能直接在 acad.pgp 实现,因而采用 lisp 来实现,供借鉴。9 {  c) W( X$ v2 ~* u; ^: J
% V3 h1 y$ B' E# P9 L2 w0 a
[ 本帖最后由 dwen999 于 2009-8-12 23:21 编辑 ]
发表于 2009-11-30 12:00:07 | 显示全部楼层 来自: 中国广东深圳
楼主辛苦了
发表于 2009-11-30 17:09:39 | 显示全部楼层 来自: 中国辽宁本溪
常用的自定义快捷键文件在support 目录下 acad.pgp 文件中,打开后直接修改,- e  I+ F6 T0 S, {+ W( X
特殊的可以考虑用楼主的方法
9 f. g$ N# i1 P& h+ j9 I8 @& s. G9 b# V# B& H
[ 本帖最后由 xxxhhhqqq 于 2009-11-30 17:14 编辑 ]
 楼主| 发表于 2010-1-1 11:09:52 | 显示全部楼层 来自: 加拿大
come back to have a look.: m! d. L" I4 T9 m# V$ }
. ^' m# C2 r8 R! |7 F) c; O: e6 Kall the best to everybody in year 2010!
发表于 2010-1-6 16:26:35 | 显示全部楼层 来自: 中国山东威海
great! thank you
发表于 2010-2-1 16:26:06 | 显示全部楼层 来自: 中国江苏无锡
好啊..楼主还发放出了源程序.来供大家学习....
; b: \; g) g# C
# D- S0 O, j2 |3 J1 |不错啊...平时命令多的要死..新安装之后又找不到了...烦....
& X6 a0 f: {1 F5 [* A7 ~: X& b) o% T, }
有这个自定义工具就好了.
